FURKOT the Online Trip Planning Tool
Discussion in 'Mapping & Navigation' started by DRTBYK, Dec 2, 2014.
  1. DaMonk45
    DaMonk45 I B Da Monk
    Apr 26, 2009
    3,161
    Texas
    if it is a water xing I will bet it is flagged as seasonal, or goggle has just decided that water x'ings are not safe and you should never use them.
    There is a work around, Dan will be along shortlly to help more.
    Good Luck
    ohgood likes this.
  2. Cataract2
    Cataract2 Where to?
    Jul 5, 2010
    4,889
    NH
    I will certainly keep an eye out for his reply. A work around would be great.
    ohgood likes this.
  3. 919nick
    919nick Been here awhile
    Mar 12, 2009
    216
    Reidsville, NC
    You can put waypoints on either side of that section and change the route type to the UFO symbol. It will just put a straight line in that section.
    ohgood likes this.
  4. Cataract2
    Cataract2 Where to?
    Jul 5, 2010
    4,889
    NH
    What is the UFO symbol?
    Edit: Figured it out. Awesome.
    ohgood likes this.
  5. 919nick
    Mar 12, 2009
    216
    Reidsville, NC
    It changes the routing type. Click on and route segment to change it.
    ohgood likes this.
  6. Cataract2
    Cataract2 Where to?
    Jul 5, 2010
    4,889
    NH
    Hm, I don't seem to have that one available. I don't even have the air plane available. Odd.
    Edit: ok, playing with it a bit and I found it.
    ohgood likes this.
  7. DRTBYK
    DRTBYK All Things GPS
    Mar 26, 2003
    7,859
    47°50′15.8″N, 119°56′21.9″W
    Sorry guys...been on the road. But, you got it figured out. You can also use the ALTERNATE option to see if OSM data will create a route segment where you want it. Just do the same as you did for the Route type of "Other": i.e, create a Stop on each side of the area you want to route through and then select the route segment that was created and then press the ALTERNATE option.
    ohgood likes this.
  8. jlevers
    jlevers Been here awhile
    Aug 3, 2016
    353
    Western Massachusetts
    Sorry if this has already been covered, but I'm trying to export my Furkot trip in such a way that it preserves the route completely -- e.g., snaps to roads the same way I see it when I'm actually using Furkot. All the export methods that I've tried thus far haven't been as exact as I'm looking for. Any suggestions?
  9. DaMonk45
    Apr 26, 2009
    3,161
    Texas
    a lot of that will depend on what you are impoting it into.
  10. jlevers
    Aug 3, 2016
    353
    Well, I'm hoping to export it to a file type that can be viewed on my phone. I know basically nothing about how GPSs work, so I'm hoping what I'm trying to do is possible. I was viewing the GPX file on Locus...and when I try to download the type of GPX they say is compatible with newer Garmins (just doing that to give all the export options a try), the download fails :dunno
  11. DaMonk45
    Apr 26, 2009
    3,161
    Texas
    ok..you say the download fails.....that means that you cannot get your file to your phone?
  12. jlevers
    Aug 3, 2016
    353
    Correct...I've tried different browsers and different computers, and each time it says "Download failed -- Network error." I don't think it's my home network as I've never had issues downloading anything before.
    Edit: if I try to "resume" the download, the error message changes to "Download failed -- Server error."
  13. DRTBYK
    Mar 26, 2003
    7,859
    First, you should only be using the GPX export option. Then I suggest that you only select Tracks to the left of the GPX option.
    You want this on your phone but you say you have used "different computers " so which is it? What phone operating system are you using? What browsers have you tried: computer and mobile?
  14. jlevers
    Aug 3, 2016
    353
    Sorry if what I said was unclear -- I mean that I'm trying to download the file on my computer (both laptop and desktop, using both FireFox and Chrome) and then move it to my phone so that I can import it into a navigation app like Locus. I have an Android phone.
  15. DRTBYK
    Mar 26, 2003
    7,859
    I would suggest that you just use your phone. Open Furkot using one of those browsers on your phone and Export your Trip using the GPX - Tracks options. Your browser should ask you what Application you want to open the file in...select Locus.
  16. jlevers
    Aug 3, 2016
    353
    The thing is that when I do that, the route is no longer snapped to roads as it is in Furkot, even if I up the number of waypoints per route.
  17. DRTBYK
    Mar 26, 2003
    7,859
    Then use GPX Routes as your Export option. I am not familiar with Locus enough to suggest how it imports Routes but that is what you are saying you want.
  18. Tiger993
    Tiger993 Been here awhile
    Oct 24, 2014
    220
    St. Michael, MN
    Here's how I use Furkot with Locus Pro:
    1. When exporting from Furkot, check the "tracks" tickbox and in the file format side, select GPS exchange file (.gpx). Leave the "routes" tickbox unselected.
    2. After the file is exported, I put it into a designated folder on DropBox that I previously instructed Locus to connect to.
    3. Launch Locus and use the import tool to import the file from DropBox into the Locus app.
    With these steps, you are importing a track, not a route. Locus can then create a route for you if you want, which is what I do if I'm traveling on actual roads, as opposed to off-road.
    DRTBYK likes this.
  19. jlevers
    Aug 3, 2016
    353
    Huh, I'm not having much luck with that either. Sorry if I'm clogging up the thread here...I've tried everything you guys have suggested, and it's just not working for me. The track is still very rough after trying the different things you all have suggested...I may just be doing something dumb when trying to get the GPS apps I'm using (I've tried both Locus and OSMAnd) to snap the rough track to roads.
    I also tried decreasing the daily mileage and travel time as much as possible in Furkot, as well as increasing the number of waypoints per track as much as possible, to get the most waypoints per mile I could. However, then I again get "Download failed -- Server error." I'll keep trying, and thanks for all the help!
  20. Cataract2
    Cataract2 Where to?
    Jul 5, 2010
    4,889
    NH
    I am attempting to download a fairly large loop that goes around Wyoming For an upcoming trip and my download is failing. I get to about 1.8 mb and the download just fails. Is there a limit on how much you're allowed to download or how big a route can be?
