Finding Unpaved Roads (on Google maps)
Discussion in 'Mapping & Navigation' started by baerrus, May 8, 2018.
  1. baerrus
    baerrus Adventurer
    Jan 17, 2018
    35
    San Jose, CA
    I have a long GPX track that I got from a buddy and I ran into a simple problem. How to verify which roads are paved and which are unpaved along that track. In other words, is there a way to display a google map (or perhaps other mapping source) to clearly mark unpaved roads in a different color?
  2. Yossarian™
    Yossarian™ Deputy Cultural Attaché
    Jul 9, 2007
    12,312
    the 'Ha
    You can check out your state's department of roads website. Often, they will have individual county maps that clearly show paved vs gravel vs unimproved.
  3. plumer1kt
    plumer1kt Adventurer
    Feb 11, 2015
    891
    athens,greece
    http://advrider.com/index.php?threads/openroute-service-maps.1293001/
    upload the route and you can see details for the track such as steepness and road type either on the track or as graph
  4. CapeMan
    CapeMan Dirt Duffer
    Sep 29, 2012
    365
    Prescott, AZ
    As a last resort, load the GPX file into Furkot (or something similar - maybe Google Earth will take GPXs?) and examine the track in satellite photo overlay. It's tedious but definitive 'cause you can clearly identify paved/unpaved as of the date of the photo (and most are pretty recent.) You'll have'ta color code the track yourself.
  5. baerrus
    baerrus Adventurer
    Jan 17, 2018
    35
    San Jose, CA
    That is what I have been doing but there is gotta be a better way.
  6. SRTie4k
    SRTie4k Northeast Explorer
    May 11, 2009
    1,535
    Nude Hampster
    Openstreetmap.org in Edit mode will show you paved vs unpaved, assuming that that data has been tagged on the roads you're looking at. Unpaved roads appear with a "wavy" or "jagged" border, whereas paved (or untagged) roads appear straight.
    You have to sign up as an editor to do this, which is both free and accessible with numerous pre-existing accounts (i.e. you can sign in with your Google account).
    If you scroll about halfway down the page here you can see what I mean.
    baerrus and CapeMan like this.
  7. gavmac
    gavmac Been here awhile
    May 27, 2007
    752
    Boonah, Qld, AU
    You can also see the road surface info using the "Humanitarian" layer , without needing to sign up. BTW
  8. SRTie4k
    May 11, 2009
    1,535
    Nude Hampster
    Hmm, I just checked and it doesn't show me any difference between paved/untagged and unpaved.
    #8
  9. gavmac
    May 27, 2007
    752
    Boonah, Qld, AU
    Are you using the Humanitarian layer?
    As an example : https://www.openstreetmap.org/#map=16/-28.1086/152.1267&layers=H
    This is an area about 60 Km from me, Peters Road starts as sealed from the Cunningham Hwy, then goes to gravel, then for a section past Watts Road it is sealed again and then turns to gravel before reaching Freestone Road. This is zoomed in to the 200m/500ft level. I think I found the map key available in the OSM wiki - Humanitarian layer. HTH
    #9
  10. DRTBYK
    DRTBYK All Things GPS Supporter
    Mar 26, 2003
    7,872
    47°50′15.8″N, 119°56′21.9″W
    Well, for the time being, if you have the Track showing on the map in Furkot, you can use the Google StreetView feature to see if the roads that your Track follows are highlighted by StreetView. StreetView has not mapped out very many unsealed road (Paved, Sealed, Concrete, etc.)
    #10
