Front caliper seized, how to rebuild master cylinder?
Discussion in 'The Garage' started by KennyFSU, Sep 25, 2019.
  1. KennyFSU
    KennyFSU Look ma, no hands
    Sep 18, 2019
    24
    Florida
    I had the caliper rebuilt by a shop recently and the front brake was working fine until yesterday when it seized up again. Shop says the master cylinder needs to be rebuilt now so I bought a rebuild kit and plan on doing it myself.
    I've seen a few YouTube videos on other bikes and it seems pretty straight-forward but I was wondering if anyone had any other tips or resources they use to rebuild one for a '91 Intruder 750, thanks all.
  2. Ducky 149
    Ducky 149 Been here awhile
    Oct 20, 2006
    933
    Roswell Jawja
    There is a really long snap ring plier that might be a MUST have tool depending on your M/Cyl. Look it up on EBay
    KennyFSU likes this.
  3. KennyFSU
    Sep 18, 2019
    24
    Florida
    Good call, just ordered a pair from Amazon, thanks.
    Ducky 149 likes this.
  4. lnewqban
    lnewqban Ninjetter
    Jan 22, 2012
    1,041
    Florida
    General but good information here:
    http://www.dansmc.com/hydraulics.htm
  5. JR356
    JR356 Long timer
    May 4, 2005
    6,973
    Way Northwest
    Just be sure it is not a collapsing aged rubber brake line,as opposed to the MC.
    JR356
    ohgood and KennyFSU like this.
  6. dddd
    dddd Long timer
    Jan 15, 2012
    1,370
    Montreal, Canada
    forgive my possible ignorance but what does a seized caliper (pistons) have anything to do with the master cylinder 3 feet above....?
    mouthfulloflake and Beezer like this.
  7. Lowndes
    Lowndes Been here awhile
    Jul 13, 2016
    115
    If your OEM type black rubber brake lines are 15 years old or older, they definitely need replacing as they are past their sell-by date. DOT4 eats paint, plastic, and those brake lines, it just takes a little longer. The front wheel on my NTM '99 BMW R1100S locked up while riding three years ago.
    After disassembling the front caliper I found decomposing brake line chunks in the galleries making a check valve, letting pressure into the pistons but not out. I replaced all the flexible brake lines and the hydraulic clutch lines with a kit from Spiegler. Galfer makes similar kits. These lines are the "braided stainless" with a clear or colored plastic coating and PTFE internal tube. It was about $200 then for the complete kit. Took maybe half a day to thoroughly clean the calipers and install and bleed everything. EZPZ if you know which way to turn a wrench.
    There seems to be two ways these old brake lines fail, one is the way mine failed (and I'd bet yours did, too), the other way as an aneurysm or big bulge and eventual burst leaving you with NO brake. It's usually the front brake lines that fail first because of the movement, steering and suspension, and the harder usage.
  8. Wentwest
    Wentwest How's that work?
    Feb 19, 2007
    3,379
    Northern California
    The other thing I learned from rebuilding old neglected bikes is that there is a very tiny sort of jet in the master cylinder that is only completely exposed when the piston of the master is fully released, and it lets pressurized fluid flow back into the master. That tiny hole is often plugged up when the caliper seems to be seized. First step is to put a tube on the bleeder of the caliper and open that bleeder to see if there's pressure in the system. With the lever released there should be none at all. If there is the problem with the lines is possible, but so is a plugged up relief port that can be cleaned out with a needle.
    #8
    tvpierce, sperz1, spokester and 3 others like this.
  9. JR356
    JR356 Long timer
    May 4, 2005
    6,973
    Way Northwest
    Forgot to add,that if your shop did not identify this as a potential issue on an older bike,time to change mechanics.
    JR356
    #9
  10. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,746
    Anchorage, formerly Spenard (hub of the universe)
    like Lowndes said in post 7.... brake lines. it was pretty common on BMWs around the Y2K years. I lost brake, had a brake seize, and had rubber crumbs contaminate and kill the ABS all due to failing lines. sounds like what your problem is to me.
    #10
    ohgood likes this.
  11. KennyFSU
    Sep 18, 2019
    24
    Florida
    Thanks for the tips, all.
