First problems with Montana - random power off
Discussion in 'Mapping & Navigation' started by OneEffinName, Jul 23, 2011.
  1. OneEffinName
    OneEffinName Been here awhile
    Nov 2, 2010
    512
    VanIsle, BC
    I have my new Garmin Montana mounted on my woods bike using the Garmin "rugged" mount - rubber mounted to my handlebars. I have about 300-400km on it - all backroads and single track. Its now starting to randomly power off. For a while it was saying "do not recognize battery" - when I have the lithium battery installed (and still on the rugged mount ?!?!). So I put in AAA cells and mounted it on the rugged mount. I would still randomly shut off.
    Back home, on the table - it of course works just fine. (grumble grumble).
    *sigh* I had these problems with my 60CSX - I was hoping the Montana could handle it better.
  2. TowPro
    TowPro Single Track Geezer
    Aug 21, 2009
    4,479
    A mixed blessing
    I have had problems with several GPS that use replaceable battery's shutting off like this. The ones that use batteries with pig tails (wire connectors) don't seem to have this problem.
    I figure the battery temporarily looses contact with the terminal. The GPS takes a shock, the battery bounces on the spring and the device looses power.
    I think my My Delorme PN40 is doing something similar when running off of Bike power (with rechargeable battery inside).
    I hit a bad bump and discover the GPS is still on, but locked up. I need to open it up, remove the battery, hold down the power button for 15-30 seconds, put the battery back in and it will work. Maybe when the battery disconnects like this the GPS receives a spike in voltage and locks up?
  3. OneEffinName
    Nov 2, 2010
    512
    VanIsle, BC
    That sounds quite plausible. I know with my 60CSX, then problem was realted to the mating connectors between the battery pack and one PCB - they are spring connectors.
    *sigh* well I'll call garmin and see what they have to say.
  4. OneEffinName
    Nov 2, 2010
    512
    VanIsle, BC
    I chatted with Garmin - they are going to send me a new rugged mount - hopefully that fixes it. I can shake the crap out of the montana, without any issues.
  5. dacrazyrn
    dacrazyrn ED RN Adventurer
    Jul 22, 2007
    496
    Greeley, CO
  6. DRTBYK
    DRTBYK All Things GPS Supporter
    Mar 26, 2003
    7,960
    47°50′15.8″N, 119°56′21.9″W
    You might request that the mod's move this over to the Montana thread.
    If I were a betting man :evil I'd bet that your battery is loose in the bat compartment. Try putting one or two wraps of electrical tape around the end closest to the contacts. This will seat the battery into position much better.
    I suppose it could be the AMPS mount but my money is still on the Battery being to loose.
    Cheers,
  7. OneEffinName
    Nov 2, 2010
    512
    VanIsle, BC
    PLEASE dont move this to the montana thread.
    What a PIA to try and find anything in there. 29 pages of numerous topics. Can you imagine if everything to do with a 60Csx was in a single thread?
    One thread per topic please!
  8. TowPro
    Aug 21, 2009
    4,479
    A mixed blessing
    I agree, I have been watching the Montana thread but it is as bad as the BRP (xr650L) thread. 25 conversations going on at one time, very hard to follow.
    Besides, you have this problem with a montana, I have had it with a Delorme PN series and an old Lowrance handheld. My buddy has some kind of problem with his garmin III?
    #8
  9. DRTBYK
    Mar 26, 2003
    7,960
    Just a suggestion - your thread - your call. It's all good.
    Cheers,
    #9
  10. OneEffinName
    Nov 2, 2010
    512
    VanIsle, BC
    Add a Garmin 60Csx to the list too.
    Although they are sending out a new rugged mount, I still think its the actual GPS unit. I am going to build a more flexible attachement for the handlebars. Right now it has three levels of rubber mounting, but is still rigid. I am going to make something that will allow the unit to move (float?) around a bit. My little dash unit on my KTM is mounted this way.
    #10
  11. OneEffinName
    Nov 2, 2010
    512
    VanIsle, BC
    It is now happening all the time. 30 second ride on the bike and it shuts down. I was able to narrow it down to the lithium battery. If I am using the lithium battery and shake the unit (a bit) it will shut off. It wont with AAA batteries. - doesn't make a difference if it has external power or not.
    I will test it out on long nasty ride this weekend. Then I'll give Garmin a ring and get a new battery.
    #11
  12. DRTBYK
    Mar 26, 2003
    7,960
    The loose Lithium Battery is a "known" issue. It has been reported here several times (see above) and to Garmin Product Support. But, please do report it for your unit - the more owners that do, the better our chance of getting batteries that actually fit correctly.
    On an up note, you did get a "free" AMPS mount out this. I have found it interesting over the last few years that Garmin's "issues" database is not that well maintained or used by the Tech Support group.
    Cheers,
    #12
  13. OneEffinName
    Nov 2, 2010
    512
    VanIsle, BC
    Thnkas for pointing out the tape post - I missed that. I will give it a shot.
    #13
  14. Pete O Static
    Pete O Static Adventure Seeker
    Apr 22, 2009
    620
    The Great White North
    Just a heads up, I called Garmin with the same issue and they immediately admitted the issue and have sent out a new battery to me.
    #14
  15. DRTBYK
    Mar 26, 2003
    7,960
    When you receive your new battery would you let us know if it is wider so that it doesn't rattle when you shake the Montana?
    Cheers,
    #15
  16. kuroda_tadayoshi
    kuroda_tadayoshi Kuroda
    May 20, 2011
    141
    Seattle, WA
    When you get the new battery, see if you can notice a difference between the two.
    I am wondering if it was a bad batch, or a manufacturing change.
    I bought my 600 direct from Garmin. I have put about 4,000 miles on the unit; many miles off-road, riding hard. I've never had it turn off on me. I am wondering if I can look forward to that problem.
    I do notice the elevation tracking is wacky.
    #16
  17. YamWOW!
    YamWOW! Been here awhile
    Oct 25, 2008
    460
    Kennewick Washington
    Mine has shut down choosing different maps a few times.
    #17
  18. DRTBYK
    Mar 26, 2003
    7,960
    I have had two shutdown's since installing v2.70 but none related to battery (fix that issue the day after it arrived).
    By the way, kuroda_tadayoshi, Setup->Display->Screen Capture->YES, works really well. :evil
    Cheers,
    #18
  19. Pete O Static
    Apr 22, 2009
    620
    Yeah I find that the "altimeter" needs calibrating regularly. I use it for tracking barometric pressure in variable elevation mode and need to calibrate it often.
    #19
  20. Motley
    Motley Lurker
    Feb 27, 2008
    3,563
    way beyond giving a damn
    FWIW my Oregon 450 shut down on me once or twice while on the power cable in the van. No notifications, it just turned itself off.
    #20
