fuel filtration system in or below fuel cap for KTM, BMW and others
Discussion in 'Vendors' started by guglemonster, Apr 2, 2015.
  1. Oldschoolrocker
    Oldschoolrocker a.k.a. EZE Supporter
    Sep 14, 2017
    2,452
    Tacoma Wa
    Well I have got the full filter setup installed! Bike runs and no leaks. Got a bit creative on the 1290 SA T. Rerouted the oil fill tube 9892753F-39ED-432A-9E6B-F5CF5747ED1B.jpeg Moved some of the hoses and electrical around to free up fuel hose, wrap it and move it away from touching cylinder head. 8A4A725B-1ABD-4A3C-A0A0-4235DAAC68CF.jpeg New fill location. Mock up pic, actually removed screw holes now DF9127A8-7CA4-4AC3-96D2-BBD4137A10FE.jpeg The reason why? With the huge tank I needed a good place for the external filter. This is where the original oil fill tube ran. AA7D9E89-13DC-48B6-9611-EBFAF5FE92EC.jpeg Full road trip/test coming May 2nd!! Wuuhooo! Cheers!!
    guglemonster likes this.
  2. guglemonster
    guglemonster Crivens!!! Supporter
    Aug 28, 2007
    1,709
    Italy
    gorgeous work
    cheers and thank you
    Oldschoolrocker likes this.
  3. guglemonster
    Aug 28, 2007
    1,709
    Italy
    @Oldschoolrocker
    I've been thinking, the filter soooooooooo close to the engine case??? really there was no other place around ?
    boiling petrol from surrounding heat is never a good option, it will not blow, but it may give the wrong pressure and kill the engine
    can you please check for another cooler place?
    cheers
  4. Oldschoolrocker
    Sep 14, 2017
    2,452
    Tacoma Wa
    Will do! I looked at it this morning. I can give it more clearance but will also wrap it with heat protecter we use on ships for steam pipes. Should do the trick. Not to worry and thank you!!
  5. virkdoc
    virkdoc Been here awhile
    Dec 31, 2018
    135
    Chandigarh, India
    Does anyone have instructions for install on the 2018 BMW GSA.
    Just got mine today and I misplaced the instructions.
    Cant seem to find them online.
    Does the fuel filler cap needs to be unscrewed? Or is it to be inserted from the top?
  6. virkdoc
    Dec 31, 2018
    135
    Chandigarh, India
    ok I
    installed the filter in the BMW R1200GSA 2018, How deep inside to push the cap?
    I have a hunch it has not opened up inside the tank!!
  7. guglemonster
    Aug 28, 2007
    1,709
    Italy
    20-25 mm is more than enough
    it will not need to open fully, the wings are much much bigger than necessary ;)
    thanks
  8. Piston
    Piston Long timer
    Mar 4, 2007
    1,073
    Central NH
    Do you make filters that would fit the new KTM 2 strokes TPI's?
  9. guglemonster
    Aug 28, 2007
    1,709
    Italy
    Hi, well I have honestly no clue what bike it is, any pictures of the open cap? is that the 1/3 lock like the EXC ?
    is this one??
    in this case yes, the M05006-ARM is your filter :)
    thanks for your interest
    cheers
  10. guglemonster
    Aug 28, 2007
    1,709
    Italy
    and CUT !!!!!!!!!!!!!!!
    HONDA AT CRF 1000 served...... no more secrets and whatnot, plus new Guglatech strainer and obviously MAZINGA !!!!!!!!!!!
    WE ROCK AND RULE
    damn, it took forever to put back the bloody cables and the mounting back is a real PA.... almost missed the 790 CAGE !!!!!!!!!!!
    :D:D:D:D:D:D:D:D:D:D
    6000 KM.... SIX THOUSEND..... yep, petrol is clean all right in italy..... sure sure.....
    that's heavy sand and no mistake !!!!!!!!!!!!!!!!!
    :D:D:D:D:D:D:D:D:D
  11. Piston
    Piston Long timer
    Mar 4, 2007
    1,073
    Central NH
    I don’t know if it’s the same as the EXC or not but does this pic help??? It’s for a ‘19 KTM XC-W TPI.
  12. guglemonster
    Aug 28, 2007
    1,709
    Italy
    well, an opened cap would help a lot haahhaha but yes, is the M05006-ARM
    cheers
  13. guglemonster
    Aug 28, 2007
    1,709
    Italy
  14. guglemonster
    Aug 28, 2007
    1,709
    Italy
    lagging behind schedule.... sorry about that
    and done :)
    https://guglatech.it/en/products/MFPMHK
    have to go back to the prto bench... KTM 790 neck filter is coming up quite nice and funny looking
    :D:D:D:D:D:D:D
  15. guglemonster
    Aug 28, 2007
    1,709
    Italy
    KTM 690 and HUSKY 701 super MAZINGA !!!!!!!!!!!!
    Honda CRF 1000 MAZINGA
  16. guglemonster
    Aug 28, 2007
    1,709
    Italy
    small spoiler
    now we have to find the alternate mounting :)
    and obviously refueling speed, hopefully, will be pretty good
    cheers
  17. Oldschoolrocker
    Sep 14, 2017
    2,452
    Tacoma Wa
    Well my friend all is well with my external filter. Found some special fuel line heat insulation I forgot I had. Now I must say I do believe the bike runs smoother? I went one tooth bigger on the rear sprocket during fhis round of maintenance but I honestly think the engine is running and pulling way smoother!! Thank you!! I’m happy with it! D8858BDE-42CC-4DC3-BDD5-1E0DB9ACBBB0.jpeg Today was the maiden voyage. I’ll clean up the looks tommorrow off the shield. Sure arent any places to really put the filter on the “T” model. 45D28ED9-EDBB-4BBF-AA6A-5580D80FC483.jpeg
  18. guglemonster
    Aug 28, 2007
    1,709
    Italy
    much better :)
    yes, your impression is correct, the better flow improves the way the engine is using the fuel at each valve opening, thus a smoother run
    happy you are really happy with it :)
    cheers
  19. guglemonster
    Aug 28, 2007
    1,709
    Italy
    Ever been curious about the Honda fuel pump ???
    or maybe how to clean the hidden small, cigarette like ultra slim filter??
    well................ you can call yourself LUCKY that GUGLATECH is always for you THERE !!!!!!!!!!!!!!!!
    :D:D:D:D:D:D:D:D
  20. guglemonster
    Aug 28, 2007
    1,709
    Italy
    MY WORD !!!!!!!!!!!!
    I know that removing the 1xxx KTM tank is a big PA compared to the 990, but HOLY CRAP try doing it on the Honda CRF 1000 Africa Twin !!!!!!!!!!!!
    Phil, our guy in Thai has!!!!!!!!!!
    and than installed the Mazinga system, with the improved Guglatech Strainer and Mazinga pump coverall !!!!!!!!!!!!!!
    way to go
    YOU DO NOT WANT TO DO IT IN THE MIDDLE OF NOWHERE !!!!!!!!!!!!!
    Get a Guglatech neck filter !!!!!!!!!!!!!!!!
    :D:D:D:D:D:D:D:D
