Fuel strip fix?
Discussion in 'GS Boxers' started by wjrudo, Nov 29, 2012.
  1. ErikMotoMan
    ErikMotoMan Airbag crash survivor!
    Apr 4, 2014
    4,486
    In Motorcycle Heaven since 1990 - So Cal!
    I'm easily entertained, but using a lighter in the vicinity of gasoline fumes?
  2. ErikMotoMan
    Apr 4, 2014
    4,486
    In getting ready to deal with a faulty fuel readout on an HP 2, I checked to see if a new fuel strip is available for this model. Imagine my surprise when I discovered the HP2 has a conventional float:
  3. bfranc
    bfranc n00b
    Sep 6, 2016
    8
    Could someone help me about the diagnostic of a faulty fuel strip in my 2008 GSA? My bike is showing empty since this spring. First time that it is not working since day one.
    I measured the resistance in the fuel level sensor strip, pins 2-3, while the bike is turned off, the tank is cca 80% full, or more. It was showing 2.91 kOhm. As far as I know, that should be a correct value. I checked the connector, seems in perfect condition.
    Zap it or search for another point of failure?
  4. mikegc
    mikegc Long timer Super Supporter
    Sep 29, 2008
    5,037
    High Point, NC
    Take it to a BMW dealer and get the free upgrade. They'll warranty it for a bunch of years . . . I think somebody said 12 years. You'll get the upgraded flange, too.
    Mike
    Callisto224, Beecher Snipes and rms56 like this.
  5. herndonp
    herndonp Metal Knees
    Feb 15, 2011
    102
    NH
    Yes take it to dealer it's still covered under an extended warranty. I have had it replaced 3 times on my 2009.
    Pete
    Callisto224 likes this.
  6. Callisto224
    Callisto224 Long timer Supporter
    Jan 5, 2010
    5,879
    GA
    Only 3?
    nOOb! :photog
  7. bfranc
    bfranc n00b
    Sep 6, 2016
    8
    Is this warranty a worldwide thing? I am in Croatia, Europe and my BMW service wants cca 200 Euros to fix it. There is a possibility they don't know about the warranty... I need something to argument with if I say I know it has warranty.
  8. bodybomber
    bodybomber Been here awhile
    May 22, 2008
    285
    Delaware
    The strip in my 08 was replaced last month and has failed once again. Is it the alcohol in the fuel that's killing them or is the upgraded part a pos too?
  9. mikegc
    Sep 29, 2008
    5,037
    High Point, NC
    A friend had his '09 replaced over a couple of years ago and it has been fine.
    Mike
  10. bfranc
    bfranc n00b
    Sep 6, 2016
    8
    Replaced in warranty?
  11. mikegc
    Sep 29, 2008
    5,037
    High Point, NC
    Yes, sir, but, more importantly, the fuel flanges were replaced, too.
    Mike
  12. Callisto224
    Jan 5, 2010
    5,879
    GA
    Warranty is only in the USA.
  13. Callisto224
    Jan 5, 2010
    5,879
    GA
    New fuel strips are the same part as the old ones. It can last 3 years or 3 weeks! I've had both. :dirtdog
    Current one is going on 3 months. We'll just have to wait and see how long it lasts!
  14. wonderings
    wonderings Long timer
    Jan 26, 2007
    1,918
    New Hamburg, Ontario
    If warranty does not cover the fuel strip do not pay to replace it as it will go again and again and again. BMW, as far as I know, has not fixed the fuel strip, they just replace it with the same strips that have been causing so many people grief over something so simple. Someone is selling a float system that is supposed to work, have not heard from anyone yet if it does indeed work as advertised
    http://hposkam.nl/en/product/bmw-vlotter-converter/
    That is the route I would be going if I still had my '10 GSA with faulty fuel strips. You are throwing money away if you pay for a new one.
    Battmo and bykemike like this.
  15. bfranc
    bfranc n00b
    Sep 6, 2016
    8
    Well... seems like more garage work on the fat cow. Sounds good.
    If I got it correctly from this link... I need to buy a BMW part 16148554065, and the 3rd party thingy BMW R1200GS Adventure TankRibbon to float converter.
    Then connect all of it. There is no talk about calibration of the new "sensor unit"? Needed, not needed?
    I suppose the "converter" is just some circuit to match the correct resistance for the computer, maybe some diodes, etc. 79 Euros for it... hm.
    Thanks for the info. Will give it a try.
  16. dad2bike
    dad2bike Retired! Cranky Old Fart Supporter
    Aug 12, 2007
    16,465
    Las Vegas, NV
    Have they resolved the shipping to the US issue with the converter yet?
  17. WOLVERINE
    WOLVERINE Keep her pinned!
    Jan 16, 2007
    666
    West of Sin City!
    I had similar issue, thought it was the strip but turned out to be corrosion on the connector at the 3pin terminal. Cleaned it carefully, applied di-electric grease and haven't had the issue since, about 3-4 years now I believe. Worth a try!
    snorty likes this.
  18. bfranc
    bfranc n00b
    Sep 6, 2016
    8
    I checked the outside connector. It is looking fine. Did you do this fix from the inside of the tank/fuel pump?
    I will open it up before ordering anything, ofcourse. For now, I am gatheting info. Never opened it before now.
  19. WOLVERINE
    Jan 16, 2007
    666
    West of Sin City!
    Outside on the pin connector. Corrosion was very minimal but the dielectric grease made the difference. Worth a try. Very easy to access.
    Sent from my SM-G930W8 using Tapatalk
  20. ultane
    ultane sqeezin the bag
    Feb 20, 2008
    2,598
    The dry side of the blood brain barrier
    Do you have a diagram of the location of the offending pin terminal?
