First year of the immobilizer chip in the 990??
Discussion in 'Dakar champion (950/990)' started by danger_nurse, Sep 14, 2019.
Tags:
  1. danger_nurse
    danger_nurse N00basaurus?
    Jul 5, 2016
    58
    Sacramento, CA
    Hello friends,
    Getting ready to start shopping for a 990 ADV that is Pre-immobilizer chip to do a rally build. I keep reading mixed info on it being 2008 vs 2008. Can anyone tell me definitively which year they added that to the 990? Thank you thank you
    White Owl likes this.
  2. Mane
    Mane Been here awhile
    Apr 16, 2002
    863
    Guatemala
    I would say from 2009 and on, but the sure way to tell is in the dash. If it has the new style it has inmobilizer.
    Regards,
    Mane
    DirtyADV likes this.
  3. rinho
    rinho Rinho Féroce
    Jul 19, 2009
    1,760
    back in France but Soul still in North America
    I dont' have the answer but I would check EPC, ign switch and key part number.
  4. Bajageorgia
    Bajageorgia n00b
    Oct 12, 2014
    6
    I’m a new owner of a 990 so definitely not an expert. The fact that my bike came with one key led me straight into world of the immobilizer.
    It’s my understanding from some posts that ‘09 and up came with it. BUT several posts indicate p/n for 07-08 ecu is same as ‘09 and up. If I’m understanding the comments, it’s possible to load a ‘08 flash on a newer ecu and it will run without an immobilizer. Then, paste a newer set of fuel table values on the ‘08 tables and you’re all set.
    I’d like to validate this. Where is an online source to validate the part number? I’ll also need to learn tune-Ecu.
  5. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,591
    Cremona, Italy
    As @Mane said, single instrument dash bikes have immobilizer, double instrument bikes don't.
    @Bajageorgia you're correct, part number is the same. But to buy one you have to supply a VIN so that the ECU come programmed accordingly.
    With earlier versions of TuneEcu it was possible to load post-2009 maps to pre-2009 and viceversa. Now it's not allowed anymore.
    I don't know if the KTM diagnostic tool can do it.
    There's an inmate (vendors section?) that can flash the ECU to remove the immobilizer.
    tomdubz, Bajageorgia and Mane like this.
  6. Bajageorgia
    Bajageorgia n00b
    Oct 12, 2014
    6
  7. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    6,508
    West of the West, Oregon
    The 09-13 have the immobilizer. 06(euro), 07, 08 do not.
    But, the 09-up have a better head, longer valve checks and generally run better.
    Otherwise, they are pretty damn similar.
    Mane likes this.
