Fuel strip spoof results
Discussion in 'GS Boxers' started by bykemike, Jan 28, 2015.
  1. bykemike
    bykemike "ready to navigate" Supporter
    Apr 30, 2006
    1,159
    St. Augustine FL
    Bill, they are standard in the marine industry. We call them " Euro strips"
    They come in relatively long strips and you just cut what you need, stainless screws as well
    #21
  2. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    19,917
    Villa Maria Sanitarium, Claremont, CA. USA
    Chances are if you take the bike in for fuel strip warranty they will break something else on the bike and deny any responsibility.
    #22
    bykemike likes this.
  3. NJCapoNut
    NJCapoNut Dirty Boy
    Nov 8, 2004
    284
    Boiling Springs, SC
    Thanks Mike,
    I like it.......Just ordered a few.
    This is clean and will be easy to change back IF they ever design a strip that works. Otherwise the gauge useless to me.....The odometer is the only way to go IMO. I had my strip replaced and it was shot again after one tankful. Im done...Just want the triangle to stop blinking
    #23
  4. rahbert
    rahbert Adventurer
    Apr 5, 2008
    43
    Bothell, WA USA
    Why don't the suppliers just 'pre-zap' the strips prior to assembly?
    #24
  5. BendyToy
    BendyToy Adventurer
    Jun 10, 2014
    59
    I've fitted a 400mm stick type float sender unit with a separate 37mm dia digital gauge. It's a metal tube (stick) with magnetic sensors inside and a float that moves up and down to trigger the sensors. Empty is 10 Ohm. Full is 180 Ohm. It would be good to know the full to empty resistance range from a working OEM fuel strip.
    It might have a 2 MegOhm bias i.e. 2.0MO empty and 2.2MO full, but that would be too easy.
    #25
