Garmin announces the new GPSMAP 276Cx
Discussion in 'Mapping & Navigation' started by mattebox, Oct 4, 2016.
  1. Madsen
    Madsen n00b
    Aug 19, 2009
    3
    I'm thinking about replacing my 60csx with the 276 cx. Can you guys tell me if you can show multiple tracks at the same time, each with a different color on the 276cx?
  2. Garry H
    Garry H Been here awhile
    May 19, 2008
    177
    The 276cx will do that no problem
  3. Tork
    Tork Aluminum Cigar Stuffer
    Feb 15, 2004
    3,971
    Duvall, WA.
    Got my new unit , fully charged battery , downloaded express , registered unit , got confirmation unit is registered , express will not download updates for map and operating software , To further the frustration it has been years since I used the Garmin site for my old 2730 , also just recently bought a iMac and ditched the PC .
    Any tips will be appreciated.
    ***update ***
    Downloaded WebUpdater and got the firmware updated to latest version.
    Still cannot update base map using garmin express
  4. pepebayeta
    pepebayeta Been here awhile
    Dec 18, 2007
    494
    Spain
    If I'm not wrong, there are no updates for the base map.
  5. Tork
    Feb 15, 2004
    3,971
    Duvall, WA.
    Express states v 2019.11 update is available for Full Coverage of North America, I purchased the Automobile bundle .
  6. DonM
    DonM Do-dah Do-dah
    Jan 13, 2008
    1,389
    Atlanta, GA
  7. Tork
    Feb 15, 2004
    3,971
    Duvall, WA.
    I think the issue is on my end , possible a slow connection and to be fair to garmin I can be an idiot.
  8. pepebayeta
    Dec 18, 2007
    494
    Spain
    Oh! Ok, I thought you meant the worldwide basemap.
    Don't worry that much about a map update but make sure to install the latest firmware version.
    Tork likes this.
  9. DonM
    DonM Do-dah Do-dah
    Jan 13, 2008
    1,389
    Atlanta, GA
    What do I need to buy to use the 276Cx in a car and on a bike? Want life time maps and a good bike mount.
  10. Tork
    Feb 15, 2004
    3,971
    Duvall, WA.
    The automotive bundle comes with 2 mounts , 84CA3ED1-3DA3-410F-9519-12DFD48698C8.jpeg friction mount with cigarette plug for a car and a hard mount for a boat , The hard mount has a bracket that you can disassemble and hardwire on bike using ram balls and ram arm . Unit locks in with security screw . An upgrade would be the Touratech mount that uses the mount with wires that come with the boat mount . By taking off the 4 screws you can add a Ram base plate with ball or use it in TT mount 84CA3ED1-3DA3-410F-9519-12DFD48698C8.jpeg
  11. RonKZ650
    RonKZ650 Been here awhile
    Jun 11, 2009
    746
    Lakewood, CO
    Garmin claims the rugged mount is included, so if you buy the automotive bundle you get the good motorcycle mount as well as lifetime maps. Just have to add whatever you like to mount the rugged mount to the bars or wherever you plan to mount. The rugged mount is really great.
  12. DonM
    DonM Do-dah Do-dah
    Jan 13, 2008
    1,389
    Atlanta, GA
    I’m in! Will be here wandering in the wilderness
  13. DonM
    DonM Do-dah Do-dah
    Jan 13, 2008
    1,389
    Atlanta, GA
    What is the max memory of the sd card on the 276cx? Can’t find it in the user manual.
    Thx!
  14. nibby
    nibby Been here awhile
    Feb 22, 2009
    276
    U.K. - Liverpool
    Does anyone know if you can show more than one track on the map page? I have a few tracks in the same area and want to view on the map and see where they meet/cross over etc.
    I've gone to tracks from the menu, selected the track hit the menu button and chosen "show on map" etc.
    But when I go to view one of the tracks by choosing one and hitting "map" it only shows me that particular track on the screen and not the others that I know should be showing.
    cheers for any help.
  15. HTSRocker
    HTSRocker amateur
    May 17, 2003
    2,784
    Tallahassee
    BigDogAdventures had put this up a while ago in #1511
    It sure set me up right
  16. nibby
    Feb 22, 2009
    276
    U.K. - Liverpool
    Thanks. I tried that #1511 post and thought it would work but when I've viewing a track and I know one of the other tracks I've enabled should run very close by and it doesn't show on the map?
    I've gone back and made sure doing the reverse then shows "hide on map" but still wont show
    anything obvious I'm doing wrong?
  17. HTSRocker
    HTSRocker amateur
    May 17, 2003
    2,784
    Tallahassee
    Each individual track that you want to view must be turned on, and the color changed to your preference. I set up a trip for this summer using a 140 tracks across the U.S., it took some time.
    nibby likes this.
  18. shu
    shu ...
    Feb 23, 2010
    1,499
    Colorado
    When you do this, you have opened up a file that pertains only to that particular track. That is, the only map you will see there is one that shows that one track.
    All the tracks that you have marked 'Show on map' will be visible together on the main navigation map. Mark as many as you want , then quit and return to your main map and look at them there.
    Right now I am riding in Spain and have 6 or 8 tracks- that I made at home on my computer -showing on my map so I can compare them to the routes that I am creating on the 276cx.
    ...................shu
    nibby likes this.
  19. bigboyxl
    bigboyxl Been here awhile
    May 24, 2011
    461
    Czech rep.
    I’m with Nibby on this topic
    Probably no more such feature, as there is no Show on map, but only Review on map
    See the picture attached[​IMG]
  20. bigboyxl
    May 24, 2011
    461
    Czech rep.
    Ok @nibby now I found it too
    Once you “selected” the desired track from GPX list by up/down button hit Enter button
    Then hit Menu button and you will see that “Show on Map”
    P.s. what is a bit frustrating is that you cannot do that with a track from Archive, first it should be places in to Favorites (GPX) tab
