First start in 14 years. What's that sound?
Discussion in 'Airheads' started by Slicky, Apr 8, 2021.
Tags:
  1. PaulBarton
    PaulBarton Long timer Supporter
    Apr 14, 2015
    4,090
    Seattle
    I agree...looks like floodwaters cleaned out whatever varmints had set up shop. That whole bike looks like its had a soak...including those valves which would also mean the crank...
    #21
  2. PaulBarton
    Apr 14, 2015
    4,090
    Seattle
    Why do you need a better meter to test that coil? Regardless of what the resistance reads, I'm sure you will see a nice light show if you run that in a dark garage. It needs replaced...coils can be hard to test definitively. You can test resistance and it shows bad and confirms the need to replace but it can also test within spec on resistance but fail under load. But yours has already failed the visual test so no need to go further. Replace with a known good coil.
    #22
  3. Motopsychoman
    Motopsychoman Not a total poseur Supporter
    Jun 2, 2013
    7,962
    Oaklandish
    That is the worst looking one I've seen so far. If it isn't the problem, it will become a big one very soon.
    #23
    PaulBarton likes this.
  4. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    9,097
    Test the butterfly shaft o-rings before making assumptions. I heard about this one guys cousins brother somewhere on the net who pulled the shafts and the o-rings fell apart. He had never tested them so he does not know, to this day, if they were good or bad. In the course of fixing things he made an error that brought grief. Because an o-ring falls apart whwn removed does not mean it was bad before being removed. This is counterintuitive.
    With the engine idling spray some starter fluid or carb cleaner around the shafts. If the motor speeds up the o-rings are leaking.
    I have a good coil around here somewhere for sale, cheap. You do need one. You can patch what you got by gooping it with silicone but do not ride far or in the wet.
    #24
  5. Slicky
    Slicky Adventurer
    Jun 13, 2016
    24
    MA
    Course of action now
    Ordering new ew coil and plug wires. - I'm going with the EnDuraLast 1.5 ohm, any reason to go with 0.7 ohm?
    Should I just buy a new ICM while I'm at it?
    Get the thing running again with new ignition components and start investigating the carbs more. o-ring seals, switching sides, ex.
    #25
  6. Slicky
    Slicky Adventurer
    Jun 13, 2016
    24
    MA
    Pic of the bike when I got it.
    #26
    spokester likes this.
  7. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    8,072
    Fort Collins, CO
    I wonder if something was living in the bike? Judging by the leaves in the motor grill, looks like insulation for a nest.
    #27
  8. Arktasian
    Arktasian Feelin the BMEP
    May 23, 2014
    2,220
    BC
    I think it was RT Gerbils, but they got forced out by Death Watch Beetles (of metal fatigue fame).
    #28
  9. Slicky
    Slicky Adventurer
    Jun 13, 2016
    24
    MA
    Timing and starter cover have been pulled off. No damage or nests. Large amount of crap on the "dirty" side of the air filter. Probably home to some little critter 20210228_114946.jpg
    #29
  10. Motopsychoman
    Jun 2, 2013
    7,962
    Oaklandish
    The bike is an '86. Does the ICU have the OE big aluminum heat sink attached? If so, that should be the HD ICU and I'm pretty sure that the 0.7 Ohm coil is called for. That's what I'm running these days.
    #30
  11. Slicky
    Slicky Adventurer
    Jun 13, 2016
    24
    MA
    #31
    Motopsychoman likes this.
  12. Motopsychoman
    Jun 2, 2013
    7,962
    Oaklandish
    At some point you should pull the ICU off the heat sink and apply some new heat sink paste. The ICUs can overheat and cause odd problems.
    #32
    Slicky likes this.
