Fuse box connectors' replacement
Discussion in 'Dakar champion (950/990)' started by gefr, Dec 10, 2019.
  1. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,044
    East Med, Greece
    Hello there,
    I wanted to replace some lines that have worn. I need to replace the connectors at the fusebox. I found some spare parts in Aliexpress but am not sure what type are out connectors. Anybody have a clue?
    https://www.aliexpress.com/item/32838546020.html?spm=a2g0s.8937460.0.0.36e62e0eEgGguE
    https://www.aliexpress.com/item/1772734395.html?spm=a2g0s.8937460.0.0.36e62e0eEgGguE
    https://www.aliexpress.com/item/32900502784.html?spm=a2g0s.8937460.0.0.36e62e0eEgGguE
    https://www.aliexpress.com/item/33002564131.html?spm=a2g0s.8937460.0.0.36e62e0eEgGguE
    Any of these?
    Cheers
    mountaincadre likes this.
  2. Mane
    Mane Been here awhile
    Apr 16, 2002
    842
    Guatemala
    Following... :ear
  3. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,110
    Mill Spring, NC
    I've been down this road with no real answer.
    https://advrider.com/f/threads/fuse-block-contacts.1372497/
    None of the contacts you posted will work properly. You may be able to get them to go into the fuse block but they won't be held in place. The nub on the back clicks into the fuse block and the ears on the front are locked in by the yellow keeper.
    My solution was to buy one of these, https://www.delcity.net/store/ATC-&...0P8gZrZIjQbVl2Z5PjCLniGskKQVwWkxoCEi4QAvD_BwE , and rob a couple connectors. They are spade connection not crimp like the OEM.
  4. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,044
    East Med, Greece
    Is this photo you posted the OEM connector? or the one you robbed?
  5. Boatman
    Mar 9, 2005
    14,110
    Mill Spring, NC
    Thats the connector I robbed. Has a spade instead of the crimped end. I inserted the connector into the fuse block and put a female spade on the wire. Im not crazy about the double connection but it works.
  6. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,044
    East Med, Greece
    78817503_455623161820414_6661660104783298560_n.jpg 79728126_440762793511438_2588558454083813376_n.jpg 79208887_439909446696268_9109601621653848064_n.jpg 79099815_456893991693432_1802158519235903488_n.jpg 79144851_544570793064249_4971351063740284928_n.jpg 78728491_584581925419433_6579289340784934912_n.jpg 78806105_2443150515938835_5516791247244623872_n.jpg 78817503_455623161820414_6661660104783298560_n.jpg 79728126_440762793511438_2588558454083813376_n.jpg 79208887_439909446696268_9109601621653848064_n.jpg 79099815_456893991693432_1802158519235903488_n.jpg 79144851_544570793064249_4971351063740284928_n.jpg 78728491_584581925419433_6579289340784934912_n.jpg 78806105_2443150515938835_5516791247244623872_n.jpg
    Spyrious likes this.
  7. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,044
    East Med, Greece
    the contacts are held in place with the yellow stripe that slides out from the side. It has a pin to keep it from sliding out freely. Now I need to find contacts.
  8. Boatman
    Mar 9, 2005
    14,110
    Mill Spring, NC
    Good luck. Even my Hella distributor that has gotten me some obscure things over the years had no luck. Just to add some info that fuse block even though sold as a Hella part is actually made by and Italian company..... MIA
    Let us know if you come up with anything.
    CORRECTION...... MTA,,, NOT MIA
    #8
    dooby likes this.
  9. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,044
    East Med, Greece
    #9
    Boatman likes this.
  10. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,044
    East Med, Greece
    Could it be the Italian company is MTA?
    #10
    Boatman likes this.
  11. LilYoda
    LilYoda Been here awhile
    May 20, 2013
    244
    #11
  12. Boatman
    Mar 9, 2005
    14,110
    Mill Spring, NC
    Sorry,,, yes I just checked my notes. MTA is correct.
    #12
  13. Boatman
    Mar 9, 2005
    14,110
    Mill Spring, NC
    #13
  14. Boatman
    Mar 9, 2005
    14,110
    Mill Spring, NC
    #14
  15. LilYoda
    May 20, 2013
    244
    You sure? I don't see the difference between this (from gefr post)
    And this (zoom from kojaycat's webpage)
    Missing an ear on the bottom, you think?
    EDIT: can't show both pics on the same post, not sure why
    #15
  16. Boatman
    Mar 9, 2005
    14,110
    Mill Spring, NC
    Yes positive. Needs the locking ears that the pen is pointing to....
    #16
  17. Boatman
    Mar 9, 2005
    14,110
    Mill Spring, NC
    Just did some more Googling and it seems that is the closest.
    Also I think I came across the MTA part number for the connectors..... MTA 01.00655 or MTA 01.00655/10
    #17
  18. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,044
    East Med, Greece
    I bought some. Part No: 11.07900 - MTA, Terminal Fuseholder Sealed
    I need to test their fitment.
    Cheers.
    #18
    dooby likes this.
  19. Boatman
    Mar 9, 2005
    14,110
    Mill Spring, NC
    Did they fit correctly?
    #19
  20. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,044
    East Med, Greece
    Sorry, didn't test them yet.
    The funny thing is I paid three times their cost for shipment with courrier service and found out they shipped them from a warehouse in my city.
    Damn.
    #20
