FD Outer Seal Pictorial!
Discussion in 'GS Boxers' started by JimVonBaden, Apr 19, 2013.
  1. ElGringo
    ElGringo Long timer
    Nov 13, 2006
    1,679
    Purgatory
    Hi Jim, big fan here. I was told by phoenix bmw that this is incorrect. You should NOT push the seal in as far as you can. I had inquired about this, and they showed me the special bmw tool they used in order to place the seal at the correct depth. I ended up duplicating the tool. Perhaps something has changed on later models??? I performed this procedure on a 2007.
    H
    #21
  2. cjack
    cjack Been here awhile
    Nov 18, 2005
    866
    Illinois
    How deep is the relief on the tool...measure from the larger diameter stop surface to the seal pushing surface?
    #22
  3. JimVonBaden
    Feb 11, 2005
    88,047
    Alexandria, VA
    The bike I used this on was a 2008. I have also done it on a 2005, 2006, 2009, and a 2010. They can say what they like, but my experience over about 20 bikes has been universally successful. I am sure they believed what they said, but it is just not the case.
    #23
  4. cjack
    Nov 18, 2005
    866
    Illinois
    Interesting what the depth is before removing the old seal.
    Could be a change?
    In the 70s, the rear engine seals leaked chronically. BMW changed the depth of the seal. I don't recall what the theory was in doing that, but I believe the frequency of leaks was reduced.
    #24
  5. JimVonBaden
    Feb 11, 2005
    88,047
    Alexandria, VA
    Could be, but since none of the seals I have changed have leaked, I do not see how this is an issue. :dunno
    The ReProm says this:
    Position shaft sealing ring (1) with the closed side out (arrow) and use drift (No. 33 1 892) to install it until fully seated.
    It is unclear if the drift fully seats it against the bearing race, or just positions it.
    #25
  6. cjack
    Nov 18, 2005
    866
    Illinois
    Yes...won't be the first time BMW just made a tool and more was read into it than was there.
    #26
  7. ElGringo
    ElGringo Long timer
    Nov 13, 2006
    1,679
    Purgatory
    I don't recall what the depth was. Id have to go dig up the tool and check.
    But I believe this photo shows the relief that Jim refers to:
    Pressing up against the relief would insure proper alignment. And yes, anything a bmw mechanic says, should be taken with a grain of salt.
    #27
  8. slade2
    slade2 Been here awhile
    Oct 8, 2008
    179
    northwest new mexico
    You need to install it deep enough to just get the snap ring back in place,
    that is pretty much botomed out in the bore.
    Slade
    #28
  9. N-m
    N-m Captain 2 Sexy
    Jan 18, 2011
    504
    Too Far from My Welder and BMW in South TN.
    If you have a snap ring in place that holds the seal in place. I would think The seal is riding against the snap ring or could work its way over to the snap ring at some point. That could mean depth is important from the standpoint of installing the snap ring deep enough to simply get the ring back in place.
    Do you have a pic of the tool? Is it round and covering the majority of the face of the seal? If so I would think the factory is trying to seat the seal evenly all the way around with a lesser chance of damaging it.
    Question: does this apply to a 1995?
    #29
  10. JimVonBaden
    Feb 11, 2005
    88,047
    Alexandria, VA
    If you seat the seal against the bearing race the snap ring groove is perfectly positioned.
    No, it doesn't apply to the 95GS.
    #30
  11. N-m
    N-m Captain 2 Sexy
    Jan 18, 2011
    504
    I am not near my bike and could not remember the FD set up. I saw a picture of a 96 and knew you were talking about a later set up. Thanks.
    #31
  12. KHud
    KHud Survivor Supporter
    Jun 24, 2008
    4,649
    Big Sky Country
    Jim,
    Thank you for your contributions to all of us wanna be mechanics. I just noticed that my R1200R (08) is weeping and I'm about ready to replace the seal. QUESTION: How does one determine if the bearing behind the seal is bad and if so what is the proceedure to replace. (Remember no good deed goes unpunished).
    By the way, on the BMW fiche there is a PDF file shown where the seal in question is listed. The PDF shows essentially the same proceedures as you showed us for replacement, but no where near as well illustrated as yours. The special tool for seating the seal is shown and it appears to me it will push the seal in as far as it will go and not to a predetermined lesser depth.
    Thanks again.
    #32
  13. JimVonBaden
    Feb 11, 2005
    88,047
    Alexandria, VA
    Hi,
    Thanks, and unfortunately the bearing is not a general DIY replacement, though it can be done. Usually you will know if it is bad because you have movement in the wheel when attached. You are allowed 1mm of movement at the rim.
    #33
  14. Britome
    Britome Get Free
    Nov 7, 2009
    2,252
    Cincinnati, OH
    So this process is if you see oil weeping out of the plastic?
    #34
  15. JimVonBaden
    Feb 11, 2005
    88,047
    Alexandria, VA
    Right side leak, yes.
    #35
  16. GL1800
    GL1800 RAT PACK---GS GAINT
    Jan 6, 2008
    109
    C.S.TX
    when ordering my new seal I see there is a new revised part# 33117722890. this seal is 59.8 75 8 old seal 60 75 8 so i like improvement!!:clap
    #36
  17. teomannaskali
    teomannaskali Long timer
    Mar 8, 2011
    1,185
    Plaka 34
    Where did you order the seal? İ have a 2005
    #37
  18. JimVonBaden
    Feb 11, 2005
    88,047
    Alexandria, VA
    Any BMW dealer should have it in stock.
    #38
  19. mefly2
    mefly2 Long timer
    Jun 28, 2010
    1,235
    Big Sky Country
    Agreed!
    #39
  20. DaveCR
    DaveCR Been here awhile
    Apr 29, 2010
    422
    Costa Rica -
    so I think I have to change my seal as well!
    today I was washing my bike after a loooooong time and I found this:
    I hope there's still some oil inside :eek1
    #40
