Front Brake Reservoir Leaking
Discussion in 'Hard. Core. (1090/1190/1290)' started by Kmont, Aug 7, 2020.
  1. Kmont
    Kmont Been here awhile
    Apr 9, 2014
    247
    Memphis
    I have the front brake reservoir leaking at the cap. Noticed at 700 miles on the bike just after first service. I adjusted the gasket and it seemed to fix it for awhile. It is leaking again. It blows droplets in my face at speed. I ordered a new reservoir since I cannot get just the gasket. ($32). It's a 2018 1290sar.
    Has anyone else had an issue with this? How do you like that fancy quick fix?
  2. Barekat
    Barekat Looking to get dirty
    Jul 28, 2013
    4,944
    North of Toronto
    Not that bad but my SAT use to sweet brake fluid when it was topped right up.
  3. Kmont
    Apr 9, 2014
    247
    Memphis
    There is an air gap at the top. Seems like the gasket moves a little and causes seepage. Just a little but the air flow its the seepage and blows into my face shield.
  4. spova
    spova Been here awhile
    Nov 28, 2009
    606
    PNW USA
    Maybe an aluminum res cap will help?
  5. Kmont
    Apr 9, 2014
    247
    Memphis
    I wish I would have thought about that before purchasing the new reservoir.
  6. Pipefighter76
    Pipefighter76 Been here awhile
    Apr 27, 2018
    218
    Maryland
    I just put the 2nd one on my 1090 today. I looked for an aluminum one but could only find orange. I took the 1st replacement off and cleaned it up and reinstalled it a while back and it worked for a while longer. with the rubber gasket I think I had a tendency to over tighten it. It will hold better if you don’t smash the gasket so far.
    Kmont likes this.
  7. Kmont
    Apr 9, 2014
    247
    Memphis
    I didn't think I over tightened but I am know to do so. I will double check. Thinks for the input.
  8. Antti
    Antti Been here awhile Supporter
    Mar 14, 2003
    639
    Finland
    In my ex 1190 the gasket got somehow fluid in to its ”cup” under the cap and blowed fluid from there. Just vlened the hasket and reassembled and was fine since then.
    #8
