Fencing Staple punctured my Rear Tire... What to do?
Discussion in 'Parallel Universe' started by HikerDaddy, Jul 20, 2020.
  1. HikerDaddy
    HikerDaddy Adventurer
    Jun 21, 2015
    57
    Vancouver
    I had a great ride Sunday up near Harrison Hot Springs in British Columbia. On my way back home I ran over a fencing staple which punctured my tire with two holes about 3/8" apart.
    I through some air in the tire and it went flat right away.
    I've got about 1200 miles on that tire and feel the only option is to replace it or is their another way to truly patch it that I am not away of that will give me another 3000 to 4000 miles ????
    I do ride allot of gravel, ride over some good size rocks and washboards
  2. Dorito
    Dorito Dreamer and Doer
    Jul 31, 2010
    7,582
    Maryland
    Which bike/year? Can you just stuff a tube in the rim, or does it have integrated valve stems? If no, then the next part depends entirely where you are on the risk spectrum. How close is the damage to the sidewall? Which tire front or rear? A dealership would never plug any tire. You certainly could take off the rim and patch from the inside. I've known people to stuff multiple plugs into a hole.
    At the end of the day, I've certainly plugged tires to ride home. Some plugs have lived happily ever until end of tire. Hindsight, I wonder if the $200 savings was really worth a potential crash.
    Arbolmano likes this.
  3. fjmartin
    fjmartin Long timer
    Sep 26, 2016
    1,132
    Scottsdale, AZ
    If a regular tube/tire setup, remove the staple and replace the tube. If just two little holes in main tread and not sideway then no issue.
    If a tubeless setup, put in tire plugs if holes are in tread and not sidewall.
    Mumbles24 and Dirty bike like this.
  4. Dirty bike
    Dirty bike EricV
    Apr 10, 2011
    2,593
    Tupelo, MS
    There are also smaller diameter plugs available that might make things easier. I'm not a huge fan of Dynaplug kits for normal repairs, but for tiny staple holes, it might be worth a try. LINK
    I've had that exact puncture on a front tire, coincidentally in B.C. at the time. I made the mistake of using slime and it was a hot mess. Tire removed, cleaned and an inside patch glued over both holes on the inside was the end repair. That held up for the life of the tire, (~8k more miles).
    Mumbles24 likes this.
  5. heatmizr
    heatmizr n00b-tastic
    Jan 5, 2012
    1,012
    CLT, NC
    Non-preferred solution: plug both holes. Can use this just to get home or temporary fix. Or as long as you dare.
    Preferred solution: remove tire and lay a quality tire patch over the inside of Both holes. I'd think this should easily last the life of the tire.
    lithodave and Mumbles24 like this.
  6. ragtoplvr
    ragtoplvr Long timer
    Oct 18, 2007
    11,812
    central USA
    I would sticky string plug it. Never had one fail. I keep a tube of patch glue, it makes good string lubricant if the hole is tight.
    Rod
    Mumbles24, Arbolmano and JimsBeemer like this.
  7. FredRydr
    FredRydr Danger: Keep Back 300 Ft.
    Aug 16, 2005
    4,365
    Carlisle Pennsylvania USA
    Sticky plug to get home, and not too fast. Unless you like risking your neck on tossing a plug, replace the tire ASAP. You cannot treat motorcycle tires like auto tires. One must accept at the outset that motorcycle tires are very expensive when priced per mile, and punctures drive up the cost even faster.
  8. HikerDaddy
    Jun 21, 2015
    57
    Vancouver
    The bike is a 2017 and the tire is tubeless
    I ordered a new tire for $250 just to have around and my gf’s bike will need a replacement in the next month anyhow
    Not sure where to get an internal patch put in the tire locally and sure with I bought that damn plug kit I was eyeing up on Saturday
    #8
  9. heatmizr
    Jan 5, 2012
    1,012
    CLT, NC
    You might not find someone who will put an internal patch in for you, so buy a kit and do it yourself. Way more reliable than a plug, I would consider the tire pretty much new after an internal patch.
