Finally fitted Lennies Rocket Sprockets
Discussion in 'GS Boxers' started by The Other JC, Nov 12, 2010.
  1. The Other JC
    The Other JC Lurking since 2004..
    Apr 4, 2010
    272
    Brisbane, Australia
    Finally got round to installing Lennies Rocket Sprockets on my '07 1200GSA after sitting in my toolbox for that last 2 months (the sprockets that is, not me!) waiting for a warm wind free day. I do not have the luxury of an enclosed garage. :cry
    Took my time and read the following a couple of guides multiple times over.
    http://forums.pelicanparts.com/bmw-...2-lennies-cam-sprocket-replacement-101-a.html
    edit: Second link removed after site when offline.
    All in all a pleasant experience. No surprises. Took about 4 hours including lunch.
    My notes:
    For the left hand side cam chain tensioner, I just used a 15mm spanner. It was enough to loosen the bolt to undo with fingers. Rather than take it all the way out I just lifted it up and let it sit on the edge of the thread top. I did not torque this bolt back up, just made a mental note of the pressure to remove it.
    Don't forget to mark the chain where the arrow on the sprocket goes.
    I have a large torque wrench which I used to undo the sprocket bolt - a good length for plenty of leverage. I put the bike in gear and stood on the back brake, leaning over the seat to crack the bolt. Similar on right side, foot on break. Same for re-torquing. No dramas
    Following Lennies advice, after taking out the sprocket bolt, I put a screw driver into the hole as I pulled off the sprocket to stop it falling anywhere I did not want it to. At that point I put a nylon tie round and through the engine casing/sprocket/chain to stop the sprocket falling into the casing while trying to get the chain off. I did the reverse when putting the new sprocket in, only removing the nylon tie when the sprocket was back on the chain.
    To remove the chain, slide your finger over the top of the sprocket under the chain.
    Lennies sprockets must be marginally larger in diameter as the BMW sprocket came out the hole, but Lennies would not go back through the hole, had to slide them in from the front. Though side by side I could not see a difference!. Maybe a few thou differnce only!.
    The nipple on the sprocket lines up with the slot at the end of the camshaft. To align the camshaft with the nipple, get a screwdriver in the slot and turn the camshaft. Tap the sprocket on gently - its a very snug fit..
    Torque the bolt back up to 65NM. Put it all back together.
    I noticed the difference straight away just riding the bike out to the road. A low RPM smoothness. Not the jerky unpleasantness of old. Took her for a spin and gone is the low speed hesitancy. I actually struggle now to remember what the bike was like before the sprockets, but it has better pull from low revs, and rolling acceleration is better.
    Very pleased with the result. A value for money performance upgrade with positive riding results. Feels like the bike is biting at the bit to go go go at the higher speeds. Must be careful. :evil
    edits: spelling
  2. sunlinden
    sunlinden David
    May 1, 2008
    128
    Boston MA
    Thanks for the feedback. In your opinion, was it worth the money and time spent? I was thinking of getting this set next year after my warantee expires. Dave
  3. The Other JC
    Apr 4, 2010
    272
    Brisbane, Australia
    For a lazy afternoon, comparing with the money spent on other 'stuff', I would recommend it. The bike runs happily in a gear higher than normal at the lower speeds, and gives more torque where its needed. [​IMG]
    Just make sure you have the tools you need, the 15mm size bolt for the left side tensioner is not a standard size in small socket/spanner kits. I found this out the first day I started the upgrade. Good job I started on the left side (right side is 17mm). Had to put it back together to use the bike to go get the 15mm spanner.
    And if you have not already got a torque wrench, this upgrade is a good reason to get one.:lol3
    If you are not a confident mechanic, have someone help who is!.
    Also, read and understand the instructions before you start, not during the opertation.
  4. SCflyer
    SCflyer Long timer
    May 25, 2007
    1,839
    Back in NC
    Looks like a relatively low $$, higher return mod...as long as you don't drop anything down into the motor:doh . How's the fuel range, any less or about the same? Can you explain how they work? Understand basics but not to knowledgable on how some engine internals (cams and such) work. Do you have any other mods (chip, remapped) for the fuel injection or stock set-up and just added the sprockets?
  5. macxx1
    macxx1 Been here awhile
    Jul 14, 2010
    103
    Speaking from (too) many years of hot rod experience, basically the
    revised sprockets are said to "advance" the cam.
    By advancing the cam, the valve openings and closings occur
    earlier in the rotation of the engine.
    The event that has the main effect on the torque curve, in this
    case lowering the rpm at which peak torque occurs and therefore
    helping the engine make more torque at most rpms below the torque
    peak rpm, is closing the intake valve sooner after the piston is at
    bottom center and starts to rise in the compression stroke.
    Closing the intake valve sooner traps more compression pressure
    in the cylinder at lower rpm, making for the increased torque at
    lower rpms.
    It doesn't change the duration of the cam, meaning the number of
    degrees of rotation the valves are open, just makes them open
    just a little sooner and close a little sooner, with the intake valve
    closing having the greatest effect on the torque curve.
    If you "retarded" the cam/s, you'd be doing the opposite - making
    things happen a few degrees later and allowing the cylinder to fill
    more at higher rpm from the "ram" effect, or the speed and inertia
    of the inlet charge continuing to fill the cylinder longer after the
    piston starts it's climb up from the bottom of the stroke in compression.
    ROAD DAMAGE, LahodaGS and Andrew like this.
  6. The Other JC
    Apr 4, 2010
    272
    Brisbane, Australia
    I have not run a full tank through the bike yet, but by all other accounts fuel consumption is the same or better - better by running a higher gear for the same speeds.
