Fuel strip fix?
Discussion in 'GS Boxers' started by wjrudo, Nov 29, 2012.
  1. Cataract2
    Cataract2 Where to?
    Jul 5, 2010
    10,123
    NH
    Good to know. Thanks for the info. Now to just see if they changed (updated) the final drive.
  2. droffsite
    droffsite n00b
    Aug 30, 2010
    3
    Finally killed off my first tank yesterday. The range counter went from being extremely optimistic to more realistic over the course of the tank. I rode about 25 miles at a time between restarts; there did seem to be some degree of recalibrating that happened each time I got back on the bike.
    After the refill, the range and gauge both seem to be working correctly. :clap
  3. GIORDINA
    GIORDINA n00b
    Feb 12, 2014
    6
    With the "zapping" technique my fuel gauge work again, thank you:clap:clap:clap.
    Greetings from Crete!!!
  4. WeazyBuddha
    WeazyBuddha Carbon-Based Humanoid Supporter
    Mar 18, 2008
    9,081
    RGV Texas
    I received the recall letter.
    Does anybody know whether the BMW dealer fix is a better solution than the zapping or do they simply replace the strip with another crappy strip?
    :ear
  5. pizzaboy
    pizzaboy Been here a little too long
    Dec 26, 2010
    2,329
    Khon Kaen, Thailand
    Replace with crappy strip
  6. hyena
    hyena Long timer
    Jan 10, 2005
    1,017
    Central Illinois #1 state for corruption
    They replace your crappy strip with another crappy strip. Six times in my case.
  7. Callisto224
    Callisto224 Long timer Supporter
    Jan 5, 2010
    7,287
    Smyrna, GA
    I'm on my 3rd crappy strip.
    The only recall letter I received was for the fuel pump inlet crack. :huh
  8. Gregg Wannabe
    Gregg Wannabe Just killing time
    Nov 10, 2003
    3,054
    San Diego
    I had my bike in for service a few weeks ago at the local BMW shop. Service writer noticed that I had paid for a fuel strip replacement a couple of years ago. He offered to contact BMW for me and see if they would reimburse me for the cost of that replacement. BMW did right by me and I ended up getting a check for ~$300.
    2008 GSA
    :clap
  9. ultane
    ultane sqeezin the bag
    Feb 20, 2008
    2,997
    The dry side of the blood brain barrier
    BMW is now said to be covering the fuel strip under warranty for 12 years IIRC.
  10. bone13
    bone13 Been here awhile
    Aug 23, 2009
    290
    Knoxville, TN
    I can confirm that.
    We've already done a few at the dealership I work at.
    There is no "Recall" on the strips.
    BMW has only extended the warranty on them. If yours fails they just replace it.
    However, DO GET THE FUEL PUMP RECALL if you havent yet. it is more than just an inspection. If your pump outlets are fine they install a reinforcement to prevent them from cracking and if they are cracked BMW replaces the entire pump assembly. It's not worth risking a fuel leak over your motor and a potential fire to put off getting it done!
  11. Jetmakerbrit
    Jetmakerbrit Cranky Flier
    Oct 31, 2012
    14
    Between SEA & YVR
    After a few years of being unreliable, my 2008 GS fuel strip finally failed completely and the yellow triangle appeared. Bike stalled while pulling away a couple of times on way home (~50 mile commute). I later read something in Haynes manual suggesting there's a limp home mode that kicks in but I've not seen anyone else mention this on the forum. I hadn't bothered trying to fix sensor before due to cost and tripometer being sufficient information (got into the habit of resetting at fill up after walking for gas a couple of times). Last night, I performed a little piezoelectric surgery (on bike with 2/3 of a tank) and the sensor now appears to have been resuscitated. The multimeter reads ~3k ohms (crappy Harbor Frieght unit) and warning light cleared itself after a minute or so. Only time will tell how temporary the fix is. I had bought a replacement sensor but I guess I can return it now or just keep it on hand. Thanks to all those that posted informative and amusing messages on this thread before me.
  12. Beecher Snipes
    Beecher Snipes Fool
    Sep 2, 2002
    875
    Mount Vernon, WA
    You know there is a 12 year warranty on those things now.
  13. edge2edge
    edge2edge Evil Scotsman
    Oct 21, 2007
    423
    Sooke, BC
    Great fix!!! Zapped my fuel strip and it is now working as it should, for how long I do not know. BMW Canada will not replace the fuel strip despite the fact that they are well aware of the problem. Frustrating as heck as the parts and labor would be over $500.00, so this described fix is the most cost effective ever for me!:deal
    Thanks all!!!:D:evil
  14. rms56
    rms56 Long timer
    Aug 25, 2013
    2,245
    Alberta, Canadia
    Can anyone tell me what the white wire is attached to on the bbq starter?
  15. NZRalphy
    NZRalphy I'm not half as good as I think I thought I was
    May 14, 2011
    1,246
    South of the North, NZ
    Yup.
    Remove the plug.
    4 pins can be seen.
    Use the two middle ones in any order.
  16. rms56
    rms56 Long timer
    Aug 25, 2013
    2,245
    Alberta, Canadia
    Got that part ... Whats it attached to on the supply end?
  17. Callisto224
    Jan 5, 2010
    7,287
    Smyrna, GA
    Is there 2 wires coming from the bbq zapper? I think one is from the center connector and the second wire is from the "outer" connector (probably a ground wire).
    Hope this helps!
  18. rms56
    rms56 Long timer
    Aug 25, 2013
    2,245
    Alberta, Canadia
    It looks like a second wire has been added to connect to the second pin. Im not sure if its a ground or simply a method to zap both pins at the same time.
  19. BikerBill
    BikerBill Motorcycle Addict
    Nov 3, 2009
    662
    Bagdad...Kentucky
    I seem to recall that BMW will continue to replace faulty fuel strips for twelve years from date of manufacture. No charge. Got that info a few months ago. Mine works but when it quits the shop can fix it under warranty.
  20. rms56
    rms56 Long timer
    Aug 25, 2013
    2,245
    Alberta, Canadia
    Taking it to the shop friday
