Fluid Extractors ?
Discussion in 'The Garage' started by ozmoses, Jul 30, 2020.
  1. Coma
    Coma Long timer Supporter
    Jul 11, 2012
    2,418
    The Emerald Coast
    Sludge is not really a problem with modern engines and synthetic oil, unless it been 10’s of thousands since your last one. If you have an engine with sludge issues then underneath you go. There more I read here the more I like the idea. Although if I get a Quickjack then I could probably live with out it.....
    That’s tool whore logic for sure, but I like it.
    #41
  2. JimVonBaden
    Feb 11, 2005
    91,762
    Alexandria, VA
  3. Grreatdog
    Grreatdog Long timer Supporter
    Apr 6, 2007
    36,114
    Annapolis, MD
    I used a fluid extractor in my boat for 15 years. It had a 90 degree fitting about 0.000001" off the bottom of the boat rather than a drain plug and a tube up the front of the engine. As nearly as I could tell from peeking under the valve covers, that engine was spotless inside despite a very hard working life. No car engine works as hard as a boat engine unless you are towing a heavy trailer uphill every mile of every drive.
    #43
    showkey and JimVonBaden like this.
  4. showkey
    showkey Long timer
    Jun 25, 2007
    2,432
    Wausau
    Mercedes and many other manufacturers have used the extraction oil system for over 10 years In dealer service.
    It‘s fast, simple, no lift, no drain plug, filter is serviced from the top, 100% of the oil is removed.
    Some manufacturers design the dip stick tube to be used with an extractor.
    Good or bad news........but.......In the future we likely see the drain plugs disappear. Se the thread about plastic pans and plastic drain plugs. Same with metal oil filter witha change to element style filters. Oil filter in land fills are a concern.......element style are more friendly to recycled waste.
    As mentioned: Extraction oil changes are not new.........common on inboard boats for 70 years or more.
    I have used an extraction device for my RV for 10 years. Checked the drain plug after sucking it dry.......not a drop of oil came out. 13 qts of HOT oil in minutes with no mess. The common method is a stiff nylon tube down the dip stick tube, but the technique varies with manufacturers and models. Most are air powered vacuum pump, electric and hand pumps are common just not in a dealer. Those boats used a drill powered pump.
    Obviously this is not DIY system..........Link Mercedes dealer system:
    Mercedes Benz Dealers
    www.oilchangesystems.com
    #44
  5. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,600
    Central Ohio
    You guys got me all excited about a cool tool that I don't have yet. :clap
    Then I realized that I still have to put the car on jack stands and crawl under to change the filter, and I usually rotate tires and check brake pads while the oil is draining. So, maybe a little less mess, but not much advantage to be gained from getting an extractor. :2cry
    #45
  6. Beemeup
    Beemeup 1978 R100/7
    Sep 1, 2014
    1,428
    Washington State
    Same here, gotta go downstairs for the filter anyway. But it helps to have a floor jack and jack stands. Cordless impact driver makes short work of the panel.
    #46
  7. JimVonBaden
    Feb 11, 2005
    91,762
    Alexandria, VA
    True, extraction is only worth it if you have easy filter access, usually from the top. My last three cars are top filter cars.
    #47
  8. victor441
    victor441 Long timer
    Jul 27, 2009
    2,808
    Sonoma Co., Calif.
    True on that for my cars as I do need to use ramps to change the oil filters anyway...but an extractor still worth it IMHO as there is less mess fooling around with a drain pan, getting scalded by hot oil when I pull the drain plug, no new gasket or crush ring required etc. Also generally rotate tires and check brakes at that time too but use two floor jacks on one side at a time and don't need to bother with jack stands since I'm not getting under the car.
    #48
  9. Beemeup
    Beemeup 1978 R100/7
    Sep 1, 2014
    1,428
    Washington State
    So you're no longer a teenager? I don't believe it. You still have the smug thing down pat.
    #49
    AZbiker likes this.
  10. Beemeup
    Beemeup 1978 R100/7
    Sep 1, 2014
    1,428
    Washington State
    You need ramps to change the filters but you don't go underneath?
    #50
  11. tvpierce
    tvpierce Been here awhile
    Sep 5, 2011
    960
    Maine
    It's also handy for many other applications. ATF change: some don't even have drain plugs anymore -- and those that do are generally countersunk so they leave fluid and sediment in the pan. Power steering reservoir evacuation. Brake master cylinder evacuation. Lawn mower oil change. Fuel extraction from any vehicle. The list goes on.
    #51
    ozmoses likes this.
  12. victor441
    Jul 27, 2009
    2,808
    Sonoma Co., Calif.
    Still go underneath to change oil filters and use ramps for that...but do not when rotating tires so I don’t bother with jack stands then. I only rotate front to back so two floor jacks make that easy.
    #52
  13. Beemeup
    Beemeup 1978 R100/7
    Sep 1, 2014
    1,428
    Washington State
    I could have used one when doing the F150 tranny fluid change. No drain plug. What a mess. I did replace it with a drain plug pan because there's a filter that needed a changin.
    #53
  14. troidus
    troidus Long timer
    Sep 1, 2010
    48,225
    Georgia
    I can do the oil and filter on both of our cars without lifting them or removing the splash pans.
    #54
    ozmoses likes this.
  15. Grreatdog
    Apr 6, 2007
    36,114
    Annapolis, MD
    Oil filter is on top with our 4th gen 4Runner. It even has a ring that catches oil since the filter is vertical. It is the easiest to service vehicle I ever owned.
    Then Toyota took a big step backward with our 5th gen 4Runner. That one has a cartridge filter under the engine covered by a skidplate. :fpalm
    #55
    AZbiker and silverbandit1 like this.
  16. Coma
    Jul 11, 2012
    2,418
    The Emerald Coast
    Our 2019 Highlander has a filter cartridge easy to reach but you have to use a straw tube to drain the cartridge. One more step......
    #56
  17. Beemeup
    Beemeup 1978 R100/7
    Sep 1, 2014
    1,428
    Washington State
    The dealers were losing too much money. :1drink
    #57
  18. ian408
    ian408 Administrator Administrator Super Moderator
    Apr 12, 2003
    64,224
    Santa Clara, CA
    I have a fantastic idea for the both of you. Put each other on ignore or a moderator will.
    #58
    ydarg likes this.
  19. ian408
    Apr 12, 2003
    64,224
    Santa Clara, CA
    Both decided this wasn't an option for them. So, forced ignore it is.
    #59
    JimVonBaden and ydarg like this.
  20. silverbandit1
    silverbandit1 Adventure Dreaming..
    Jun 5, 2004
    1,667
    NorCal
    My Tacoma is easy peasy
    The Wife's 4Runner is a PIA :bash
    #60
