Garmin Montana 700i
Discussion in 'Mapping & Navigation' started by monkd, Jul 30, 2020.
  1. Fiddish
    Fiddish Adventurer
    Sep 27, 2007
    13
    Just Red and Black to the battery will power the cradle. (I bundled up the headphone jack and serial wires in case I ever change my mind) If you plan on shortening the cable between Garmin's Voltage converter and the cradle, you'll need Red, Black and Grey wires reconnected.
    Hubilado, you used just the Red and Black wires to the cradle straight from your 5V converter, yes? (Not your converter output to the rugged mount input Red & Black)
    mbabc likes this.
  2. ramz
    ramz Professional Trail Rider Supporter
    Dec 11, 2006
    2,956
    Salida, CO
    Customer comment on DC to DC converter: "Draws around 14-15 mA when there's no load."
    So one should have it on a switch (on the battery side) or you'll lose your battery.
    :ricky
    phreakingeek and empedrado like this.
  3. CavReconSGT
    CavReconSGT Just the right amount of evil. Supporter
    Jul 7, 2011
    1,638
    CT/NH
    I have mine wired, like all my accessories, to my PDM60 which is programmable and turns all my accessories off after a minute or so of the bike being turned off.
    KR
    offtheback and ramz like this.
  4. ramz
    Dec 11, 2006
    2,956
    Salida, CO
    conrado and mbabc like this.
  5. Exurban
    Exurban Been here awhile
    Sep 14, 2007
    952
    Wilmington, DE
    There are reports that some have theirs bricked by this update and waiting for a new update fix. For others it went ok. Update at your peril.
  6. ramz
    Dec 11, 2006
    2,956
    Salida, CO
    Change made from version 5.30 to 6.30:
    • Added wifi icon flash on status page/status bar when wifi on but not connected.
    • Added custom patterned lines for other road types.
    • Added the ability to lock/unlock the configurable fields on the corner data fields dashboard.
    • Added a lock icon on confirmation pages to clarify auto-lock status.
    • Added configurable fields on the corners of the map page.
    • Added a "note" option for logging geocaches.
    • Added the ability for the measure distance function to start at any point.
    • Added Rain mode to Touch Sensitivity settings.
    • Improved map drawing times.
    • Improved filename time formats.
    • Improved inReach activation prompts.
    • Improved swiping on the status page.
    • Fixed issue with lock icon not showing up on secure wifi networks in night mode.
    • Fixed issue with shutdown when sorting photos by date in photo viewer.
    • Fixed issue with geocache proximity alarm causing slow start up times with .ggz files loaded.
    • Fixed issue with slow start up after deleting .ggz files.
    • Fixed issue with font on corner data fields dashboard in night mode.
    • Fixed issue with the widget page indicators occasionally blinking on the status page.
    • Fixed issue with text alignment for inReach messages.
    • Fixed issue with flashing on the photo viewer.
    • Fixed issue with potential shutdowns when navigating tracks.
    • Fixed overlapping icons on the map page with corner data fields dashboard.
    • Fixed issue with the wifi status not updating.
    • Fixed issue with "track up" and "north up" map orientations.
    • Fixed issue with manual route transitions.
    • Fixed issue with the tabs/status bar flashing on the geocache page.
    • Fixed issue with zoom levels on round trip routing pages.
    • Fixed issue with getting a false max number of photos exceeded message.
    • Fixed issue with Explore sync and map settings.
    • Fixed issue with CIQ apps and widgets in landscape orientation.
    • Fixed issue with auto-zoom on the weather map.
    • Fixed issue with copy-as-reversed fit activity stats.
    • Fixed issue with truncation of a data field on the trip computer page.
    • Fixed issue with mounting SD cards formatted on Mac computers.
    • Fixed possible shutdowns when using Birdseye imagery.
    • Fixed Express sync errors due to empty current activity file.
    • Fixed "off road" label for routes that were not off road.
    • Fixed issues with geocaches not showing up when attempting to program a chirp.
    • Fixed issues with truncated translations.
    • Fixed issue with overlapping text in the geocache info box.
    • Fixed issue with the "Go" button not appearing on some routes.
    • Fixed issue with geocache filters turning back on automatically.
    • Fixed a potential for a shutdown on the map page.
    • Fixed issue with adding via points.
    There may be additional unpublished changes included in this update.
    :ricky
  7. hubilado
    hubilado Motoquiero Super Supporter
    Feb 16, 2004
    823
    New Mexico
    Sorry, not exactly sure what you're asking, but I trimmed the wire to the GPS mount, added a quick connector and plugged it into a paired connector on the output from the voltage regulator using red/blk wires only.
  8. Fiddish
    Fiddish Adventurer
    Sep 27, 2007
    13
    Yes, as I thought, thanks.
    mbabc had asked about chopping off the headphone jack and serial wires and just using the red (fused) and black wires that hook to the battery (then into Garmin’s voltage converter), as I understood it. NOT the red and black wires inside the cable from Garmin’s converter to the mount (cradle)
  9. mbabc
    mbabc Curmudgeon trainee
    May 28, 2007
    3,414
    Louisville, KY
    I ended up just coiling up the excess data wires/audio cable and connecting the red and black to my fuse box.
    In looking at my old Montana 600 rugged mount, that's exactly what I did 8 years ago.
