Front brake carrier sieze
Discussion in 'Parallel Universe' started by cgguy09, Jul 24, 2020.
  1. cgguy09
    cgguy09 Scientiæ Cedit Mare
    May 25, 2010
    1,518
    Astoria, OR
    Hey team,
    I had some minor pulsing at slow stops and I've been working through the scientific methods to rule things out. I got to the point where I greased the carrier pins and I may have found my culprit.
    My front right caliber's brake carrier is seized, specifically, it's the top pin. I've been using a tire iron and WD-40 (which I hate to use on anything brake related, but I had no other choice) and the SOB will not budge. I've even marked up the caliper a little bit (cosmetic, nothing bad...staying away from the pistons).
    To be clear, the pistons are operative and clean, it's merely the carrier.
    What I've done: Tire iron to pry it (NEGRES), WD 40 In the rubber cover (NEGRES), Beat it with a rubber mallet (NEGRS).
    What am I missing? What else should I do?
    Appreciate it, team.
    -cFogs
  2. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    340
    Fannystelle
    I sure you referring to pin # 9 Had them seize a few times pull the safety clip use a small punch hammer pin out. I have tried different lubes/anti seize with little success running gravel roads it gets seized
  3. cgguy09
    May 25, 2010
    1,518
    Astoria, OR
    It’s actually part 4.... this comes in to parts, the caliper and the carrier, you need to grease the carrier pins every year or so.... I guess I haven’t.
  4. cgguy09
    May 25, 2010
    1,518
    Astoria, OR
    The pin in yellow
  5. cgguy09
    May 25, 2010
    1,518
    Astoria, OR
    Got it. Just patience, tons of PB Blaster and a rubber mallet
  6. bmwroadsterca
    bmwroadsterca RadioFlyer
    Jan 3, 2007
    993
    Lanark County near Ottawa ON
    A good habit is to lube or apply anti seize to the slider pins at every tire change. This is a very common problem.
    cgguy09 likes this.
  7. cgguy09
    May 25, 2010
    1,518
    Astoria, OR
    I was doing it every brake pad change.... but I’ve gotten good at engine braking, so it’s been about 1.5 years and 10-11k miles.
    I used white lithium grease, any concern with that impacting the rubber? I have anti-seize too... didn’t know if one was better.
  8. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    6,915
    South Jersey... Close to the Pines
    The grease can melt out of there if the brakes get hot plus it is not waterproof.... Clean it off completely and use the anti seize or Caliper Lube which is made specifically for this.
    https://shop.advanceautoparts.com/p/permatex-disc-brake-caliper-lube-20353/7160129-p
    #8
    cgguy09 likes this.
  9. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    340
    Fannystelle
    cgguy09 glad to see you got it fixed brake caliber fixed link from SnoDrtRider grease does work I use C5A anti seize I try to look at brakes every month
    #9
    cgguy09 likes this.
  10. PortugalGS
    PortugalGS Adventurer
    Apr 2, 2015
    62
    Denmead Hampshire UK
    I use a Red Rubber Grease and never a problem
    #10
    cgguy09 likes this.
