Galileo (guru gps) App
Discussion in 'GPS 101 - Which GPS For Me' started by mosey.levy, May 13, 2018.
  1. PineLaneRider
    PineLaneRider Long timer
    Dec 25, 2016
    1,285
    Between Michaux and Tuscarora State Forests
    I have downloaded a couple of these and once downloaded they are available on my device even in airplane mode, no connection at all.
  2. PineLaneRider
    Dec 25, 2016
    1,285
    Forget everything I just said. Apparently I'm not a savvy as I thought. Just tried it again and it would not work. I stand corrected!
    i4bikes likes this.
  3. JustAnotherDude2
    JustAnotherDude2 Adventurer
    Jan 7, 2019
    41
    VA
    I recently used Furkot to plan a trip and Guru on my phone to follow the track. It worked after a fashion. The thing that I can't figure out how to get around is Guru creating "approximate" tracks that don't follow the road closely, i.e. straight line segments between points and the actual road meanders back and forth under the line or the line cuts across a long sweeping bend. This is very problematic when in an area where on- and off-ramps are abundant. Any suggestions how to get Guru to follow actual roads more closely? (I have the Furkot Pass so used the Guru maps export function)
    Thanks,
    Dude
  4. scootertrog
    scootertrog Jedi Fart Master
    Mar 26, 2011
    1,308
    Missouri USA
    I use Mappite.org to create a route. Then export that as a .trk to either my email or Dropbox. Open that .trk file with Guru. You should see a route and a track show up. Look at the imported file in the Guru Collections section and you can delete either the route or the trk file. It's confusing that the straight lines are considered "routes" and the mapping that follows the road is called a "track". Hope this helped! I set up a tutorial for the iPhone/Galileo Pro ( Guru) which will demonstrate this step-by-step. :)
    https://advrider.com/f/threads/galileo-pro-quick-start-guide.1166708/
    interactive3 and mosey.levy like this.
  5. DRTBYK
    DRTBYK All Things GPS Supporter
    Mar 26, 2003
    8,256
    +47.352472, -121.941635
    If you want to actually keep your Furkot Trip as a Track then make sure you Export the Furkot Trip using the Guru Maps GPX Option and then select the TRACKS option and the new High-Resolution Tracks option as you can see in the screenshot below:
    flexiflyer likes this.
  6. JustAnotherDude2
    Jan 7, 2019
    41
    VA
    I tried that after I returned and didn't see any difference in the path Guru would follow. I also exported from Furkot routes with 1,000 points/route, 2,000 points/route, 4,000 points/ and 6,000 points/route with no discernable difference in the path Guru would follow. I confirmed Guru has no limits on number of points per route allowed. Any other suggestions to get Guru tracks or routes to better follow the actual roads in the maps?
  7. scootertrog
    Mar 26, 2011
    1,308
    Missouri USA
    Are you stuck on FURKOT? Mappite.org created .trks follow the roads really well in Guru.
  8. JustAnotherDude2
    Jan 7, 2019
    41
    VA
    Not locked into Furkot though I really like it. I looked at Mappite but the map repainting on my system is SO SLOW. I will pull it up on another system to see if it's any better.
  9. scootertrog
    Mar 26, 2011
    1,308
    Missouri USA
    Mappite.org is a really light, simple program, should not be having any kind of issue. Are you using it on a PC?
  10. JustAnotherDude2
    Jan 7, 2019
    41
    VA
    Mac in Brave browser (based on Chrome)
  11. scootertrog
    Mar 26, 2011
    1,308
    Missouri USA
    Not familiar with the Mac or Brave.
  12. Tiger993
    Tiger993 Been here awhile
    Oct 24, 2014
    452
    St. Michael, MN
    It sounds like you're exporting a Route instead of a Track. In Furkot, you need to use the Guru GPX export option, select "Tracks" as the export, and then select "high-resolution tracks" checkbox as @DRTBYK described above. This will create a track with thousands of trackpoints that Guru plots.
