Fuel Gauge Dead - Sender replaced - What I found
Discussion in 'Parallel World (790/890)' started by windblown101, Apr 12, 2021.
  1. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,134
    Star Tannery, VA
    This has been my fuel gauge for the last several thousand miles.
    I checked and had power to the fuel gauge sender. Removed the sender from the tank and the float was sliding normally inside the tube. I checked sender with an Ohm meter and was getting a range of 110 ohms to 10 ohms from full to empty. Unfortunately the repair manual doesn't provide what the expected Ohm range should be for the sender, so I ordered up a replacement.
    Finally got around to installing the new sender today and figured I'd outline the steps I took and what I found. First off, I had around a half tank of gas still so I dropped the bike onto it's side to let the gas flow to the fuel pump side then closed the transfer petcocks and picked it back up. This made for a lot less mess or having to drain the tank.
    Ready to operate.
    I pulled the sender and started making comparisons: Both senders measured the same ohm range. Both floats seemed to slide easily inside the tube. I was starting to wonder if I was barking up the right tree replacing the sender.
    Hating the idea that I had missed something I took the old sender apart.
    Dropped the float from the old sender into a container of gas. It sank like a rock. Problem found! Dang Italians...
    The float absorbed fuel and lost buoyancy. Can't blame this one on me!
    Got the new sender installed and have a working gauge again! :) A handy thing to have if I forget to set the ODO at a fill up or were to develop an unnoticed fuel leak while riding. Glad to have it back working again. I might let the old float dry out and do some reading on what I would safely coat it with to seal it and keep it as a quick replacement.
    lithodave, konam, EvilSteve and 5 others like this.
  2. ShaftEd
    ShaftEd Long timer
    Nov 6, 2001
    4,126
    San Diego, CA USA
    Thanks windblown101, very nice write up. Mine also crapped out at about 8,000 miles. Dealer blamed ethanol was killing the floats.
  3. windblown101
    May 17, 2010
    8,134
    Star Tannery, VA
    That wouldn't surprise me. I'm guessing Europe doesn't have ethanol laced gas. Quite a bit of history with them having issues with it in their bikes. On the 1190 the float would swell and jam. On some BMWs the fuel strip would crap out. Ducati had gas tanks swell from the stuff. What strikes me as odd is that after all this time they still don't seem to test their components destined for world wide sale with the stuff. Non-ethanol laced fuel is almost as rare as leaded gas in these parts.
  4. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    3,315
    Denver, CO
    Lots of way stronger chemicals in gasoline than ethanol
    comradecasey likes this.
  5. windblown101
    May 17, 2010
    8,134
    Star Tannery, VA
    True, however it's in pretty minute amounts as I recall. But sure, I reckon it could be something else in the gas causing it.
  6. wierpig
    wierpig Adventurer
    Jan 19, 2007
    61
    merseyside uk
    Europe has e10 petrol, ie 10% ethanol.In the UK its e5....for now
    windblown101 likes this.
  7. Dan D.
    Dan D. Long timer
    Mar 13, 2020
    1,296
    Jacksonville, FL
    Probably from methanol abuse.
    Fun read. You're a curious fellow.
  8. windblown101
    May 17, 2010
    8,134
    Star Tannery, VA
    The world is a curious place. I should fit right in! :)
    #8
    chippertheripper and Dan D. like this.
  9. BHoward
    BHoward Been here awhile Supporter
    May 5, 2014
    944
    Dallas, TX.
    Dang Windblown, you sure are a busy guy. 25,000 miles on the 790 and a excellent write up. Thank you.
    #9
  10. windblown101
    May 17, 2010
    8,134
    Star Tannery, VA
    Thanks. Trying to see how much abuse it will take before it cries uncle in a big way.
    I had to cry uncle for a minute but I'm just about ready for round three.
    #10
    BHoward likes this.
