Galileo (guru gps) App
Discussion in 'GPS 101 - Which GPS For Me' started by mosey.levy, May 13, 2018.
  1. 919nick
    919nick Been here awhile
    Mar 12, 2009
    284
    Reidsville, NC
    It's possible, you just have to create it. I folllowed the instructions in the Galileo manual and created offline topo maps for the MABDR. Later I discovered Locus can do effectively the same thing right from the app.
    #81
  2. Viktor.J
    Viktor.J Been here awhile
    Sep 18, 2018
    124
    Sweden
    Allright, thanks. Ill try to make it work !
    #82
  3. Viktor.J
    Sep 18, 2018
    124
    Sweden
    So Im using Google myMaps to plan the tracks/routes. But lately Its been hardwr and harder to use it. Now I can’t add any routes ?? is there a limit ?
    Sorry if its in the wrong thread I’ve tried searcing but found nothing.
    #83
  4. mosey.levy
    mosey.levy Long timer
    Jul 13, 2013
    2,493
    NYC
    FYI they are renaming the app to guru instead of Galileo
    #84
  5. akupnt
    akupnt Been here awhile
    May 26, 2018
    125
    Reno, NV
    Google limits the number of waypoints you can use when plotting routes. No longer very practical.
    I use Furkot for planning. I use a laptop / desktop for the screen real estate and export the track. There is a short learning curve but has some useful features including user collaboration, distance / speed calculators for lodging, fuel, food recommendations and search > filters for route options & destinations.
    Furkot just announced compatibility with Gurumaps last week ... https://twitter.com/furkot/status/1091431799568228352/photo/1
    Gurumaps is also currently on sale through Feb 5 for 50% off @ $2 ... https://play.google.com/store/apps/details?id=com.bodunov.GalileoPro
    #85
    mosey.levy likes this.
  6. Viktor.J
    Sep 18, 2018
    124
    Sweden
    Ok, stupid question but I want to make sure I dont missunderstand.
    In this case, what is the definition of Waypoints in Google myMaps ?
    If i make a route by following a road from point A to B. Is that two waypoints ?
    #86
  7. akupnt
    May 26, 2018
    125
    Reno, NV
    They waypoints are any stopping points on the map. Because Google routes automatically, you may have to drag a route to another road resulting in an additional marker. Each one of these markers constitutes a waypoint.
    Its very easy for a simple route to require several waypoints. Google has reduced the usable limit making their system impractical for longer / more detailed planning.
    #87
  8. Viktor.J
    Sep 18, 2018
    124
    Sweden
    I tried around some and can't wrap my head around it.
    I places 9 "A to B". So It should have 18 waypoints, 9 A's and 9 B's. Then MyMaps said stop, I could add any route, marker or anything.... fine...
    But If i removed one "A to B" so I only had 8, then I could add many markers (didnt reach any limit). And I could also then "re add" the 9th "A to B"....
    I then tryed to "add a destination" within a "A to B" so it's a "A to J" (9 sections) that was no problem..... Adn I tried for Another "A to B"... No problem to add up to 9 sections...
    So It seems that I can only have 9 "routes"/ "Start to Finish" and within this I can have up to 9 sections.
    #88
  9. DRTBYK
    DRTBYK All Things GPS Supporter
    Mar 26, 2003
    8,346
    +47.352472, -121.941635
    I've been using Guru Maps (Galileo) on and off for quite some time. They were moving rather slowly in their development over the past five years but are now prooving to be a very rhobust Navigation App. I've always liked their underlying map architecture and their Map Downloading is one of the best. With the recent Furkot.com Export feature for Guru Maps, I'm compelled to use Guru Maps Pro more often.
    #89
  10. Viktor.J
    Sep 18, 2018
    124
    Sweden
    I’m only able to download the”vector map” as a offline map. Is there a way to download the other maps offline ?
    Cheers
    #90
  11. mosey.levy
    Jul 13, 2013
    2,493
    NYC
    If you can find map tiles you can use those too
    But no way to download google maps or earth i believe.
    https://boydsmaps.com/docs/Boyds-Core-of-the-Pines-HD.pdf
    #91
  12. Viktor.J
    Sep 18, 2018
    124
    Sweden
    #92
  13. PineLaneRider
    PineLaneRider Long timer
    Dec 25, 2016
    1,458
    Between Michaux and Tuscarora State Forests
    Navigate to this site, goto User Manuals, pick you OS and you will find many answers to your questions. I have been using Guru for a while now and just recently went through the manual. I now know how to do some things I didn't.
    https://gurumaps.app/#
    #93
  14. Viktor.J
    Sep 18, 2018
    124
    Sweden
    Thanks, but do you know If I can have other offline maps than the vector map ?
    #94
  15. PineLaneRider
    Dec 25, 2016
    1,458
    I use OpenTopo Maps that was downloaded using the link in the online manual.
    Android or Apple?
    #95
  16. 919nick
    Mar 12, 2009
    284
    Reidsville, NC
    #96
  17. Viktor.J
    Sep 18, 2018
    124
    Sweden
    Apple. "OpenTopo" is Another "mapp app" I guess?
    #97
  18. Viktor.J
    Sep 18, 2018
    124
    Sweden
    OK, hmmm. That seems advanced. I Will look in to it and come back if (or when) I get stuck :)
    #98
  19. PineLaneRider
    Dec 25, 2016
    1,458
    If you go to the manual as recommended, you will find links to "ready to download" maps. These may or may not be what you are looking for. Once downloaded these maps can be used offline.
    #99
  20. 919nick
    Mar 12, 2009
    284
    Reidsville, NC
    That section under "Additional Source" is for online maps.
    Making your own offline maps isn't difficult. Just download MOBAC, pick the area you want, map type, and save in the Guru/Galileo format.
