Garmin announces the new GPSMAP 276Cx
Discussion in 'Mapping & Navigation' started by mattebox, Oct 4, 2016.
  1. khpossum
    khpossum poster
    Sep 13, 2007
    839
    Colorado
    Hmmm, did not know about that one. Nice find. I hoped that it would be a way to shorten search time. But: I can only find the menu option as described sometimes and other times it will not show up, not only with addresses (and cities??). It appears to work only after it is done searching all locations and the result box is populated. Defeates shortening the search time with fewer maps to search. It seems a feature halfassed implemented by Garmin. I do not know if it was better / different under 4.8 since I already updated. It will need some more playing around to find out when it is of use.
  2. ConiKost
    ConiKost Adventurer
    Feb 3, 2020
    94
    World
    Yes, I can confirm that. I am getting, except for addresses, only the ability to choose a map, when the list returns something. Otherwise it does not show up.
  3. Berin
    Berin Been here awhile
    Oct 7, 2006
    560
    Oxford
    I see the proximity alert radius field but cant enter anything into it
  4. ConiKost
    ConiKost Adventurer
    Feb 3, 2020
    94
    World
    Can't produce that. See my screenshot, I can set a radius without any problems.
  5. ConiKost
    ConiKost Adventurer
    Feb 3, 2020
    94
    World
    I noticed a new change. Firmware 5.10 shows GPS accuracy with one rounded decimal place.
    Older Firmware 4.80 only shows a single number. So for example instead of 4m, it shows now 4.3m.
    But it's apparently a little bit wrongly alligned.
      File size:
      58.1 KB
      29
  6. Sattphalat
    Sattphalat Adventurer
    Mar 24, 2019
    17
    Oslo, Norway
    I think it is the soap I have used washing it.
    Strong kitchen spray soap.
  7. fastdresser
    fastdresser n00b
    Aug 29, 2015
    4
    Buffalo, NY
    I've been hounding Garmin for almost a year now regarding Unit shutdown when searching near current route. They promised me a fix was coming out this summer. Well it finally came out, but guess what, it still doesn't work. Unit still locks up when doing a search "near current route". I've already notified them. I've had it with the 276cx. They did fix the issue with the waypoint catagories.
    khpossum likes this.
  8. anadel
    anadel Been here awhile
    Apr 16, 2006
    206
    I always wondered about the crash worthiness of the 276cx and found out in June. I had a collision with a kangaroo at approx 50 km/h, the bike came down heavily on the handlebars and broke the mirrors and screen, seriously scraped the brake reservoir cover and hand guards but the 276cx came out with flying colours. It was mounted on a 6” ram arm.
  9. ConiKost
    ConiKost Adventurer
    Feb 3, 2020
    94
    World
    You should never use soap on such protection, as it destroys the film due its ingredients.
    I am still thinking, could be this some issue with a map? For example, I still don't have any crash using the function "near current route".
    What do you mean with flying colours?
  10. Berin
    Oct 7, 2006
    560
    Oxford
    More questions!
    Using the route function, is t
    Also, it shuts down searching near another location. For example, I'm in London, and want to find a hotel in York. To do this, I do:
    find>cities>york
    Then find>lodging>hotel
    Unit then crashes
  11. ConiKost
    ConiKost Adventurer
    Feb 3, 2020
    94
    World
    Hm, I am unable to reproduce that on my 276Cx. It just works, no crash here. I am wondering, if this is somehow related to the map version.
  12. khpossum
    khpossum poster
    Sep 13, 2007
    839
    Colorado
    Same crashing problem here, OSM and Garmin US maps. Reported ages ago, but apparently not important enough to fix. Hey, it only requires you to stop, take the GPS out of the cradle, remove the battery and start over again. I have not confirmed it also happens with 5.1.
  13. ConiKost
    ConiKost Adventurer
    Feb 3, 2020
    94
    World
    Could you give me the exact steps? I would like to try it to reproduce, so I could also report to Garmin.
  14. Berin
    Oct 7, 2006
    560
    Oxford
    Hmm, now I can't reproduce the crash either. Here are the steps I took, which I was sure resulted in a crash.
    From the map page
    Find button>cities>(highlight containing text)>menu>select map>select City Navigator>back to Containing and type York: make tea; drink tea
    Select the correct York>Select "Map">find button: find from York>select lodging
    View list of hotels.
    Worked.
  15. carvalhito
    carvalhito n00b
    Jun 28, 2020
    5
    Portugal
    Hi, my unit doesn't crash when performing a search near current route. Could it be another issue to cause that?
  16. CLANTECH
    CLANTECH At work...
    Jul 17, 2007
    65
    Somewhere on the Globe
    Mine doesn’t crash either.
    Seems to work ok.
    carvalhito likes this.
  17. ConiKost
    ConiKost Adventurer
    Feb 3, 2020
    94
    World
    I noticed a new bug on 5.10, which is not present on 4.80.
    The indicator for north direction is only visible, when as page layout "Full Screen Map" or "Map With Overlay" is used.
    When "1 Column (Large)" or "1 Column (Small) is used, the indicator is covered at the top by the box which shows during routing when you see your next turn by turn.
    In 4.80, the indicator is a little bit lower and before that box and visible.
  18. Max Kool
    Max Kool Xtankteam™
    Jan 19, 2004
    4,963
    Los Angeles
    Did you report it?
  19. ConiKost
    ConiKost Adventurer
    Feb 3, 2020
    94
    World
    Yes, just a couple minutes before :-) Please do too! Thanks.
    Max Kool likes this.
  20. ConiKost
    ConiKost Adventurer
    Feb 3, 2020
    94
    World
    ffs!!! Found a new bug. Just start a route navigation and press Quit button and the device powers off.
    In order to trigger that, you need to have Altimeter page enabled, as it's the first one, which would be shown, when button Quit is pressed. You can also trigger that by pressing multiple times Page button.
    If no route is enabled for navigation, the device does not power off and the Altimeter page is shown.
    So basically, with firmware 5.10, the Altimeter page is unusable during active routing.
    This is ridiculous, the firmware is full of bugs.
    @All: please report all that bugs also to garmin, as the german support is pretty bad and doesn't seem always to take the bugs for serious..
