garage pics
Discussion in 'Photos' started by W4lnutz, Oct 3, 2012.
  1. BigEasy
    BigEasy Fish Eyed Heathen
    Jun 23, 2007
    3,691
    South of Indy in the hills
    https://www.lowes.com/pd/Super-Slid...lastic-Carpet-and-Hard-Surface-Slider/4086784
    Easy wife uses something similar to slide furniture out of the way to do workoutsin front of the TV. Slides slick enough she can move a big ass couch by herself.
    oldfuddy likes this.
  2. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,028
    SouthWest (AZ)
    Nice. Is that an insert or did you cut the floor and then re-cement? How much of a gap is around the edges when it’s down? Where’s the controller? Thanks.
  3. BigEasy
    Jun 23, 2007
    3,691
    Search his content, I believe he put up a post of the build a few years ago when he and some buddies did it.
  4. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    3,789
    Fort Collins, CO
    "When the lift is down it is flat with the floor"
    So what you are saying is the lift no longer raises as high and after you take the bike off, you need to, again, raise the lift and remove the wheel vise and stop, then again, lower the bench. Right?
  5. old scoot
    old scoot Been here awhile
    Apr 5, 2017
    724
    O Fallon Missouri
    There is probably 1/4 inch gap between the lift and the floor, that worked out well. We cut the floor and then made forms for the pit and poured it. I moved the control to the front of the lift, it's electric so it's just an up down and off toggle . If you look closely you can see the electric cord is inside the rubber cord cover I got at H.D.
  6. old scoot
    Apr 5, 2017
    724
    O Fallon Missouri
    You're right, the lift doesn't go as high as it did although that hasn't been an issue at all. The wheel vise isn't a problem because I park the bike on the lift anyway so I might lose 6 inchs in front. It wouldn't take long to remove the vise but why bother.
  7. DerrickWade
    DerrickWade Adventurer
    Oct 14, 2008
    14
  8. SoggyDonkey
    SoggyDonkey Been here awhile
    Mar 18, 2017
    186
    Nyack, NY
    Whoa, I dig that mini-trail-powered TV!
    DerrickWade likes this.
  9. scout68
    scout68 Been here awhile
    Jan 1, 2018
    440
    Germantown TN
    Halen likes this.
  10. Macho Man2
    Macho Man2 Long timer Supporter
    Aug 19, 2009
    2,524
    Corryton,Tn
    phil2104, tattoo Dave and oldfuddy like this.
  11. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,028
    SouthWest (AZ)
    Not a lot of progress, but chugging along. Taping done, started mudding, filled in window going on to kitchen as it’s against code to leave the window in with a garage here. Slump block bricks on order for exterior....
    alpina, Halen and Parcero like this.
  12. africadero
    africadero ronny-king
    Dec 25, 2009
    173
    belgica
    Halen, DerrickWade, mischief and 10 others like this.
  13. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,028
    SouthWest (AZ)
    I see a lot of folks hanging commonly used tools on the wall over the bench. How do you like that? Is it a novelty or do you like having them there even after quite some time.
  14. africadero
    Dec 25, 2009
    173
    belgica
    I like my tools there, I have Always had them at the wall, never have to search for anything, as they all have their spot. It only works if you put them back there after use, haha. Special tools you don't use every day are in the drawers. I'm doing it this way for over 30 years.
  15. Parcero
    Parcero Mundial Supporter
    Aug 7, 2008
    1,552
    Chicago physically, Colombia en mi mente.
    redwing51, mischief and oldfuddy like this.
  16. Fixnfly
    Fixnfly Not found on the book of faces
    Feb 28, 2008
    1,493
    SWPA
    It's a great way to find the tools you use the most!
    africadero and oldfuddy like this.
  17. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,028
    SouthWest (AZ)
    Yup, I usually have some common ones up, but see folks have lots and some run all sizes from small to large and everything in between. For me, I’d only use some, not all. Thinking I’ll only hang the ones I use instead of a whole set or range.
  18. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,028
    SouthWest (AZ)
    More progress. Going to start designing the bench. Think it’s going to be on wheels. Haven’t decided yet.
    Mini split up on the roof...
    And the other part mounted inside....
    Garage door hung....
    Halen, Mudclod, busa1300 and 3 others like this.
  19. mikejjmay
    mikejjmay Long timer
    Dec 15, 2008
    1,094
    Wisconsin
    I wasnt a believer, then a built a tool wall of aluminum pegboard right behind me when im standing at my MC lift. Basically, i can spin 180 and have all my tools right there in front of my face to choose from. No more walking over, opening a drawer, finding the tool, and then not bothering to put it back. Just turn, grab, use, and rehang right away. Dont know why i didnt do it sooner.
    TropicalDale and oldfuddy like this.
  20. Tiger812
    Tiger812 Adventurer
    May 22, 2007
    48
    East Tennessee
    Walk this way.
    Macho Man2 and Snaga like this.
