Galileo (guru gps) App
Discussion in 'GPS 101 - Which GPS For Me' started by mosey.levy, May 13, 2018.
  1. mosey.levy
    mosey.levy Long timer
    Jul 13, 2013
    2,473
    NYC
    Not sure how android works but with iOS yes. Assuming android is the same.
    You can even sync the data to the cloud so each device is the same.
    #41
    i4bikes likes this.
  2. i4bikes
    i4bikes Been here awhile
    Apr 16, 2007
    668
    One more question, what version are you using?
    #42
  3. 919nick
    919nick Been here awhile
    Mar 12, 2009
    268
    Reidsville, NC
    Yes. I've got it on two Android devices and syncing between them.
    Sent from my Pixel 2 using Tapatalk
    #43
  4. PineLaneRider
    PineLaneRider Long timer
    Dec 25, 2016
    1,284
    Between Michaux and Tuscarora State Forests
    ^^ Just installed on another phone for back up. All tracks, etc. synced in. Had to download maps.
    #44
    ohgood and i4bikes like this.
  5. scootertrog
    scootertrog Jedi Fart Master
    Mar 26, 2011
    1,304
    Missouri USA
    A couple things to double-check, just in case you haven't tried:
    1. Turn the iPhone's display brightness up to "full".
    2. Experiment with the different color options when you select your Track or Route.
    #45
  6. GCecchetto
    GCecchetto Long timer Supporter
    Jun 29, 2013
    2,987
    Woodside CA
    I’m running on an iPad mini, soon to be a Samsung Tab Active2, but yes, screen is full bright, and I’ve played with the track colors.
    #46
  7. mosey.levy
    Jul 13, 2013
    2,473
    NYC
    And text size!
    I found Galileo to be less refined on the android side. Small details.
    #47
  8. mosey.levy
    Jul 13, 2013
    2,473
    NYC
    Curious to hear how that works for you. Post photos of it mounted and let us know how it compares to iOS.
    #48
  9. GCecchetto
    Jun 29, 2013
    2,987
    Woodside CA
    From a usage standpoint, I'll probably prefer the ipad. Where the Tab Active2 excels is that that it's mil spec rated. Dustproof, waterproof (30 minutes at 5'), shock proof, takes extreme temperatures (so no shutting down in the sun like the ipad), glove friendly screen mode, so just a much better piece of kit for an adventure bike. The screen is shitty resolution though, only 1280x800. I'll report back once i have it in hand, which should be by Friday. RAM mount is slo to ship, so I probably won't get the parts to mount it on the bike until next week though.
    #49
  10. Tabbi
    Tabbi Adventurer
    Jan 22, 2014
    57
    Germany
    Question about creating a route.
    Has anyone succeed creating a route between points on a map, where none of them is your current location?
    I live in Germany and want a route between two points in Norway. No luck. My current location is always my starting point?
    That's not like a real planning tool. Ok if you route to a specific point nothing more, can´t plan a route in other areas.
    Any hints, tipps, solutions?
    Thank you
    #50
  11. PineLaneRider
    Dec 25, 2016
    1,284
    ^^ What he asked.
    #51
  12. mosey.levy
    Jul 13, 2013
    2,473
    NYC
    Ram makes lockable mounts for that i think. A bit pricey.
    #52
  13. scootertrog
    Mar 26, 2011
    1,304
    Missouri USA
    Not sure that is possible within the Galileo app, but would be curious to see if so.
    #53
  14. GCecchetto
    Jun 29, 2013
    2,987
    Woodside CA
    Yes, but it’s huge, heavy, cumbersome, and the lock lever would hang down over the gauges.
    #54
  15. GCecchetto
    Jun 29, 2013
    2,987
    Woodside CA
    Currently, I believe you would have to do this in another app, or on a computer and create a gpx file to then import into Galileo.
    Would be nice if they supported this in the app. Not that difficult to allow you to select the start and finish.
    #55
  16. GCecchetto
    Jun 29, 2013
    2,987
    Woodside CA
    Sooo, today was the first ride with my new Samsung Tab Active2 running Galileo. The app crashed 6 times on 110 mile ride. This is obviously far from acceptable. Are any of you folks running the android version running into stability issues like this?
    I had done the Google sync thing, that’s a beta feature, so I’ve stopped the Google sync to see if that’s the issue.
    Any thoughts/suggestions would be appreciated.
    #56
  17. scootertrog
    Mar 26, 2011
    1,304
    Missouri USA
    Zero experience with the android version, but it's never crashed on my iPhone5s.
    #57
  18. ohgood
    Sep 21, 2010
    10,100
    alabama
    email the developer. they're usually really good at squashing bids for you
    #58
  19. GCecchetto
    Jun 29, 2013
    2,987
    Woodside CA
    I did, no response yet.
    #59
    ohgood likes this.
  20. mosey.levy
    Jul 13, 2013
    2,473
    NYC
    iPhone plus or X works really well in that spot.
    #60
