Front Shock Issues?
Discussion in 'GS Boxers' started by Zappafeld, Jul 22, 2020.
  1. Zappafeld
    Zappafeld Been here awhile
    Mar 23, 2018
    149
    Terrace, BC
    Hi,
    Anyone have issues with the front shock on the GS or GSA? I have only 50K KM on my 2018 GSA and had to have it replaced. Luckily, it was covered under the warranty, but I am hoping this doesn't happen again at 100K KM. Was like a $2000 CAD part.
  2. lewisjr1
    lewisjr1 Long timer
    Sep 26, 2008
    7,185
    DC metro
    It's a warranty repair. In the U.S. we get two years of component warranty after the replacement. No clue about you guys up North.
    My vote: worry less & ride more!
    Use that replacement shock extensively, and try to beat it up before your local warranty wears out.
  3. ExodusRider
    ExodusRider ExodusRider
    Jun 9, 2015
    2,270
    Houston, Texas
    Ultimately if it does go out and bike is out of warranty.. you can normally find lightly used ones off ebay for $200-300...
    Zappafeld and lewisjr1 like this.
  4. Zappafeld
    Mar 23, 2018
    149
    Terrace, BC
    BMW is international warranty so we will have same.
    My question was more around if it is a common repair. The guy at the shop said he has never seen one go on a GS. Which is odd, I would think it would be more likely to go on a GS than a K model. (He had seen it on a few K models that were cold-stored and moved before they warmed up.) I ride mine hard though so that may have contributed.
  5. m931a2
    m931a2 Long timer Supporter
    Oct 2, 2014
    1,226
    Austin, Texas
    As for normal? I have 48K miles on my original ones and they are fine still. Others have had them go bad much earlier.
    Wait a bit, someone will show up and tell you that they killed them faster than you :)
    If you off-road GS's a lot you will need better suspension sooner than us that are mostly on the road.
    I got used front and rear from this site for $300 with 18K miles as insurance for when mine go bad.
    Zappafeld likes this.
  6. ExodusRider
    Jun 9, 2015
    2,270
    Houston, Texas
    Easy answer:
    Uncommon but not unheard of..lol
    Actually, I hear they are normally good for about 50-65K miles if you ride it right.. or 75k-100k if you ride it like a grandpa..
    lewisjr1 likes this.
  7. lewisjr1
    lewisjr1 Long timer
    Sep 26, 2008
    7,185
    DC metro
    I most definitely ride like a grandpa. Or maybe a little ole lady!
  8. ExodusRider
    Jun 9, 2015
    2,270
    Houston, Texas
    Lmao..yeah, a mean grumpy grandpa
    #8
  9. m931a2
    Oct 2, 2014
    1,226
    Austin, Texas
    I think you mean Miss Daisy :)
    #9
  10. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    17,480
    Zer0-Zer0-Zer0-Zer0
    Shocks are considered wear-and-tear item and as such aren't meant to last indefinitely. Different riders (of different weights) riding on different roads in a different style etc etc are all contributors to how slow or fast the shocks may wear out and require replacement... :deal
    How and why your front shock failed at ~31K Mi/50K km may it's anyone's guess but that doesn't even matter as you got it replaced under the warranty.
    There are aftermarket shock solutions as replacement, which are serviceable, either using OE ESA hardware or with its own hardware so when the time comes, you can ponder the options - until then enjoy the bike and you'll worry later if or when you have to... :thumb
    #10
  11. Lead Wrist
    May 26, 2007
    17,480
    Zer0-Zer0-Zer0-Zer0
    Acchully, the warranty varies from market to market and it is all factored into the price of the bike. In Canada is I believe 3 Years Unlimited kms while in the US is 3 Years and only 36K mi ie. ~60K kms. And EU/AUS etc is all different too...
    If you bought the same bike and living in US, you'd have only ~5K mi leftover of your warranty while in Canada, you can make another 50K km within time you have remaining and be still within warranty...
    #11
  12. Rossland Rider
    Rossland Rider Been here awhile
    Jan 1, 2009
    328
    Kootenays, BC
    I had mine fail on my 2016 GSA at about 10000 km. Was warranty replacement but a PITA. It happens it seems.
    #12
  13. Mcgee
    Mcgee Been here awhile Supporter
    Aug 19, 2011
    893
    Pacific NW
    Had mine fail at 30000 miles. Replaced with Tractive. Ted Porter at the Beemershop says it is a very common problem on the GS's.
    #13
  14. jmb711
    jmb711 Been here awhile
    May 2, 2019
    147
    Northern Nevada
    Mine soiled itself at 12K miles. Sad. It of course was covered...Next winter upgrading too Wilbers from Ted porters shop.
    #14
  15. Boxerbreath
    Boxerbreath Old 'nuff to know better...
    Feb 7, 2018
    4,763
    Los Reno
    General consensus seems to say the shocks are ready for service (or replacement) at 50K so being still under warranty you did well.
    #15
  16. bikeroz
    bikeroz Long timer
    Oct 18, 2012
    2,419
    Sydney Lower North Shore
    Had a set on my '18 replaced at about 15k km.
    If it happens again, I will go aftermarket.
    #16
