Fuell thread
Discussion in 'Electric Motorcycles' started by djroszina, Mar 6, 2019.
  1. djroszina
    djroszina Long timer Supporter
    Jan 30, 2006
    2,771
    Midwest
    Heres another one to watch.
    X-wing fighter and motowest like this.
  2. MJSfoto1956
    MJSfoto1956 Been here awhile
    May 12, 2017
    505
    Boston, MA
  3. ctromley
    ctromley Long timer
    Oct 18, 2012
    1,180
    PA
    No, there's a disc brake on the front wheel. Brake systems always require redundancy, so a single failure doesn't leave you without brakes. If the brave new world of EMs, that might be interpreted to mean you can have a disc front and regen only on the rear, but that would depend heavily on how the regulation is written - and how NHTSA decides to implement it.
    When I was working in aircraft instrumentation it was the beginning of the glass cockpit era (computer screens instead of the traditional round or rectangular indicators). FAA regs were not written for such new-fangled movies, they were written for God-fearing needles and dials and vertical colored bars. So a lot of time was spent negotiating with FAA reps on what was acceptable. The first examples were just computer-generated representations of the old round and rectangular indicators, and even those required back-and-forth discussions with the FAA rep. The first ones in always have the hardest time getting new tech to market.
    I wouldn't be surprised if the FMVSS regs won't allow regen-only rear braking yet and Fuell will have to add a rear brake disc. They could activate it with a lever on the left bar (likely if redundancy is the issue). Does anyone know of a linked system (one actuator operating both brakes) that has redundancy built in? I'm thinking that's what Fuell would need to do to retain one-lever braking.
    Eventually, I think the FMVSS will be re-written to allow regen-only to serve the redundancy requirement for braking - IF, and only if, it can brake hard enough to lock the rear wheel, to a full stop, regardless of regen user settings. Something like a throttle that rolls back like a normal throttle, starting from a clear detent at the zero point, but also rolls forward to initiate regen to whatever level you choose in real-time.
    The now-defunct Vectrix (big electric super-scooter) patented that idea. (Even though it's been used on forklift foot throttles and earlier electric motorcycles for decades - patent law makes no sense). But Vectrix is dead now, and the patent has probably expired anyway.
  4. MJSfoto1956
    May 12, 2017
    505
    Boston, MA
    I meant brake handle. No second brake handle or foot brake either. Sorry.
  5. SteveAZ
    SteveAZ Long timer
    Sep 23, 2002
    2,418
    AZ
    Cars got one brake pedal so only one brake lever on a moto sure doesn't seem a stretch
    Roadscum likes this.
  6. MJSfoto1956
    May 12, 2017
    505
    Boston, MA
    Never ridden a bike with just one brake lever/pedal (exception being my teenage, handmade minibike). But I agree -- in theory it should be just fine.
  7. ctromley
    ctromley Long timer
    Oct 18, 2012
    1,180
    PA
    In cars the redundancy begins in the master cylinder. No reason theoretically that couldn't be done on a motorcycle, but there are no existing motorcycles that do it that way. Brake parts are sourced outside, even by the majors. I doubt Fuell wants to start developing and manufacturing their own master cylinders. They have bigger fish to fry.
    Having said that, Buell did have special large diameter rotors made up for the rim-mount brakes on his HD-powered bikes. (I wonder how easy it is to replace one of those now?)
    Doing a car-like approach on a motorcycle is also a bigger challenge because there's a much more severe shift in cg during braking, so optimum brake balance moves all over the place. The only proper way to get around that is to use ABS. Does the Flow have it?
  8. liberpolly
    liberpolly Nu, shoyn, nudnick!
    Sep 21, 2015
    6,351
    Seattle
    I cannot imagine shipping a viable contender without. But you don't really need a separate ABS on a regen-only rear motor-wheel.
    #8
  9. ctromley
    ctromley Long timer
    Oct 18, 2012
    1,180
    PA
    How do you mean? ABS maintains wheel rotation just short of lockup at speed regardless of traction conditions. How do you replicate that function without ABS using a wheel motor?
    #9
  10. MJSfoto1956
    May 12, 2017
    505
    Boston, MA
    Maybe that will be exclusive IP of Fuell? (might explain only a single brake handle)
    M
    #10
  11. liberpolly
    Sep 21, 2015
    6,351
    Seattle
    ABS does it by pulsating (turning on and off) the braking pressure. In a regen- braking wheel motor, you can regulate back force to any degree, to have it is gradually reduced as the wheel is about to lock up, so there will be no pulsation.
    #11
  12. ctromley
    ctromley Long timer
    Oct 18, 2012
    1,180
    PA
    Yes, but you still need speed sensing on both wheels and processing capability, using algorithms that are unique to this approach. And a controller that either interacts with this new, unusual system or just incorporates the whole shebang inside. Which means either building your own controller or closely collaborating with a controller manufacturer on a new platform that may have relatively low sales for awhile.
    Not to say this isn't possible. I've read from people smarter than me that TC is trivially easy to include in a controller, so this could be too. But no one (to my knowledge) has done TC in an EM controller yet, choosing off-the-shelf controllers and TC included in ABS. One has to wonder why. Maybe EMs aren't mainstream enough yet for the numbers to work out.
    #12
  13. liberpolly
    Sep 21, 2015
    6,351
    Seattle
    Yeah, software is very expensive to design but free to manufacture, so the volumes of production are critical.
    #13
  14. MJSfoto1956
    May 12, 2017
    505
    Boston, MA
    You can place a $500 downpayment on a Fuell Flow today.
    $10,995 for 11kW vs. $11,995 for 35kW (which is a bargain IMHO).
    100% regenerative braking on the rear wheel.
    30 minute charge time!
    Delivery in late 2020.
    More info here: https://fuell.us/us/flow.html
    #14
  15. MJSfoto1956
    May 12, 2017
    505
    Boston, MA
    these guys out of Taiwan seem to have a similar idea behind their hub-powered racer:
    #15
  16. ratdog
    ratdog Long timer
    Aug 15, 2004
    3,733
    Vail, CO
    Is it just me, or would the circular-F logo look better as "FYYFF"? ;-)
    #16
    discochris and wheresbaoskee like this.
  17. RockyMtnRoadRash
    RockyMtnRoadRash Useful and decorative
    Jun 20, 2006
    876
    SLC, UT
    Will legit buy this sticker.
    #17
  18. wheresbaoskee
    wheresbaoskee Perpendicular to Everything
    Aug 8, 2017
    404
    No Matter Where I Go, There I Am
    Is it weird that I kind of want a Fluid?
    #18
    MJSfoto1956 likes this.
  19. MJSfoto1956
    May 12, 2017
    505
    Boston, MA
    If I were to purchase one, I'd consider a paint job.
    Perhaps something like this:
    #19
  20. RockyMtnRoadRash
    Jun 20, 2006
    876
    SLC, UT
    It's been kinda quiet from Fuell lately. I'm getting nervous.
    #20
