Garmin Montana
Discussion in 'Mapping & Navigation' started by AugustFalcon, May 18, 2011.
  1. ohgood
    Sep 21, 2010
    7,809
    alabama
    looks like a great time to use tracks
  2. marchyman
    marchyman DR and GS
    Jun 30, 2005
    10,659
    SF Bay Area
    I don't know your specific route which of course can make all the difference in the world, but I've so far been able to create multi hundred mile routes with no more than a handful of waypoints. I start with the end points and see what happens. Then I add a mid point to force it to use a road I want. If needed I keep splitting the segments in half. Usually after adding 3-5 additional waypoints the route is exactly as I like. I'm doing this in basecamp. Convert the route to a track and upload both to the GPS.
    Creating a route 1 turn at a time has never worked well for me. It's lots of work and the GPS usually screws it up, anyway.
    rsteiger and wbbnm like this.
  3. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    4,531
    Albuquerque NM
    +1 I have found it works better to put the intermediate via points in the middle of a road segment I want rather than at intersections.
    Grinnin likes this.
  4. Emmbeedee
    Emmbeedee Procrastinators
    Mar 19, 2008
    11,343
    Near Ottawa, ON, Canada
    So @Grinnin, did you figure this out yet?
  5. Grinnin
    Grinnin Forever N00b
    Dec 10, 2005
    4,998
    Maine
    Q 2, yes; Q 1, no.
    Q 2, backlight vs. battery save, you're correct and I had them both on. (I wasn't "confusing" them; I didn't know that battery save existed although I must have seen it years ago.)
    Q 2 grew out of Q 1 -- does the backlight change intensity in bright sun? I doubt that it does, and it just doesn't matter to me any more. I can read the map very well, rain or shine or direct sun.
  6. SteveAZ
    SteveAZ Long timer
    Sep 23, 2002
    1,650
    AZ
    Anyone know what they're charging for out-of-warranty repair (replacement) these days?
    I got home last night after a bike ride and there's a hole where my power button used to be :bluduh
  7. fpalbrecht
    fpalbrecht Adventurer
    Aug 17, 2008
    99
    Lake Mills, Wisconsin
    It's $160ish. Replacement with like new refurbished unit. Mine was about 2 months past warranty and they replaced it anyway!
    Sent from my SM-G950U using Tapatalk
    SteveAZ likes this.
  8. SteveAZ
    SteveAZ Long timer
    Sep 23, 2002
    1,650
    AZ
    I'm waaaaay past two months.... thanks!
  9. Emmbeedee
    Mar 19, 2008
    11,343
    I’ll trade you a 276C for it.
  10. SteveAZ
    SteveAZ Long timer
    Sep 23, 2002
    1,650
    AZ
    If your talking about the unit the way it is pre-replacement I'll consider it... If I'm sheeling out $160 it won't make sense. I am pretty much using it 99% on my bicycle and it's ok on there but since the unit is going to be "down" one way or the other I'm going to see if I can put one of the other old units on the bike... if that works... well...
  11. Emmbeedee
    Mar 19, 2008
    11,343
    My offer was for your Montana the way it is.
  12. SKINNY
    SKINNY Been here awhile
    Jul 23, 2001
    843
    West Texas
    I have a new Montana that I'm trying to set up the same as an existing Montana.
    Where in the directory structure can I find the file that the custom settings are saved in??
  13. Emmbeedee
    Mar 19, 2008
    11,343
    There’s no one ‘settings’ file. You need to copy over the \Profiles and \Shortcuts folders as well as \Gpx to get close to your previous setup, then adjust the rest.
    scottydawg and Magus like this.
  14. SKINNY
    Jul 23, 2001
    843
    West Texas
  15. Triplog
    Triplog Adventurer
    Aug 20, 2017
    25
    Thanks Shu and Emmbeedee, Unfortunately I can't try the suggestion. My Montana was acting weird ( 5 mile route taking 7 minutes by car, 85 minutes in Motorcycle profile and 7 minutes in Walking profile!!!) so after talking to Garmin I shipped it back to them. They have lost it (claim they never got it even though I have a signature on delivery) and are now telling me they won't have a replacement unit in until October 6th (they received mine on 18th Sept and told me it would be a 2 day turn-around). To say I'm less than impressed and just a bit furious would be an understatement.
  16. Emmbeedee
    Mar 19, 2008
    11,343
    What country are you in?
  17. Triplog
    Triplog Adventurer
    Aug 20, 2017
    25
    N. Ireland
  18. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    4,531
    Albuquerque NM
    Just got back from a week long trip. I noticed some strangeness in my recorded tracks. The track from the first part of the first dirt riding day was appended to the end of the track from the truck drive day.
    And the rest of the track for the 1st day was fragmented into about 5 segments. Each segment was marked "Auto" in Basecamp.
    Tracks for the next 2 days were okay and marked "Day".
    The track for the 4th day was appended to the track for the 5th day and to the track for the drive home.
    I had to do a Master Reset recently. I know from experience that this screws up some of the track logging settings. My Archive setting for Profile Car got reset to "When Full", but the setting for Profile Motorcylce was still "Daily". I use Car for the drive since I have it set to record way less track points. I assume that this somehow caused the strange behavior. But I really don't understand what happened.
    I forgot to turn the unit off at the end of the 4th or maybe the 5th day. And I probably set the Profile to Car before the end of the 5th riding day.
    Edit: After thinking more about this I believe the problems might have been caused by trying to switch Profiles several times a day to switch between City Nav and Topos. Both of these were set to Archive Daily. But I was wearing heavy gloves and many times got the Car Profile by mistake. May every time I did this it executed an autoarchive??
  19. Brutalguyracing
    Brutalguyracing Long timer
    May 15, 2013
    2,908
    Long Island New York
    any tips
    my computer died last week
    i got a new one, but while transferring all my data from that hard drive to this all the garmin files failed to transfer
    can i get them from the unit to the new basecamp on new computer
    i have not tried as i am leaving for a trip in am and dont want to mess with anything before said trip
    thanks
  20. BlueFargo
    BlueFargo Been here awhile
    Apr 18, 2015
    253
    Central Indiana
    I also did a week long trip last week with similar issues. I've got a 4 month old 610T that I've now had to master reset twice. I like a lot about the Montana but it has its flaws.
    I had it set up to auto save at the end of each day so that I could go back later and review each day's ride. Out of 6 days riding, it only correctly saved tracks for days 1, 3, and 6 (and on each of these days it captured 2 or 3 tracks/segments - not 1 like I was expecting). On day 2, it saved 2 tracks of 0ft and 265 ft. On day 4, it saved 3 tracks but only one of them (37.3 mi) was legit. On day 5, it saved 1 track (98.4mi, second half of the day) but missed the entire morning.
    I think it was day 4 that I had to do the master reset because it lost the GPS signal. For about an hour or so it kept losing, finding, losing, and finding the signal. I finally just turned it off and followed my buddy. Coincidentally, he also has a new 610. His was working on Day 4 but his was losing GPS signal the day before. We had clear views of the sky for much of this time.
    It was a good thing we had each other as a back up and also had our phones for backup.
    I can forgive a software glitch that doesn't save tracks but this is the second time I've been out riding where I've had issues losing GPS signal. For a GPS unit, that seems like a pretty big flaw.
    Any help or suggestions would be appreciated. Thanks.
