    Dismiss Notice
Front wheel rimlock - is it really necessary?
Discussion in 'Thumpers' started by BuilderBob, Apr 4, 2014.
  1. BuilderBob
    BuilderBob Adventurer
    May 23, 2011
    78
    Central Florida
    Got a new KTM 500 EXC. Sweet bike. I will occasionally ride it on the road to the trails and I want to tame the drastically out-of-balance condition caused by the rimlock in the front wheel.
    In order to balance the wheel while retaining the rimlock, the rim has to be loaded up with wheel weights basically on the sides of the rim. Not only does it look bad, but I can see those weights being snatched off pretty quickly in the rough stuff.
    I'm in Florida and the trails we have are soft sand. I rarely use the front brake in those conditions because the front end will quickly wash out in the soft sand. If I do use it, it is with very light pressure on the lever. As a result, there are hardly any forces acting on the tire that would cause it to slip on the rim. My previous bike (WR250R) didn't have a rimlock in the front and it did just fine. As with the WR, I'll be running about 15 psi on the trails.
    So, with this in mind, can any members find a good argument for keeping the rimlock in place?<!-- google_ad_section_end --> <!-- / message --><!-- sig -->
  2. GBAUTO
    GBAUTO Bambi Assassin
    Sep 18, 2013
    133
    Young Harris, GA
    I added a rimlock on the KLX because I do run low pressure and encounter some steep terrain that has me on the front binder. I use wheel weights on the inner lip next to the spokes and cover the weights with duct tape. It works great and I have yet to lose a weight.
    If were me, I would forgo the possibility of losing a weight over ripping open a tube anytime.
  3. markk53
    markk53 jack of all trades... Super Supporter
    Dec 20, 2007
    19,795
    Delaware Ohio
    You will be asking yourself "why didn't I put in a rim lock!" if you ever rotate the tire and rip the stem out... The rim lock will stop that from happening, as I am sure you know, but the rim lock will also hold the tire in place if you ever get a flat and have to ride on with it flat.
    You want the weight to stay, figure how many grams or ounces, then cut a length of solder (plumbing supply) that matches that weight and wrap it around the necessary nipple/spoke, maybe silicone it in place. No thrown weight. My old flat tracker had the front wheel balanced that way - wrapped solder around a nipple/spoke.
    Forgot to mention you could distribute the weight over three or so spokes, or even put some wheel weights INSIDE the rim under the rim band.
  4. Wattner
    Wattner Long timer Supporter
    Oct 14, 2003
    7,424
    Key West, Florida
  5. ignatz72
    ignatz72 call me iggy
    Aug 6, 2010
    650
    Straight outta Memphis
    And if you're dead set on balancing the wheel with weight, try Dynabeads instead. I used them with the Motion Pro light locks on my ex-650L and this combo worked great. I use Dynabeads in all my bikes.
    I won't bother balancing the 650R wheels though.
  6. Auto-X Fil
    Auto-X Fil Been here awhile
    Feb 17, 2013
    894
    Montrose, PA.
    These are great.
    For weights, I just wrap some lead pipe around a spoke. For a dirt bike, you can get away without that:
    1) Balance the wheel alone - find the heavy spot
    2) Mount the rimlock as close as possible to opposite the heavy spot on the rim
    3) Mount the tire's heavy spot opposite the rimlock.
    This usually comes out to needing a very small amount of weight, or enough you can forget it and not mind.
  7. nevermind
    nevermind increasingly less
    Jul 26, 2008
    3,836
    duh?
    As soon as you slap on a 3oz rimlock, balancing becomes more of a necessity. YMMV, of course!
  8. Grreatdog
    Grreatdog Long timer Supporter
    Apr 6, 2007
    36,589
    Annapolis, MD
    Yep, running low air pressure on my 640E, hitting the highway to connect some trails, grabbing a big handful of front brake while coming down a hill to a stop sign and doing just that was pretty exciting. :eek1
    #8
  9. TNC
    TNC Candyass Camper
    Mar 22, 2007
    4,859
    Tejas
    Totally agree. The only way to do without a rim lock is to run high enough pressure, probably in the 18-20 range...at least. You do that, however, and the traction goes out the window. I doubt one would be riding a KTM500 in a manner that wouldn't challenge a front tire without a rim lock...or have the desire to run the pressure rock hard. I don't balance my dirt/dual sport bike tires to the finite precision that I balanced my 100-mph-plus motorcycle tires, but you usually have to add some weight to rim locked wheels for a pleasant result.