    The front brake seems to work fine when left alone to cool down. After riding it for a few minutes and getting it warmed up it will seize on me again, any ideas??
    #11
  12. Lowndes
    Jul 13, 2016
    115
    KennyFSU,
    If you have the clog from decomposing brake lines like I did, YES, it will continue and get worse. What I'm afraid youre are experiencing is the "check valve" type clog. It isn't a perfect check valve and will "leak down" over time, what you are calling "cool down". But as it gets used it will take longer and longer to leak down as more junk settles in there. And you are correct, it does cool down at the same time, too.
    This is the clog in my caliper, in the junction between the caliper halves (looks like a head and shoulders sticking out):
    There was also a chunk of the same junk in the bleed nipple port:
    #12
    spokester, Beezer and KennyFSU like this.
  13. KennyFSU
    Sep 18, 2019
    24
    Florida
    Since my caliper was recently rebuilt do you think the clog could be in my MC? Someone said to check the two holes for clogs there as well. Or it could be bad brake lines. Thanks.
    #13
  14. Lowndes
    Jul 13, 2016
    115
    YES, certainly check the MC. The port is usually visible the reservoir (if the reservoir is part of the lever/MC and not a remote type) as one or two VERY small holes on top of where the MC piston is.
    Remove the reservoir cover, make sure the fluid is full, and give the lever a good, quick pull. If it squirts DOT4 straight up in the air and all over everything you're in the right place. An old Indian trick is to drop a quarter, nickel, or a washer in the reservoir to cover the holes so the DOT4 doesn't squirt out.
    Take some pics and tell us what you find.
    ALWAYS keep a windex spray bottle and a few wet rags handy when fooling with DOT4. Water cuts it and it will save your paint, plastic, windshield, etc., if you get on it quickly.
    #14
  15. Beezer
    Oct 26, 2004
    9,746
    take the line loose at the bottom and pump fluid into a container. if the line is failing you will probably see hunks of rubber
    #15
    MotoChris521 likes this.
  16. kenstone
    kenstone worn out
    Mar 3, 2013
    1,916
    Boysee
    … and pushing the caliper piston/brake pad back (with bleeder closed) will put added pressure on that bleed hole and may dislodge anything blocking it.
    This can be done a C-clamp as the caliper slides on pins and is self centering.
    If that doesn't work take a single copper strand of wire from a multi-strand electrical wire and poke it thru that bleed hole.
    This bleed hole can be found in the bottom of the reservoir, towards the back directly over the centerline of the piston and is usually chamfered/counter sunk, appearing bigger than it is but you'll need that small diameter wire to poke thru it.
    :lol3
    #16
  17. lnewqban
    lnewqban Ninjetter
    Jan 22, 2012
    1,041
    Florida
    Besides all the above, it could simply be humidity in the brake fluid.
    Easy to happen if your mechanic used fluid that had been exposed to humid air (the brake fluid is highly hygroscopic).
    In some cases, that disolved small amount of water becomes steam with the heat from the pads; the additional pressure of that steam pushes the piston(s) forward until it locks the brake, then it condensates and unlocks the pads.
    Water expands by a factor of 1600 when it turns into steam at atmospheric pressure.
    :muutt
    #17
  18. Wentwest
    Feb 19, 2007
    3,379
    Northern California
    Any of the solutions will mimic the symptoms you are reporting. I guess I'd try to clear out that pressure relief hole in the MC first, because it's the easiest and cheapest solution. Next might be to pump the MC with the bleeder open and a tube into a glass jar, and see if there's anything coming out in the fluid besides fluid. That would be a giveaway that the line is breaking down inside. You can look at the fluid after it stands for a bit to see if anything settles out.
    #18
    squish likes this.
  19. mitchxout
    mitchxout Long timer
    Jan 24, 2004
    1,983
    Asheville, NC
    Thanks for the helpful info, I recently dealt with bad brake lines on my 04 r1150r. My rear caliper pistons wouldn't retract and bleeding revealed black bits in the fluid.
    #19
    Beezer likes this.
  20. KennyFSU
    Sep 18, 2019
    24
    Florida
    Almost took a spill after a quick test ride. Removed the mc cap and nothing squirted up when squeezing the brake handle. I can’t see any debris in the bottom of the mc at all either.
    #20