    I also have the Accelerator Module installed, which definately tamed the bike at low revs when pulling away, it was a bit too frisky for my liking - it smoothed out the power delivery.
    I shall try removing it soon to see what difference the sprockets make in that area.
  7. Davis53
    Davis53 Been here awhile
    Apr 29, 2005
    635
    Northern California
    This is very interesting, but have the wait for the warranty,
  8. Andrew
    Andrew Optimus Primer Administrator Super Moderator
    Sep 25, 2001
    25,922
    Eastbania
    Thanks for the report, nice to hear confirmation of smoothed low-end torque. Have you taken up to max RPM? How does it feel at the top end?
    #8
  9. signit98
    signit98 Nutcase... really!
    May 6, 2008
    909
    Sun Diego, Mexifornia
    Glad my little write up was of help... you'll be VERY happy in the long run.
    I have helped many people put them in and not a single one will ever taken them out again...
    #9
  10. on2wheels52
    on2wheels52 Long timer
    Jun 14, 2006
    4,056
    northern Arkansas
    "I have a large torque wrench which I used to undo the sprocket bolt - a good length for plenty of leverage."
    I'll send you a breaker bar for the postage.
    Jim
    #10
  11. lennie
    lennie Been here awhile
    Aug 10, 2010
    184
    Melbourne, VIC
    theotherjc,
    Glad you got the sprockets installed and are happy with the result.
    That makes me happy.
    Enjoy the many miles of riding and feel free to contact me in the future.
    #11
  12. opposedcyljunkie
    opposedcyljunkie Heavyweight Boxer
    Feb 20, 2007
    4,899
    By the Lake
    Getting ready to install mine next week on my 07 12GS. Are there more detailed pictorial instructions available anywhere? This is one install I don't wanna goof-up! :ear
    Appreciate any help. Thanks.
    #12
  13. Dan Cãta
    Dan Cãta Long timer Supporter
    Jun 5, 2008
    2,336
    Cluj, Romania
    Too bad I did not take pics on the Rt I did this last time. Did not change the sprockets with aftermarket ones but the owner mounted the distribution chain 1 tooth wrong...
    Anyway, I will also do this mod in the near future. My RT seems too lazy when having my gf in the back sat + 10 tons of luggage (to be read cosmetics, small oval/round mirrors, etc.)
    Dan.
    #13
  14. J_White
    J_White should be working
    May 2, 2010
    329
    NE Mississippi
    I just got around to installing mine last week. Have about 400 miles on it since the swap. A definite improvement for the way I use the bike, thanks Lennie! Only problem was self-inflicted, got in a bit of a hurry and did not tighten left tensioner enough, had small oil leak. Took TB back off, got tensioner properly tight and all is well.
    Greatly reduced the amount of down/up/down gear shifting to keep the engine sounding happy riding in rolling hills.
    Don't know, may be peculiar to my bike, but though it pulls smoother from lower rpms, it did seem to take a little "snap" out of it that i missed after riding awhile. I am running power commander III set up pretty lean - i bumped up the low and midrange another 5 percent rich, and it responded very nicely to it. Think a dyno tune, re-mapping is in order in my case, and it will be even better.
    #14
  15. lennie
    Aug 10, 2010
    184
    Melbourne, VIC
    J_White,
    I am glad you are happy with the result.
    Saves the left foot a little work and makes walking easier after a long ride. :evil
    Opposed,
    I have the install instructions on a PDF if you email me I will send to you.
    #15
  16. opposedcyljunkie
    Feb 20, 2007
    4,899
    By the Lake
    You have sent them to me (Rico Carballo) and I've already done a successful installation. Good thing I tied the old sprocket as it almost rolled down the engine innards. Nice torque distribution, a more consistent torque curve, if you like. I don't see myself taking them off. Seems to compliment well with my BoosterPlug.
    #16
  17. lennie
    Aug 10, 2010
    184
    Melbourne, VIC
    I have 42 sets of seconds left and 34 sets of new sprockets.
    This is a post from one of the UK Boxerttrix giys in relation to his experience in using the sprockets.
    #17
  18. celticus
    celticus Long timer
    Mar 11, 2007
    1,323
    E. Tn.
    Is there a "Tools Needed" list anywhere for the Lennies Sprockets instation? I just ordered a set.
    Mark
    #18
  19. The Other JC
    Apr 4, 2010
    272
    Brisbane, Australia
    • Oetiker clamp pliers or similar for oetiker clamps on injector bodies.
    • Spark plug cap remover.
    • 16mm thin walled Spark plug socket. Anything larger than thin wall will jam in the hole - ask me how I know!!
    • 15mm spanner or stubby socket for left side cam tensioner
    • 17mm spanner or socket for right side cam tensioner.
    • Set of torx drive bits and wrench for head cover, injector, breather, and camcog removal.
    • Bar breaker/long handled lever to break the cam cog bolt hold. Its on tight!!
    • Thin screwdriver to insert through cam cog into bolt hole after bolt removal and before cog removal and zip tie attachment. This will make sure the cog does not go anywhere unexpectedly. Pull the cog off along the screwdriver shaft and attach zip tie through till it's out the casing.
    • Magic marker to mark the cam chain against cog arrow.
    • A small torch I found useful in the dim light.
    • Leave in high gear and turn rear wheel to get TDC - take both spark plugs out for this!!
    • Torque wrench for correct re-tightening of everything.
    • Patience. :wink:
    I think that is all. Its been a while
    #19
    AngusOz likes this.
  20. opposedcyljunkie
    Feb 20, 2007
    4,899
    By the Lake
    Memory's a bit fuzzy now but I don't recall the need to remove the TB tubes in doing this upgrade.
    #20
