Fuel strip fix?
Discussion in 'GS Boxers' started by wjrudo, Nov 29, 2012.
  1. dad2bike
    dad2bike Retired! Cranky Old Fart Supporter
    Aug 12, 2007
    16,797
    Las Vegas, NV
    I recall having some lag in display response to any fuel strip changes I had done in the past. Including the SIM fooler I put on.
    My float conversion is working fine. Although I can't speak to the accuracy of the mileage etc as I'm on a GS with a GSA tank. I'm hoping that the ECU will learn about the longer range as I go along.
  2. markherman
    markherman Louisianaman Supporter
    Apr 9, 2003
    344
    new orleans, la.
    Where did you source or buy the float fix for your set-up?
  3. dad2bike
    Aug 12, 2007
    16,797
    Las Vegas, NV
    I ended up buying a new float. GSA floats are hard to come by. GS floats are plentiful.
    That said. I already had a GS float and before installing the GSA I fabricated a GSA arm that would easily swap into place. The sender is the same with just a longer float arm.
    Back a couple pages is the links to the process.
    It requires also getting Motoscan Ultimate app as well as the OBDLink LX and BMW adapter cable. (secondary benefit. I now can turn off my TPMS when I put my dirt wheels on)
    The pictures of the rewire of the ECU connector do not do justice for how difficult that is.
    I may be doing another of these for a friend. When I do I'll take some pictures to point out the finer points of the process.
  4. boxerboy81
    boxerboy81 Stay Horizontal
    Jul 22, 2009
    4,033
    Melbourne, Oz
    Is this valid for K1200s &K1200r?
  5. FinlandThumper
    FinlandThumper Sleepy Super Moderator
    Jan 30, 2008
    15,604
    Helsinki
    As far as I know they used the same crap part in basically all the bikes in those years, so yes, it should work.
  6. Si1208
    Si1208 n00b
    Oct 7, 2019
    3
    Vers-Pont-du-Gard, France
    I have to say, this forum is an absolute mine of information. My fuel gauge packed up after a refill yesterday after being fine for the 18 months and 15,000 km since I bought the bike. I had no idea that this was such a widespread issue until Google led me here! Long story short ... the zap method worked! I was sceptical when I first read about it, but the lighter in my kitchen was running out of gas anyway, so I thought it was worth a go. Interestingly, the resistance across pins 2 and 3 was only 3,300 ohms before zapping. 3 zaps later - 2,800 ohms, another 3 - 2,600, 3 more for luck - 2,480 - that'll do. Reconnect battery, fire it up, wait 90 seconds, et voila! (as they say around here). Cost = 0 €, time = 30 minutes to adapt the zapper and 10 minutes to fix. Result :clap:clap:clap. Time will tell how long it works for, but I have my custom zapper ready for the next time. If it gets to the point that zapping no longer works, or has to be done too often, I'll go down the resistor route - I always reset my trip meter anyway.
    Thanks to all the contributors on here for saving me a chunk of euros that I can spend on more fuel :-)
    ultane and Callisto224 like this.
  7. markherman
    Apr 9, 2003
    344
    new orleans, la.
    Oh, I see you are in France. See my pm and you'll understand.
  8. Auwerda
    Auwerda n00b
    Jul 4, 2018
    2
    Netherlands
    Replaced my fuel strip by a float without reprogramming zfe but with a module between the float and bike's wiring. Video explains it all
    geewiz and ultane like this.
  9. Callisto224
    Callisto224 Long timer Supporter
    Jan 5, 2010
    7,259
    Smyrna, GA
    Well, it's been 2 or 3 years but I finally got around to making this SIM (4 actually!). I tested each one by installing them and turning the ignition on for 2 minutes. Bike reads a full tank of gas each time. Then I re-connected the bikes fuel strip and within a minute the bike went back to it's low fuel reading and warning.
    You can see in the last photo that I've ridden 186 miles on this tank and the gauge reads full.
    Thanks again @dad2bike for all your help with this! :clap
    JimVonBaden, mikegc and dad2bike like this.
  10. ultane
    ultane sqeezin the bag
    Feb 20, 2008
    2,985
    The dry side of the blood brain barrier
    I wish I could do shit like that!
  11. Carlisja
    Carlisja A wandering soul. Super Supporter
    May 29, 2014
    837
    Fairfax Station, VA
    Why did you build 4 of them.
  12. Callisto224
    Jan 5, 2010
    7,259
    Smyrna, GA
    The resistors come in packs of 4. After the first one went quickly and easily I decided to build another 3!
    It's really just 2 solder joints and some shrink wrap.
  13. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    8,353
    Zer0-Zer0-Zer0-Zer0
    So now your fuel strip issues are all resolved with your resistor hack?? :ear
  14. Callisto224
    Jan 5, 2010
    7,259
    Smyrna, GA
    Current fuel strip is still working. This was just something I wanted to try in the event BMW stops replacing them for free someday. I've also tried the bbq lighter trick (with limited success).
    ultane likes this.
  15. Exurban
    Exurban Been here awhile
    Sep 14, 2007
    928
    Wilmington, DE
    Thanks for resurrecting this. As I recall, BMW said they would replace the strip as many times as needed for twelve years from purchase. I was recently thinking about this because I just passed the twelve year mark. My third one is still working but, for who knows how much longer.
    Callisto224 likes this.
  16. leeo45
    leeo45 Longtime Lurker
    Dec 31, 2004
    322
    Lake Hartwell, SC
    Yes, pretty sure 12 years is correct. Mine failed yet again last year at 12 years and 2 months. The dealer looked it up the VIN and they would not replace it under warranty. The out-of-warranty cost was over $400 (parts+labor) for something that is likely to quickly fail* so I added the resistor hack.
    * The original strip lasted over 8 years. The replacements averaged less than 13 months, excluding the one that was DOA when I picked up the bike.
  17. Callisto224
    Jan 5, 2010
    7,259
    Smyrna, GA
  18. 40cu.in.of.furey
    40cu.in.of.furey Something clever
    Oct 24, 2007
    361
    Milton, Wisconsin
    What years did they use the fuel strip in the tank?
  19. Callisto224
    Jan 5, 2010
    7,259
    Smyrna, GA
    2005 to 2009 and some of the 2010's.
