Form, function and comfort, a Frisco Chopper build
Discussion in 'Some Assembly Required' started by n8mandy, Sep 23, 2019.
  1. n8mandy
    n8mandy PadreN8
    Apr 7, 2013
    1,300
    Santa Cruz Mountains
    So, I'm going to take this:
    Into something like this:
    but with rear suspension, shocks for now, maybe softail frame for later
    These are some of the original Frisco chops, but not exhibiting all of the mods that were often done.
    The Frisco Chop, originated in the Bay Area as a 1%er bike. They had narrow bars for "white lining;" lifted King Sportster or Peanut tanks for more range, having moved the petcock to the back, the filler to the top and sometimes removing the channel to give those precious extra ounces; raised pegs and mild fork stretches, 2" or 4" over to gain clearance for corning and those sharp hill transitions.
    They were practical, not just about the look in the same way that later Choppers were.
  2. n8mandy
    n8mandy PadreN8
    Apr 7, 2013
    1,300
    I'll also use it for touring. I'm not hardcore enough to ride it all day as is. I can't take 21 Days* to get to Chicago next year.
    So I will have to add some touring things for long rides that can be take off: windshield, highway pegs, bags, comfortable travel seat, etc...
    *See what I did there :lol3
    Richy likes this.
  3. 131unlimited
    131unlimited Been here awhile
    Aug 14, 2008
    616
    Going to need to cut and rake the frame for it to look and sit right with 4" over fork tubes. 2" over you can get away with the stock rake.
    Had a '75 sporty with 4" over in front and lowered in the rear. 3.5 gall fatbobs with fabbed up mounts, Wideglide rear fender and a modified mustang seat from a superglide to get more lower back support for the long rides.
    You'll get close to the look your going for, but the new sporty frames just don't have the length, neck rake and overall layout needed to nail the way the old ones sat and rode.
  4. n8mandy
    n8mandy PadreN8
    Apr 7, 2013
    1,300
    You're right, those do looked more raked out. I'll just be going with 2" over.
    I'd love to see pics.
    villageidiot likes this.
  5. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    11,722
    Orange County, CA
    Don’t necessarily need 2” over tubes, trackerdie makes a 11” damper rod setup for the 39mm front end that you can then space down if you need depending on the stock damper rod length to get desired lift.
    cheaper than tubes, it’s $75 kit.
    johnwesley, Richy and n8mandy like this.
  6. willis 2000
    willis 2000 neo-quixote
    Oct 15, 2011
    4,823
    idaho
    Longer damper rods would reduce stanchion overlap, longer tubes would be better.
    n8mandy likes this.
  7. villageidiot
    Apr 29, 2010
    11,722
    Orange County, CA
    there’s PLENTY of stanchion overlap on the sportster and dyna.
    n8mandy likes this.
  8. 131unlimited
    Aug 14, 2008
    616
    Sorry no pics... Pls don't take this as 100% gold as it has been decades since I built my 75 sporty. The Newer sporty frames have a rake around 28 degrees. For 4" over having the rake set to 32 /33 degrees gives a good stance and decent handling for that kind of build. The 75 frame sat at 32 and it worked out really well for me, enough so that when I built my Superglide, I raked it to 33 and went 3" over on that bike as well.
    "Forks by Frank" always did me right for extended fork tubes at a good price. Best of luck with the build!
    #8
    Richy, n8mandy, AK650 and 1 other person like this.
  9. n8mandy
    n8mandy PadreN8
    Apr 7, 2013
    1,300
    So here it is basically as I bought it. I just wanted to put in my own pics instead of the cycletrader ones.
    I did add a throttle lock and cramp buster for the trip.
    I titled the build thread "form, function and comfort" because I won't be making an exact replica of a classic Frisco, due to my need for comfort for 400 mile days (I did over 300 taking the "Italian Sportster" my Guzzi V9 out to Cowtown, CA and bringing the Sporty back.)
    #9
    Dirt Road Cowboy and Richy like this.
  10. n8mandy
    n8mandy PadreN8
    Apr 7, 2013
    1,300
    I was planning on putting it on a diet today, pulling the headlight eyebrow and the belt guard off. I didn't realize that the eyebrow actually was the bracket to hold on the headlight. I also did not have the big-a$$ torx necessary for taking the belt guard off.
    So, let's play spot the difference between the pics above and these. I was the only weight lost today:
    #10
    Dirt Road Cowboy likes this.
  11. thebigman
    thebigman XR's all the way . Big Thumps or V-twins
    Jul 9, 2010
    3,902
    Texas Gulf Coast
    I'll be along for the build .. good luck :thumb
    #11
  12. n8mandy
    n8mandy PadreN8
    Apr 7, 2013
    1,300
    Alright, another lesson learned: DON'T TRUST THE INTERNET.
    Oh, right I already knew that. Actually I should say to myself, "just be more selective with your research dummy, making sure that you are sure that it applies to your bike." Wow, I even talk to myself too much.
    I planned on putting my Biltwell Frisco bars this morning and after looking up info on them, read that the brake lines are long enough with some rerouting. That would be true of Sporty's that don't have the doohickey separating the lower brake line from the upper line.
    So this is what I ended up with: frisco fail.jpg
    Yup, exactly the same after I wasted my time removing the stock handlebars. I also could have saved that time if I had just taken a look at the brake line.
    Great, another delay. :doh
    #12
  13. yokesman
    yokesman Long timer
    Sep 12, 2008
    2,237
    SW. Idaho
    seen what a kevlar fanbelt would do to a bmw, taking out all the hoses, radiator. might want to leave the guard on if not only as a deflector.
    #13
    n8mandy likes this.
  14. n8mandy
    n8mandy PadreN8
    Apr 7, 2013
    1,300
    How exactly does that work? I've never done any forks work.
    #14
  15. villageidiot
    Apr 29, 2010
    11,722
    Orange County, CA
    forks out of triples, take spring caps loose, pull axle, take out bolts from bottom of fork leg lowers (holds the tip of the damper rods.
    pull forks apart, swap short rods for long rods.
    re assemble with new seals (bushings too if needed)
    refit springs, fill it required oil level.
    run it.
    I’m sure there’s a detailed step by step here somewhere, or on xlforum
    #15
  16. n8mandy
    n8mandy PadreN8
    Apr 7, 2013
    1,300
    Geez, looking back at my question I didn't ask what I was thinking in my head at all. I meant to ask how many inches over would you get. If I'm not mistaken, the stock damper length is 9.5", so switching to 11" would get you 1.5", I was hoping for at least 2".
    Are there any other relatively inexpensive ways to get more. Is it possible to get 3" or even 4" without changing the fork tubes?
    #16
  17. villageidiot
    Apr 29, 2010
    11,722
    Orange County, CA
    It all depends on what dampers you have in your bike. You could have 7” dampers in that thing.
    from the lowest dampers to 11” is significant, just gotta figure out what you’re working with as a baseline.
    #17
    n8mandy likes this.
  18. Bt10
    Bt10 Long timer
    Dec 18, 2012
    1,108
    Saranac,MI
    Are there upper fork tube cap extensions available?
    #18
  19. villageidiot
    Apr 29, 2010
    11,722
    Orange County, CA
    fuck that noise
    #19
    humancertainty likes this.
  20. n8mandy
    n8mandy PadreN8
    Apr 7, 2013
    1,300
    why's that?
    #20