    Even the Tubliss setup that I run has a rim lock. In its case the rim lock isn't to secure the tire bead, the high pressure inner liner does that, but the lock will come into play under a full deflation...which has never happened. I use the old-school wrap-around lead weights on the spokes, but I've been tempted to try the stick-on models that attach to the rim. The old wrap-arounds are ugly and they loosen once in awhile, but they never fall off and leave the bike.
    #9
  10. BuilderBob
    May 23, 2011
    78
    Central Florida
    I like this idea.
    This is cool too. How do I figure what size I need?
    With the lightweight rim lock I should be able to reduce the amount of weights that I need. I'll be able to keep the rim lock and keep all of you happy! :D
    (I'll also avoid the possibility of having to push the bike out of the woods)
    #10
  11. bogieboy
    bogieboy Long timer
    Feb 5, 2013
    1,481
    Palmyra NY
    Why not use a second wheel lock to balance it out?
    #11
  12. StuInFH
    StuInFH Been here awhile
    May 18, 2012
    711
    Central CA
    Better safe than sorry, good protection against slipping when inadvertently at low pressure due to a slow leak during ride or worse. I use these opposite my TuBliss rimlocks and they are handy and holding tight so far. I believe the paint mark on the tire is the light spot.
    They come in pack of 1 oz. each or a pack of assorted sizes. I got one of each.
    http://www.ebay.com/itm/MOTORCYCLE-WHEEL-BALANCE-WEIGHTS-FOR-SPOKE-WHEELS-/230858915489?pt=Motorcycles_Parts_Accessories&hash=item35c0437ea1&vxp=mtr
    #12
  13. fullmonte
    fullmonte Reformed Kneedragger
    Nov 14, 2005
    7,748
    Chattanooga, Tennessee
    I use these re useable spoke weights on my bikes. They are made of brass by an ADV inmate and look great. No more sliding on the spokes or falling off.:deal
    http://advrider.com/forums/showthread.php?t=786255
    edit: Jim is the same guy as posted above. 205'd by a minute.
    #13
  14. TNC
    TNC Candyass Camper
    Mar 22, 2007
    4,859
    Tejas
    It works but is a PITA for tire installation/removal. It's not as big an issue at home in the shop, garage, or driveway, but on the side of the trail with available tools it adds to the aggravation. It does work, however, I'd rather have offsetting weight.
    #14
  15. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    15,321
    Out in the NM Dez somewhere
    Pull the tire, get some mp rim tape and a set of their weights, install the weights inside the rim in the arch between the spokes, cover with rim tape. One time deal, you don't see 'em and they don't fall off. Btw grab the lightweight rim lock at the same time like suggested.
    #15
  16. TNC
    TNC Candyass Camper
    Mar 22, 2007
    4,859
    Tejas
    Chris, that's all fine for you neanderthals still running tubes, but that won't work for the more advanced among us who are running Tubliss.
    :hide
    P.S.--Has Ev even advanced to neanderthal level yet?:lol3
    But seriously, I'd not heard of this weight design and method. Pretty clever.
    #16
  17. Grreatdog
    Apr 6, 2007
    36,589
    Annapolis, MD
    Makes sense to me as I am already running a duct tape rim strip. :lol3
    #17
  18. Beardoge
    Beardoge Been here awhile
    Aug 12, 2007
    488
    By the twin bridges
    Nope.... take it out and fill the hole with a dab of silicone ..
    #18
  19. BikePilot
    BikePilot Long timer
    Jul 5, 2005
    11,955
    Golden CO
    I've run without one and as long as you keep lots of pressure in the tire it's fine. If you air down for optimal performance in the dirt the tire will slip on the rim sooner or later. Also if you get a flat at speed it's nice to have the rim lock to keep the tire on the rim and make the bike more controllable. I'm a fan of two opposing rim locks. I use the serrated aluminum ones--pretty light and really bite into the tires.
    #19
