Fork midvalve question- and other DIY suspension tuning
Discussion in 'Dakar champion (950/990)' started by slackmeyer, Sep 5, 2011.
  1. Torque
    Torque Been here awhile
    Apr 4, 2006
    544
    San Diego
    Long travel bikes have softer rear spring
    dooby likes this.
  2. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    3,615
    North of North Plains
    Since i've posted up a few questions in this thread myself a few pages back, i'll give you all a short results update on what i did. I just got my suspension from George at Suspension 101, and it's crazy awesome now. Yes it was expensive, but so well worth it. So whatever advice that @Torque is giving out here, from my experience with his work, it's probably spot on. The only, and absolutely only thing that i think he needs to change, is to have his fork stickers made in an orange color.
    Bonnie & Clyde likes this.
  3. ThirdUncle
    ThirdUncle More will than skill Supporter
    May 11, 2010
    534
    Toronto
    Mid-summer, I replaced the OEM shock with a 990ADV unit on my 950SE, after having Rob at Lang's Off-Road install the taller spring, redo the guts, etc.
    Took it out on the Oak Ridges-Ganaraska Trails and in two minutes was laughing out loud at the bonkers difference. I could sit down! In the rough! And without rendering my spinal cord into splinters. I could roar up and down nasty boulder strewn hills at full speed like those boulders were party balloons. I also stopped airing down, running street pressures in my Tractionators. And that was pure Grrrrrr.
    Chappies, I could go faster over and through everything wet, dry, hard, soft, sandy, muddy, twisty, turny. My confidence levels smashed through the glass ceiling, or whatever that thing up there is. There wasn't one hooligan move that wasn't made 40-50% easier on the filthy beast. Even street hazards got tamed, seeing how many of Toronto's roads are more busted up than Ontario's trails.
    Except... now it's so effin tall -- guessing two inches more now -- that I tipped over a few times in trails at low speeds because there was no there there when I put a foot down. I dialed the screw down as low as I could and backed off a turn or two, but that made no meaningful diff. I've got a 32" inseam, which doesn't help. I've ordered a new one, but they're backlogged. I also just switched to new Sidi boots which are substantially lower than my old cheap but bomb- (but not water-) proof Alpinestar Tech 3s, with their amazing short man remediation treads.
    Anyone who's done this mod encountered / solved this extra question thing to their satisfaction?
    Can't really tell by looking, but here's a gratuitous porno pic with aphrodisiac to set the mood...
    MadM and Whodatschrome like this.
  4. Whodatschrome
    May 4, 2015
    3,615
    On my 950A I removed my seat cover, dished out some of the foam, then stapled the cover back on. It definitely changes the seat to footpeg distance, but at least i can get the tip toes of both my feet down now.
  5. Torque
    Apr 4, 2006
    544
    San Diego
    Did you match the additional travel in the rear by extending the travel in the forks?
  6. ThirdUncle
    May 11, 2010
    534
    Toronto
    How's your ass been holding up?
  7. ThirdUncle
    May 11, 2010
    534
    Toronto
    No. Haven't touched the forks.
  8. Torque
    Apr 4, 2006
    544
    San Diego
    Either shorten the shock or lengthen the forks. Surprised your not getting head shake. Can shorten the shock some but have secondary bottoming system that you have to be aware of. Do not want to go into that system too early.
    bananu7 and dooby like this.
  9. ThirdUncle
    May 11, 2010
    534
    Toronto
    Lengthening the forks? To make the bike even higher?
  10. Whodatschrome
    May 4, 2015
    3,615
    I stand 95% of the time. I very rarely sit. It's definitely a trade off, but i'm in good enough shape that it hasn't been an issue for me (yet).
  11. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,688
    NW Sydney, Australia
    Youre steering angle will be much sharper with the ass so high and unmatched on the front.
    Take care you dont end up in a tank slapper.
    You really need to shorten the shock or lengthen the forks to match.
    bananu7 likes this.
  12. Boianovich
    Boianovich Old and Cautious
    Jan 29, 2013
    2,470
    The 8th Dimension
    Did you set the sag at the OEM height or???
  13. ThirdUncle
    May 11, 2010
    534
    Toronto
    This is where I need to bring in @keener who helped me with the upgrade.
  14. keener
    keener Speed changes you.
    Feb 24, 2010
    2,255
    Toronto, Canada
    OEM Height for now, we will adjust it to his weight at some point.
    ThirdUncle and Boianovich like this.
  15. MadM
    MadM Dreamer Supporter
    Jun 12, 2008
    1,183
    Slovenia
    On Thursday I am finally (2y in the making :hide :fpalm ) dropping my rear shock at a shop for a well overdue service. While the shock is there, I will supply them with a 140/265 spring and washer for lengthening to "S" spec and installation of the custom shim stack.
    Shim stack that will go in is the following:
    I hope @Torque and anyone knowledgeable can make a comment on this?
    1coolbanana and bobone like this.
  16. Torque
    Apr 4, 2006
    544
    San Diego
    Happy to help but need to know the bike, the year, the travel, your weight, how fast you go, terrain. or just your intent. Do you have a racing background? Bags, passenger, your height. Do you stand or sit, etc. One size does not fit all, not even close.
  17. Torque
    Apr 4, 2006
    544
    San Diego
    Spring rates?
  18. MadM
    Jun 12, 2008
    1,183
    Slovenia
    I knew I forgot to add some more info :hide
    04 950 Adventure standard model - going for "S" spec with 265mm travel all-round
    My weight is around 70kg no gear (155lbs)
    I ride enduro/extreme enduro/some MX with my 300 2t and did Albania Rally last year on a 450, I can be fast, but I am no pro.
    Terrain (Central Europe, from Alps to sea side) mostly gravel roads with some off-road and tarmac work. I prefer better good off-road manners than road.
    Bags will be on the bike at some point for a trip once or twice a year (Enduristan Monsoon size). No racks, engine bars or similar stuff, bike is on a strict diet.
    100% alone on the bike
    Off-road I stand 95% of the time
    Spring rates will be 140 rear and 0.56 front (valving in the picture below).
    * 36 ring shim is replaced with 36x0,2 standard shim (this is an old picture)
  19. Torque
    Apr 4, 2006
    544
    San Diego
    Shock I think you are in the ballpark to get some testing done and may need some fine tuning.
    The rebound I think is a bit light. I would add a face shim or two.
    I would also maybe stiffen up the compression valve a bit. Your pretty aggressive and I think you might be cranking in the high speed to keep the shock from going too deep.
    Regarding the forks I simply do not know how to valve a standard design. I only do sprung mid for many years and completely different base design.
  20. Whodatschrome
    May 4, 2015
    3,615
    MadM, you and I are both the same weight, both have 265 suspension, both bikes have a similar diet, both are bikes see little pavement, we ride the same enduro bikes, and we probably have a similar riding style too. I wish you could test ride my ‘06 950 that Torque recently worked on. He set it up for aggressive desert riding.
