1. eNewsletter Sign Up
Garage Floor Epoxy Screw UP :(
Discussion in 'The Garage' started by Holden, Jul 22, 2007.
  1. Holden
    Holden Long timer Supporter
    Jan 5, 2006
    1,571
    Franklin, TN
    So I finally painted the garage floor with one of those DIY kits.
    I cleaned the HECK out of the floor, etched it twice, and followed the directions on the kit when laying it down.
    As it dries I can see NOTICABLE differences in color/gloss... I have no idea what I did worng?
    ANyoen else have this happen?
    Can I paint ontop the epoxy or do I need to scrap it off and start over?:cry
  2. Adh007
    Adh007 Needs to get back to work
    Dec 14, 2005
    771
    Shreveport, Louisiana
  3. Dano 407
    Dano 407 One Man Wolfpack
    Dec 31, 2005
    6,482
    The orange groves, CA
    If you did a good prep job, you should not have to scrape it off. Just recoat. But I am no expert, so get reading and post your results here so we dont fuck up also.
    thanks,
    D
  4. VStromTom
    VStromTom Long timer
    Aug 26, 2004
    1,579
    Did you mix the pails of finish coat as you went or did you use one pail up, then go to the second, etc? Could be a difference between pails, hence the mixing suggestion. If your prep was thorough, and it sounds like it was, and the finished surface of the concrete itself was consistent, the difference has to be the coating itself.
  5. R_W
    R_W wannabe
    May 3, 2005
    4,126
    Kansas
    If you did use multiple containers of stuff--make sure they were the same color and gloss code (I don't think there are many choices for this stuff, but need to check). Then check for a batch code. If they were the same, call the manufacturer and explain the issue (nicely but firmly). They should have a solution, and if their customer service is worth it, they will give you the product to fix it.
  6. DirtMerchant
    DirtMerchant Long timer
    Aug 2, 2004
    1,645
    Florida
    You may have etched some areas more then others, I would contact the manufacturer for input re recoating.
    I have been told that recoating epoxy can be problematic but I would think the sooner the better before it cures 100%. :dunno
  7. apeirce
    apeirce Two ears, one mouth.
    Jan 28, 2003
    2,726
    CT USA
    I'm sorry but after reading the title all I could picture was a guy standing in the middle of his garage with his feet stuck firmly to the floor and his wife standing there with her hands on her hips shaking her head.
    Hope you sort it out.
  8. Brucasso
    Brucasso Been here awhile
    Nov 27, 2004
    492
    You probably rolled over some that was partially dry. Some idiots did a 40,000 sf area at my work and screwed it up two times in a row doing just that. Caused it to be checked, some areas shiny some dull...
    No problem recoating as long as you don't get it dirty.
    #8
  9. Rad
    Rad Done riding
    Sep 24, 2001
    12,174
    It's a goddaymn garage floor, fer Christ's sakes; park yur car on it and stop whin'n:lol3
    #9
  10. fixer
    fixer KLR-riding cheap bastard
    Oct 9, 2003
    7,439
    Lost Wage$, NV
    +1
    #10