    But everybody has their own asshole, I mean opinion on here, so take it for what it's worth!
    What's up with that wierd pic? Inverted?
    Oh wow, that is an optical illusion!
    #9
    Mumbles24 and SnoDrtRider like this.
  10. 1994klr250
    1994klr250 Long timer
    Aug 16, 2007
    1,330
    Southeast michigan
    That tire has way too much life left in it to toss it because of that. If you are worried about plugging it or having a plug fail why not just put a tube in it so you can get the rest of the life out of the tire? A tube can be cheap insurance if you can't get plugs to hold air or worrying about a plug coming out at speed.
    #10
  11. The Maz
    The Maz Clueless and lost
    Feb 14, 2013
    555
    Medicine Hat , AB
    You said 2017.
    What is it? An 800 or a 700?
    Depending on that whether you can use a tube or not.
    I'm assuming it is a 700 with a mag rim.
    Not sure about 2017, but the valve is on one of the spokes previous years.
    Edit
    Just looked on the parts fiche, looks like the valve is in the normal spot centered on the rim so you could probably use a tube.
    #11
  12. heatmizr
    Jan 5, 2012
    1,012
    CLT, NC
    Inside patch seems waaay easier. Just glue it in and forget!
    Just as good are those little mushroom plugs that go in from the inside, kind of a combination between a plug and internal patch... But with two holes those might not fit so close to each other.
    #12
  13. HikerDaddy
    Jun 21, 2015
    57
    Vancouver
    Thanks for all the comments and feedback
    New tire arrives tomorrow and I’ll install it on the rim.
    the other bike has TKC’s that are getting low on tread so i’lL path the Anakee wild
    #13
  14. Tigershark48
    Tigershark48 My other BMW is a Roadster.
    Mar 18, 2017
    1,443
    West Bend, WI
    Dynaplugs are junk. Rope plugs witha Tee handle are great for cars, but I would only do an inside patch on a motorcycle tire.
    #14
    heatmizr likes this.
  15. ROAD DAMAGE
    ROAD DAMAGE Long timer Supporter
    Jun 3, 2007
    3,642
    Steamboat Springs, COLORADO
    https://teamgrandwagoneer.com/blackjack-12-pc-patch-plug-combo-6mm-stem-wrapped-style/
    Take a look at these combination plug/patch repairs. ^^^^
    I've been using these for years and they work great. :thumb
    BUT, they require breaking the wheel down to install .................. and that's not always an easy field repair depending on the bike, tire, tools, weather, etc..
    I'm currently running a tire on my GSA that I rode back home after doing a plug repair 2 states away -------- BUT, after I got it back home I broke the tire down and used one of these combination repairs. The tire had lots of meat left on it and I was a long way from home when it punctured.
    Now I get to safely use up all of the tire with confidence instead of wasting that tire.
    I go to the trouble to ream the hole out well when installing the plug and/or combination repair. I also use the reaming tool to get a good coating of rubber cement inside the puncture hole.
    This would work great for the fencing staple repair.
    With these patch/plugs, the puncture hole is both FILLED IN and COVERED OVER.
    Good luck!
    #15
  16. Dirty bike
    Dirty bike EricV
    Apr 10, 2011
    2,593
    Tupelo, MS
    For the tiny holes of the staple, a regular sticky string repair will require a lot of reaming.
    I have had good results at tire shops by going to the back and asking for an inside patch done telling the guy doing the repair that I'll pay cash and don't need a receipt.
    #16
  17. heatmizr
    Jan 5, 2012
    1,012
    CLT, NC
    So HikerDaddy, let us know which option you want with.
    #17
  18. B_C_Ries
    B_C_Ries Long timer
    Mar 15, 2013
    11,588
    Imperial Valley, California
    Being able to remve the wheel and/or tire yourself goes a very long way when you go that route
    #18
