Garmin Montana
Discussion in 'Mapping & Navigation' started by AugustFalcon, May 18, 2011.
  1. Emmbeedee
    Emmbeedee Procrastinators
    Mar 19, 2008
    11,343
    Near Ottawa, ON, Canada
    I agree. I don't think there's any kind of light sensor in the Montana.
  2. Grinnin
    Grinnin Forever N00b
    Dec 10, 2005
    5,004
    Maine
    I sure don't know. I could be wrong.
    AFAICT there's no visible light sensor on my nuvi either. That nuvi would switch to night mode when the screen got too dirty and cleaning just the screen would turn it back to day mode. Pic shows nuvi just after noon with day/night set to "auto". OTOH, I cannot get the nuvi to switch from night to day mode with any amount of artificial light. (It's dark as I write this.)
    I'll try some things with my Montana today to learn more.
  3. SteveAZ
    SteveAZ Long timer
    Sep 23, 2002
    1,650
    AZ
    Didn't notice that when it changed it was coincidentally exactly the same times the unit computes for sunset and sunrise, eh?
    Emoto and Anders- like this.
  4. Rocky TFS
    Rocky TFS Been here awhile
    Apr 16, 2012
    835
    Hailey, Idaho
    HUH? I've been creating tracks on my Montana since the day I bought it 7 years ago. :confused
    You can create a track, save a track, change color of that track, make that track visible, and trakback it, as well as save it to BaseCamp for future use.
    outbacktm likes this.
  5. Emmbeedee
    Mar 19, 2008
    11,343
    He probably meant from scratch, as you would create a route, not by letting the device record the track.
    At least that was my understanding.
  6. Grinnin
    Dec 10, 2005
    5,004
    Maine
    I don't usually have sunrise and sunset times as a display field.
    The nuvi would display the night mode at mid-day. Since Garmins often share features I thought they might share this one too.
  7. Emmbeedee
    Mar 19, 2008
    11,343
    Here's how to check: put your Montana in the fridge. Is the backlight on?
    But seriously, take it to a dark place and I'm sure you won't see any automatic brightness changes. The only thing that can change the brightness automatically is sunset/sunrise changes if you have display set to auto.
    Brightness can vary if you put the Montana on a powered mount, though.
  8. Grinnin
    Dec 10, 2005
    5,004
    Maine
    I was going to put it in bright sun and put welding filters over much of the screen to see if it would dim. Not feasible with heavy clouds today.
    I do believe I'm wrong though. When the backlight goes out, the screen is so blank that I doubt any amount of sun would make it readable.
    I have no idea how the nuvi changes brightness depending on how dirty the screen is, but it does it somehow.
  9. Rocky TFS
    Apr 16, 2012
    835
    Hailey, Idaho
    Oh. Now why would anyone who had BaseCamp want to do that?
  10. Emmbeedee
    Mar 19, 2008
    11,343
    I thought he was describing the Montana's capabilities.
  11. shu
    shu ...
    Feb 23, 2010
    1,501
    Colorado
    Exactly.
    As to why I would want the unit to be able to create a track? Simple: I don't travel with a computer and can't use Basecamp on my tablet. So any routes I create while on the road are done right on the Montana. It would be nice to be able to turn those routes into tracks also, but AFAIK it can't be done on the unit.
    ..................shu
  12. Emmbeedee
    Mar 19, 2008
    11,343
    Really? Before I had my new VStrom wired up with the Rugged Mount I was running my Montana with the backlight turned off and in sunlight, it was very easy to read.
  13. Grinnin
    Dec 10, 2005
    5,004
    Maine
    Ah, yes. I see a huge difference between turning down the backlight and "backlight timeout" which seems to do much more than turn off the backlight.
  14. Emmbeedee
    Mar 19, 2008
    11,343
    Again, really? There should be no difference between setting the backlight to low and having it turn itself down after a certain interval.
    There's nothing in the display which changes, imho. It's just a trick of the light.
  15. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    4,538
    Albuquerque NM
    +1. I am evolving towards the same situation. I have always carried a notebook on long trips and occasionally used it to create new tracks during the trip. I recently decided I wanted a backup gps and decided to check out the smart phone route. After a couple of months of playing with the thing, I have decided the smart phone will serve well as a backup gps and will do everything I could do with my notebook except make new tracks from routes.
    I have not found a smart phone app that will do this either.
    I am leaning towards not carrying the notebook anymore and if I need to make changes during a trip, I will do it with routes on the Montana. I do this sometimes anyway if I need to make a change in the middle of day's ride. I will also load all the other tracks I already have in the vicinity of a current ride onto the Montana, so I could easily switch to one of these.
  16. Grinnin
    Dec 10, 2005
    5,004
    Maine
    Really.
    Turn down the backlight to 0 and I can still see the map in modest light and see it clearly outside (overcast) both on just battery power.
    Wait 1 minute for the backlight timeout, and there is simply nothing visible. The screen is just plain gray. (Again, on battery power.)
    Is there another timeout that I haven't found? The only one I see is in Setup then Display and is clearly labeled "backlight timeout".
  17. Spud Rider
    Spud Rider Long timer
    Jun 15, 2008
    4,098
    Idaho
  18. Emmbeedee
    Mar 19, 2008
    11,343
    I think you're confusing 'battery save' with backlight timeout.
    BS makes the screen go grey, ie it displays nothing.
    BT just turns off the backlight.
    You probably have both set to On.
    Triplog likes this.
  19. ohgood
    Sep 21, 2010
    7,820
    alabama
    hmm, what's this about trying to make new tracks from routes?
  20. Emmbeedee
    Mar 19, 2008
    11,343
    You can't on the Montana. Want to discuss how to do it on a phone? Do it somewhere else. It's not on topic here.
