Garmin Montana -- Mounting to factory BMW GS GPS mount?
Discussion in 'Mapping & Navigation' started by rcfitch, Jun 29, 2018.
  1. rcfitch
    rcfitch Been here awhile
    Oct 27, 2013
    115
    Atlanta
    Hello Friends
    I have just purchased a new 2017 BMW R1200 GS which has the factory GPS mount installed. The BMW GPS option is very functional. However, it is an expensive option that I would like to avoid.
    I have a new Montana 610. I am wondering if there is any adapter available that will allow the Montana to be connected to the BMW GPS mount?
    Thanks in advance for your guidance.
    mickey.smith1958 likes this.
  2. MJS
    MJS Long timer
    Dec 23, 2005
    2,517
    Off the grid in San Felipe, Baja
    Nope. You have to buy the BMW GPS if you want to use the wonder wheel.
  3. rcfitch
    Oct 27, 2013
    115
    Atlanta
    I don't want to use the wheel... It's not worth $800.
  4. MJS
    MJS Long timer
    Dec 23, 2005
    2,517
    The factory cross bar is to small a diameter if you want to use a RAM mount. Even with the RAM reducer I could not get the RAM ball tight enough to keep from rotating so I mounted my Montana on the handlebars. You can power it from the OEM connector if you get the plug from the BMW dealer and splice it to the Montana cable. I just removed the OEM GPS mount and set it aside for some future owner.
  5. Patch
    Patch Long timer
    May 4, 2011
    1,868
    Southwestern New England
    You can get the RAM M8 bolt mount to replace a handlebar clamp bolt and easily mount the Montana.
    Also, you can easily score a BMW NAV 5 or 6 if you watch the flea market.
  6. Emoto
    Emoto Sure, why not?
    Feb 24, 2004
    21,192
    SE Mass
    Use the AMPS mount and then get RAM mount parts - an arm of the length and style you want, and the U-Bolt mount. You can clamp the u-bolt mount anywhere to the OEM BMW bar that is on your bike. I run a V-1 Radar detector this way.
    I will say, though, that since I have to use the touch screen on the Montana to control it, I have mine on the left handlebar, so that it is an easy reach up from the left grip to operate. I find this most convenient.
  7. Emoto
    Feb 24, 2004
    21,192
    SE Mass
    That would appear to be the case if one reads the specs for the RAM mounts and the OEM bar (the OEM bar is a teeny weeny bit smaller diameter than the ram mount claims to clamp), but I can assure you from actual experience that the RAM u-bolt mount clamps on just fine and holds without problem. I have had a V-1 on mine for 5 years now and it has never loosened up or been a problem in any way.
  8. MJS
    MJS Long timer
    Dec 23, 2005
    2,517
    Mine would not get tight enough and would vibrate down. Might have been the angle of the arm and the extra weight of the Montana. Left handlebar preferred here too.
    #8
  9. Emoto
    Feb 24, 2004
    21,192
    SE Mass
    I have an arm and the 2-magnet detector mount, and the V-1 with the remote audio adapter velcroed to the top of it, so I dont' think the Montana outweighs that. Maybe there is more than one u-bolt mount? I think I got the one that was for things as small as 1/2" and it works fine. If you think of the OEM BMW mounting bar as an upside down U, I have mine clamped to the vertical bar on the right side. No slipping or movement. According to emails from GPSCity, I have this one: https://www.gpscity.com/ram-mount-large-stainless-steel-rail-u-bolt-base-with-1-inch-ball
    #9
