Fuel strip fix?
Discussion in 'GS Boxers' started by wjrudo, Nov 29, 2012.
  1. raywilson
    raywilson Been here awhile
    Jul 31, 2011
    350
    Portland, Or
    2008 w 16k. PO had only put 10k on it in 8yrs. I've done 6k in 2. I'm sure the bike is happier now that it's being ridden
    Sent from my SM-G930V using Tapatalk
  2. Callisto224
    Callisto224 Long timer Supporter
    Jan 5, 2010
    6,046
    GA
    Meh, ...on my previous bikes I'd use my odometer to know when it's time to refill so this isn't a big deal for me.
    Chaostrophy likes this.
  3. Ronnie B!
    Ronnie B! n00b
    Jun 18, 2019
    7
    NL
    Hi, interesting post! Have you been able to run calibration procedure with this sim- tool connected? Or do you need to have calibration values in the ZFE already, before this tool turns off the yellow signal on the dashboard?
  4. Ronnie B!
    Ronnie B! n00b
    Jun 18, 2019
    7
    NL
    Is it possible to run the calibration procedure successfully with this sim connected?
  5. dad2bike
    dad2bike Retired! Cranky Old Fart Supporter
    Aug 12, 2007
    16,504
    Las Vegas, NV
    Nope. Been there done that.
  6. cjack
    cjack Been here awhile
    Nov 18, 2005
    866
    Illinois
    I've measured several broken strips and determined that the break was in the epoxy blob where the wires connect to the strip (and hidden from view). I have replaced a strip without calibration and it worked fine.
  7. Ronnie B!
    Ronnie B! n00b
    Jun 18, 2019
    7
    NL
    so the sim tool with resistors only works effectively when the zfe already contains calibration values? If yes, is there any trick to get past the calibration procedure without a real strip connected?
  8. dad2bike
    Aug 12, 2007
    16,504
    Las Vegas, NV
    Mine just shows full tank. What more are you looking for. We are just trying to kill the alarm.
    bykemike and Callisto224 like this.
  9. Ronnie B!
    Ronnie B! n00b
    Jun 18, 2019
    7
    NL
    Same goal, but with sim tool connected, the yellow alarm sign does not go away...
  10. dad2bike
    Aug 12, 2007
    16,504
    Las Vegas, NV
    I suspect the wiring of your sim. Look it over to make sure it matches one of the version posted here.
    Can you post up a pic?
    EDIT- Also I don't believe the alarm clears right at power up. It samples for a few minutes then clears.
  11. Ronnie B!
    Ronnie B! n00b
    Jun 18, 2019
    7
    NL
    33 Ohm 0,5 W serial AND parallel to get one time 33 Ohm 1 watt
    2.2k Ohm 0,5 watt
    1 Mohm 0,5 watt
    I am not getting a fault code, it just does not run through succesfull with “error during calibration”.
    With a multimeter everything seems to be ok
  12. dad2bike
    Aug 12, 2007
    16,504
    Las Vegas, NV
    So you are attempting to do the calibration on a GS-911?
    Are you getting a alarm on the Info center of the speedo? What is the fuel level showing?
    Other than that just forget about trying to calibrate.
  13. Ronnie B!
    Ronnie B! n00b
    Jun 18, 2019
    7
    NL
    it shows empty tank, fuel tank icon constantly blinking, with yellow alarm signal. I cannot get rid of the yellow light.
  14. dad2bike
    Aug 12, 2007
    16,504
    Las Vegas, NV
    Flip the assembly over. You may be plugged in in reverse
  15. dad2bike
    Aug 12, 2007
    16,504
    Las Vegas, NV
    Have you looked at the construction and soldering etc of my unit on page 10? Check it out.
    And 33 ohms may be too low of a resistance for that big one.
  16. bykemike
    bykemike "ready to navigate" Supporter
    Apr 30, 2006
    1,090
    St. Augustine FL
    This was inmate TXjames I believe. He engineered this, I built one for my 09 and it has been out of sight and out of mind for many, many miles. Cost was about zero and took an hour.
    Full tank, no alarm and, as I like to say, you drive off your trip meter as God intended. I have never missed that unreliable, tension inducing fuel strip system for one instant since I installed this. Its only purpose is to shut off the blinking yellow fuel light.
    Chaostrophy, dad2bike and motogon like this.
  17. motogon
    motogon Like wind
    Mar 23, 2005
    1,191
    Philly, PA
    Same here.
    bykemike and dad2bike like this.
  18. dad2bike
    Aug 12, 2007
    16,504
    Las Vegas, NV
    Yes that's the one I used for my unit. Later on is my post showing the construction of a sim. Like you, full tank and no alarm. I use the fuel trip meter on my Garmin. The bad things is with these rolling bricks my fuel economy can be 35-50 mpg. That's quite a spread. I set my overall fuel limit to 350 miles and then plan on gas anytime after 300. (GSA tank, 10 gallons) There have been times I've only put 7 gallons in on a refill. Here in the desert it can be quite a distance to fuel.
    bykemike likes this.
  19. dad2bike
    Aug 12, 2007
    16,504
    Las Vegas, NV
    Quoted to put the SIM within reach.
    Cheers! :thumb
  20. Ronnie B!
    Ronnie B! n00b
    Jun 18, 2019
    7
    NL
    During the calibration procedure I measure with a multimeter that the voltage is increased slowly to 6.6V and than the it stops and goes back to 0V and ends the procedure with “an error occurred during calibration”.