  10. krussell
    krussell Gravel Warrior Supporter
    Nov 19, 2009
    4,384
    Portland, Oregon
    Picked up a 700i with the hope of replacing a Zumo XT and a 66i with a single unit. I love the 700i, but ended up returning it and listing the powered mount in the flea market. I just can’t give up the XT display, the Montana doesn’t compare. I get that it’s a handheld and there are power concerns. I was just hoping it might be brighter when using the powered mount.
    I guess what I really want is a Zumo XTi as I’m happy with the XT, I just want integrated inreach.
    The 700 powered mount is a step back from the 600 too. Putting a small brick in the center of the cable makes it really hard to get a decent install without hacking up the cable. At least with the XT mount you can remove the cable and thread the mount end then reattach
    If the display and cable work for I was happy with everything else.
    CavReconSGT and hubilado like this.
  11. hubilado
    Feb 16, 2004
    823
    New Mexico
    It has been the same for me....although I haven't returned the unit. The display (brightness) has been the biggest disappointment. I can live with it, but it's clearly a step backward for Garmin. The external voltage step-down circuit was a surprise as I've not dealt with that on any of the other Garmin units I've had; it's a fairly easy workaround, but, nevertheless, a PIA and it seems Garmin wasn't thinking of the motorbike consumer when they OK'd this design.
  12. ConiKost
    ConiKost Adventurer
    Feb 3, 2020
    94
    World
    Does anyone has a good picture for brightness for 276Cx vs 700i? I am really thinking about replacing my 276Cx with an 700i. But that doesn't sound good :/
  13. hubilado
    Feb 16, 2004
    823
    New Mexico
    I don't have a picture of the two that is of decent quality, but I can ASSURE YOUT THAT THERE IS NO COMPARISON; the screen on the 276CX is MUCH BRIGHTER and can be seen in all lighting conditions MUCH BETTER than the 700. I cannot recommend exchanging the the 276CX with the 700.
  14. readonly24
    readonly24 Been here awhile
    Jun 5, 2015
    472
    In the dirt
    There's a thread in the Garmin Forums: Increase brightness in AMPS.
    STLR likes this.
  15. empedrado
    empedrado Been here awhile
    Aug 4, 2004
    699
    Central NM
    I posted a comparison picture earlier in this series. The 276cx is far and away my favorite for off road use. I also have the XT, which I use primarily for my big dual sport and when I am exploring also add the 276cx. The Montana is now a back up secondary gps and my inReach device. If you can't find it I can repost but have deleted the picture from my camera
  16. conrado
    conrado Been here awhile
    Jun 17, 2004
    451
    Berlin (Germany)
    I find brightness a non-issue, but it obviously depends on your reference.
    Exurban and krussell like this.
  17. markbvt
    markbvt Long timer
    Sep 26, 2007
    4,178
    Georgia, Vermont (that's one town, not two states)
    ??? The XT's got one too...
    I do wish Garmin would put the brick closer to the mount so it's easier to shorten the cable, but...
    Garmin actually did do this intentionally, because the idea is that you permanently mount it to your bike, run the cable under the tank, and hide the step-down box near the battery. So it does make sense, it just doesn't work out great for those of us who want to put a plug on the end of the cable and move the mount from bike to bike. I have a zip-tied bundle between the mount and the step-down box.
    As for screen brightness, yeah, the Montana could definitely be better, though it's fantastic in direct sunlight. But I'm finding myself using my XT less and less because I like the Montana's interface and features a lot better, and the XT's waypoint handling actively pisses me off.
    --mark
    mbabc and Grinnin like this.
  18. krussell
    Nov 19, 2009
    4,384
    Portland, Oregon
    The XT step down box is about a third of the size. It's much less of an issue for cable routing IMHO because it's closer to the battery end of the cable. The mount allows the cable to be easily removed and threaded without having to take the bike apart to find a way to lay a brick in the middle of the cable somewhere nice. Why even have a freakin' brick on the 700 or the XT. 600 series didn't have one, BMW NAV doesn't have them. The 700 has a lot more room inside in theory Not only is it a hassle, the mount is now twice the price it was on the 600 series.
    It's good to have choices.
  19. Ken in Regina
    Ken in Regina Long timer Supporter
    Sep 12, 2010
    2,260
    Regina, SK, Canada
    ??? I have a Montana 600 and the cable for my powered mount has one. I have no idea what it's for ... never analyzed it ... don't care. But I had exactly the same problem that's being described above. I wanted to be able to swap the mount and all necessary parts of the cable between two bikes by putting a two prong trailer connector at the handlebars with a simple two-wire cable running under the tank to the battery. Rather than mess with anything between the box and the mount I just wrapped the excess cable around the stem for the mount. It's an ugly mess but it works and I didn't have to worry about screwing anything up.
    ...ken...
    mbabc likes this.
  20. ConiKost
    ConiKost Adventurer
    Feb 3, 2020
    94
    World
    The Montana 600 series AMPS mount doesn't have a 5V converter box. It only has a tiny surge protection near end. I am also really disappointed, that the Montana 700 AMPS mount uses a 5V converter, same as the XT does. It would be better, if they handled that the way as the old zumo 590/595, which had the 5v converter build into the mount itself.
    hubilado likes this.
