Garmin 650 T dark screen
Discussion in 'GPS Tracks - Oz and Kiwi Land' started by Moff52, Sep 9, 2016.
  1. Moff52
    Moff52 Been here awhile
    Dec 10, 2014
    153
    CANDELO NSW AUSTRALIA
    My 2 or 3 year old Garmin 650T has suddenly decided to display the screen in about half its former lamination. I have been through all the options I thought I may have altered or stuffed up but can't make it bright screened (for daylight) again.
    Any suggestions please??
  2. Moff52
    Dec 10, 2014
    153
    That's LUMEMATION not lamination -
  3. Precis
    Precis Maladroit malcontent
    Oct 13, 2009
    6,552
    Body's back home, but soul is in Central America
    Ahem: illumination....
    :hide
    Has the device's clock been set so that it thinks it's night time when it's not, and vice-versa?
  4. wairau
    wairau get in behind!
    Mar 29, 2011
    3,743
    Urenui, Taranaki
    my oregon(?) short press the pwr button, and the screen brightness option appears. use plus or minus buttons from there
    or try factory settings reset. or check the screen brightness timeout/auto dim setting?
    or new batteries.
  5. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    12,680
    GodSowncountry Australia
    I'm so glad I got a 60CSx...........they are proper tough little units.:nod
  6. SaAdvRider99
    SaAdvRider99 Been here awhile
    Apr 26, 2015
    653
    Adelaide Hills South Australia
    Same with 650T
    Short press power button. Brings up backlight setting %.
    Adjust here.
    Go into settings/Display and see what your backlight time out is set at.
    Not sure if the Battery saver option will effect this?
    If all settings are OK?
    Other option to fix/repair would be get a replacement screen/backlight combo from Aliexpress and fit yourself?
    I did this with mine.
    http://ridedualsport.com/forum/index.php?topic=2960.0
    Only need to do the first part to replace the screen.
  7. Moff52
    Dec 10, 2014
    153
    Thanks for both replies. correct spelling noted.
    Wairau you were spot on about the short press start button. Screen brightness now back to normal. So easy when you know what your looking for.
    Cheers
    Ross
