First Glitch with the 1290, Suspension Error
Discussion in 'Ridiculous streetbikes with 6 CPUs and too much HP' started by Saltboxlad, Jun 9, 2019.
  1. Saltboxlad
    Saltboxlad Been here awhile
    Jan 13, 2015
    589
    Wales, UK
    Last week while in Ireland out of the blue got this:
    It did appear after a fairly long high speed dash on some pretty bumpy B roads. Anyway, turned bike off and on again and it was gone.
    Just been out on the local roads and got it again, re-cycled ignition and gone, but this time it came back after a few more miles so this time I inspected the front forks and rear shock for any leaks, none, and then I unplugged all the shock electrical plugs and re-attached. Drove home about 15 miles and it didnt come back. Ill keep an eye for now, Im hoping its just a dodgy connection, the bike did get a fair amount of rain last week, maybe it got into the plugs?
  2. CanineCombatives
    CanineCombatives the sound of inevitability
    Apr 20, 2017
    529
    GA
    One day, perhaps KTM will properly update these systems with a stable software package, but we are in year 3........
  3. Andy_L
    Andy_L Been here awhile
    Jan 5, 2018
    382
    UK
    When a bike's been fine for thousands of miles and then suddenly has a problem, I doubt it's a software problem. A bad electrical connection sounds like a good bet. Might be worth checking/cleaning up the battery connections too. Electronics can be sensitive to poor grounding I think.
    EkrebDK likes this.
  4. Saltboxlad
    Jan 13, 2015
    589
    Wales, UK
    What I'm thinking too mate, thanks. I rode through some pretty dire conditions last week.
  5. Barekat
    Barekat Looking to get dirty Supporter
    Jul 28, 2013
    3,568
    North of Toronto
    I usually add a bit of dielectric grease any time I disconnect/reconnect an electrical connection on the bike. Helps keep water out and makes removal next time easier... a bit of lube never hurts. :)
  6. Saltboxlad
    Jan 13, 2015
    589
    Wales, UK
    Yep, just done all 3 using a bit of corrosion block grease which says its Dielectric
  7. RTwo
    RTwo Been here awhile
    Apr 30, 2014
    207
    UK
    I tend to use Servisol silicone (dielectric) grease in both spray and solid.
    The spray is great for getting right into things like switches etc.
    Fairly cheap from CPC Farnell in the UK
  8. bigmadstu
    bigmadstu Adventurer
    Jan 30, 2016
    38
    UK
    Connector to the rear shock was the problem area on my bike. Since I cleaned the contacts and liberally applied dielectric grease I've had no more faults.
    #8
  9. Saltboxlad
    Jan 13, 2015
    589
    Wales, UK
    Ive had a word with my Dealer, he agrees more than likely just an iffy connection but If i take the bike over they will log on and check for any stored error codes
    #9
    Barekat and Oldschoolrocker like this.
  10. Wynnded
    Wynnded Wait....what?
    Nov 11, 2017
    274
    Rockies
    On a side note, I've never liked the abrupt bend that the wires need to make at this connector to prevent them from rubbing on the rear fender. /rant
    #10
  11. Saltboxlad
    Jan 13, 2015
    589
    Wales, UK
    So , took bike in this morning and they put it on computer, stored code was to do with inconsistant 5v feed to shock, so they also think water ingress into plug. Codes cleared so hopefully with the cleaned and greased plug that should be it, ridden 50 odd miles since and no reoccurrence. Also raised warranty for 2 front LED indicators. :thumb
    #11
  12. Saltboxlad
    Jan 13, 2015
    589
    Wales, UK
    Unfortunately, its come back and this time wont clear, also to me feels like Ive got no rebound damping at the rear. Waiting for RAC to collect bike and transport to Dealer. Oh well, 6300 miles of the most fun Ive had on a bike, just hope it aint too long to resolve
    #12
  13. Saltboxlad
    Jan 13, 2015
    589
    Wales, UK
    Well, cant fault the recovery service, 90 minutes from first phone call:
    Boo hoo, missin yer already :2cry
    #13
  14. Saltboxlad
    Jan 13, 2015
    589
    Wales, UK
    And shes back already, :D big shout out to Wayne Mounter KTM Dealer, less than 24 hour turnaround, now thats service.:ricky
    #14
    hoss1 and Soggy_1 like this.
  15. Andy_L
    Jan 5, 2018
    382
    UK
    Awesome :D Did they tell you anything about what the problem was?
    #15
  16. Saltboxlad
    Jan 13, 2015
    589
    Wales, UK
    Yep, water had got into one of the plugs going to the one of the ECU's, should have asked which one I suppose and where it is
    #16
  17. SASteve
    SASteve Been here awhile
    Aug 17, 2018
    420
    California
    Now that is some service... Nice!
    #17
