Full Length Fork Guards - Recommendation?
Discussion in 'Trials' started by Greebe, Jun 27, 2018.
  1. Greebe
    Greebe Been here awhile
    Aug 6, 2010
    477
    MN
    I would like to add a set of fork guards to my 17 Scorpa Factory with Tech Forks. There are a number of guys who run the ones from Stu at Jacks Cycle which look nice. I also see that Jitsie makes one that incorporates a molded bottom to cover up the bottom of the fork as well.
    Any opinions on either of these?
    Jacks Cycles:
    Jitsie:
  2. heffergm
    heffergm Long timer
    Sep 22, 2014
    2,037
    The Jitsie's are crap. They're made of paper thin plastic, and the extra molding just gets in the way of things like taking off the front wheel. Get Stu's.
    Norman Foley and Greebe like this.
  3. Greebe
    Aug 6, 2010
    477
    MN
    Brilliant! I will order the ones from Stu. Thanks.
  4. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    12,025
    Dubuque, Iowa
    I have the Jitsie's...lol.
    Greebe likes this.
  5. heffergm
    heffergm Long timer
    Sep 22, 2014
    2,037
    I have a set too, which is how I know they're crap...
    Norman Foley, Greebe and lineaway like this.
  6. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    3,070
    Boise aria
    Also, remember for best results a wrap of tape (I like gorilla tape) around the lower sanction before applying the zip tie's will help them hold in place without turning when taking a hit. Otherwise you can get a slight spin on them and still get a scratch or chip in the upper sanction.
    Greebe likes this.
  7. Norman Foley
    Norman Foley Devotee of the Husqvarna
    Mar 20, 2004
    1,991
    New York... The Finger Lakes
    I had Jitsie on my Gas Gas and bought the same style as Stu sells, from the Tryals Shop for my Scorpa.
    Jitsie ones are junk!
    laser17 and Greebe like this.
  8. motobene
    motobene Motoing for 46 years
    Mar 9, 2013
    5,126
    Wichita Mountains SW Oklahoma
    Have had both. Stu's are tough!
    Beat the hell out of the last set of Jitses. Gashes and mashes everywhere. The bottom 3" of one side finally broke off. But heck, they lasted through a lot of events.
    The most critical thing I found was to wrap electrical tape at the top of the fork sliders, under the top zip tie, so the protectors don't rotate in a crash and expose the stanchions to that next rock.
    #8
    Norman Foley and laser17 like this.
  9. Greebe
    Aug 6, 2010
    477
    MN
    Thanks guys. I ordered a set from Stu. Hopefully they arrive before the next event, which will be a sharp rocky one.
    #9
    laser17 and jonnyc21 like this.
  10. Vincentg
    Vincentg Adventurer
    Nov 15, 2014
    16
    For the cheepscapes out there, I used some scrap 2" abs drain pipe. Half with table saw, some filing, use a piece of inner tube for a lower spacer & install with zip ties. Pretty much free. IMG_20180707_104641254.jpg
    #10
    Greebe, slicktop and mmanniko like this.