  13. JustAnotherDude2
    Jan 7, 2019
    41
    VA
    I've done it every way imaginable including what you suggest. Route with points as described, as a track using straight .gpx, a track using Guru .gpx, a high-resolution track using straight .gpx and a high-resolution track using Guru .gpx. I get the same outcome regardless of what I select. I confirmed in another mapping program that what I'm getting is what Furkot is outputting. I've sent this to Furkot to see what they can tell me.
    I can't upload a pic yet or I'd show you what I'm getting.
  14. Tiger993
    Oct 24, 2014
    452
    St. Michael, MN
    When you zoom in to view your route in Furkot, does it follow the roads closely, or does it approximate the path like you are seeing in Guru?
  15. JustAnotherDude2
    Jan 7, 2019
    41
    VA
    It follows the roads closely.
  16. JustAnotherDude2
    Jan 7, 2019
    41
    VA
    Update:
    Worked with Furkot on this problem and it has been corrected for me. When I exported my route, the last day of the route would not export correctly. Natalia at Furkot was not able to duplicate my results. I sent my export file to them along with screenshots of the result and export settings. Settings were correct and Furkot got high-resolution on all days when they exported the trip so they were a bit stumped at what was causing the difference. They made a change in the server and asked me to re-export the trip. Just to be careful I cleared my cache in case that could have been the problem. In hindsight, I should have exported my trip before clearing the cache to see if the server was the issue or my system was causing the problem. Export worked as expected. :clap Natalia also mentioned there could be some instances where timing of updates in their maps and the maps Guru is using could cause some anomalies.
    Natalia and Furkot were GREAT to work with. Fast responses and really wanted to help fix the issue. I will be using Furkot for all my route planning. I liked Mappite.org as well but Furkot is much easier (for me) at controlling waypoint placement and allows much more information to be attached to each day, stop or route segment. I also like having large amounts of POI information easily available and lodging reservation built in.
    Since this is a Guru thread, I'll also comment that Guru will be my handheld GPS of choice as it is so much faster than Locus or OsmAnd (on my old Kyocera Duraforce Pro). I'll play around a bit with Locus but it's learning curve is much steeper and map download is cumbersome with the free version.
    interactive3, DRTBYK and Tiger993 like this.
  17. DRTBYK
    Mar 26, 2003
    8,256
    I occasionally use Scenic but Guru Maps Pro is my go-to Navigator on my iPhone. Guru Maps implementation of OSM maps is the best in the business in both speed of rendering and searchable content - they don't strip out a bunch of the POI data like some OSM map servers do. With the Furkot Guru Maps Export and what appears to be forthcoming support for WunderLINQ, I actually feel like I've moved into the 21st Century for Moto-navigation.
    I'll be using Guru Maps Pro on the GlobeRiders World Tour next year from Tokyo to Munich. I have most of the worlds OSM maps downloaded to my phone (~28GB) including Navigation data.
    My partner, Jill, and I will be using this beast for the 12K+ mile journey across EurAsia. Happy Holidays!
  18. jojojones
    jojojones Long timer
    Jul 21, 2016
    1,564
    Northeast
    Locus is still the gold standard my friend...light years ahead of any of this stuff. Try harder...you can figure it out.
  19. TheChaser
    TheChaser n00b
    Jan 30, 2020
    1
    belgium
    i just installed guru pro and tested it for the first time yesterday with a track I downloaded from transeurotrail.org. When i load the track and start navigating towards the track but i was riding the opposite way the track was indicating.... , how can a reverse the riding direction of the track?
    thx.
  20. scootertrog
    Mar 26, 2011
    1,308
    Missouri USA
    Guru is just a heavy line on a map, it doesn’t really have a “direction”. True, there may be chevrons imbedded in the line, but you’ll soon learn that you won’t notice them. The actual chevron shape has changed a few times over the last 2 years, it’s getting harder to see with each rendition. Excellent road-going app!
