Fluid extractor ?
Discussion in 'The Garage' started by ozmoses, Jul 30, 2020.
  1. ozmoses
    ozmoses .
    Jul 3, 2009
    41,486
    What are you using/which would you recommend?
    :ear
    (searched, no results; merge accordingly)
  2. TripleTriples
    TripleTriples Long timer
    Feb 6, 2019
    1,346
    OH
    I've got one the tall mityvac canister sized units and the smaller syringe style. Both get used quite a bit and have held up well.
    I wish the canister had included longer tubes, but it's great otherwise.
    SmittyBlackstone likes this.
  3. AlpinaE24
    AlpinaE24 Long timer
    Nov 2, 2010
    1,166
    az
    I have the tall floor mighty-vac that holds like 15 quarts, works great for all kinds of things...used it yesterday to suck 4qts of 75w-140 gear oil out of a dana 80 rear
  4. ozmoses
    ozmoses .
    Jul 3, 2009
    41,486
    re: longer tubes- are you going into the oil sump through the dipstick?
    Out of curiosity, was the gear oil hot?
  5. AlpinaE24
    Nov 2, 2010
    1,166
    az
    Well the ambient temp was 113 outside, around 105 in the shop....but the truck hadn't been driven. Sucked it all out in about 5 minutes, I was impressed
    ydarg and ozmoses like this.
  6. TripleTriples
    Feb 6, 2019
    1,346
    OH
    Sometimes. It's great for things like transmission fluid where you don't have a drain plug and have to just drop the pan and hope for the best. On a taller vehicle, the tubes that come with the unit aren't quite long enough, but that can be fixed with a trip to the hardware store.
  7. YesRush
    YesRush Long timer
    Aug 17, 2014
    3,626
    Va
    Refrigerator icemaker/water hose works.Kinda like pex but not.
    Never stick hose in something too hot.It could collapse and get stuck in dip stick tubs.
    spokester and TripleTriples like this.
  8. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    16,381
    Silver Spring, Md
    Changing a dip stick tube is a pain but not all that hard. Either engine or trans. Of course the last time I did it was on something built in the 80's.
    #8
  9. ozmoses
    ozmoses .
    Jul 3, 2009
    41,486
    Is Mity Vac the consensus, then?
    Mostly, it's for my wife's VW- she has the oil/filter changed every 10K, I'd like to (quickly) change the oil every 5.
    #9
  10. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    37,540
    Pittsburgh PA
    I recently just used an vacuum pump and a 5 gallon gas can to suck the transmission fluid out of my van, it was crude but it worked. I am interested in other options that are out there for future projects.
    #10
  11. YesRush
    YesRush Long timer
    Aug 17, 2014
    3,626
    Va
    Best other option is pneumatic.Lots of ways for a home made unit.
    #11
  12. troidus
    troidus Long timer
    Sep 1, 2010
    47,866
    Georgia
    I had trouble bleeding trailer brakes once (had a bad leak I didn't know about), so I hooked a clear tube to a vacuum port on my car engine. I put a MityVac cup inline to reduce the chance of sucking brake fluid into the engine. Worked like a champ.
    #12
  13. tvpierce
    tvpierce Been here awhile
    Sep 5, 2011
    951
    Maine
    That's some mad MacGuyver shit right there. Brilliant!
    #13
    local1 likes this.
  14. victor441
    victor441 Long timer
    Jul 27, 2009
    2,763
    Sonoma Co., Calif.
    West Marine sells a good one and it is actually a rebadged Pela 650...have used my for years at home and on the job.
    #14
    Johann likes this.
  15. CrustyAPO
    CrustyAPO Long timer Super Supporter
    May 7, 2008
    3,362
    New York state (unfortunately)
    I use a MityVac 7201 tall unit for draining gas out of tanks, brake bleeding, transmission draining. $110 or so on Amazon. You will wonder how you ever got along without it.
    #15
  16. racer1735
    racer1735 Long timer
    Dec 30, 2005
    1,393
    Amarillo/Canyon, TX
    I purchased a Mityvac 7201 8-9 years ago when I briefly owned a Mercedes-Benz. Used it twice to change the oil. Haven't used it since and it sits in its original box next to my toolbox.
    #16
  17. GonzoMD
    GonzoMD Adventurer
    Apr 7, 2020
    50
    Temecula CA
    I have the larger mity vac non-pneumatic. It works but I would get the pneumatic one, works better in every way.
    #17
  18. Carlisja
    Carlisja A wandering soul. Super Supporter
    May 29, 2014
    776
    Fairfax Station, VA
    #18
  19. ABHooligan
    ABHooligan The Flying Mythos
    Oct 2, 2008
    1,527
    Chattanooga
    I have never used one of these, but it seems every car i own has the drain plug right over a crossmember, diff, steering rack, etc, so oil coats it, runs along it, and despite best efforts i still find oil drips days later. These go in through a dipstick hole? How long does this take? Are you guys reasonably confident they remove all the old oil?
    #19
    local1 likes this.
  20. tvpierce
    Sep 5, 2011
    951
    Maine
    Good comparison video:
    Then an update comparing the Topsider. And this one addresses your question about whether is gets as much oil as draining.
    The Reader's Digest version: for $50, get the Topsider.
    #20
    Yinzer Moto, ozmoses and Beemeup like this.
