Garmin Montana
Discussion in 'Mapping & Navigation' started by AugustFalcon, May 18, 2011.
  1. Emmbeedee
    Emmbeedee Procrastinators
    Mar 19, 2008
    11,343
    Near Ottawa, ON, Canada
    I've had instances where the navigation text stops working, and usually a factory reset cures it for me.
    If you do a reset, switch to the Recreation profile first, then shut it down. When you restart it, hold your finger on the screen in the top left until you're asked if you want to reset. Choose Yes, then let it go.
    You won't lose any tracks, maps or waypoints, though some of your customisation may need to be redone. Generally a reset is nothing to worry about.
    Are you using the Nuvi Dashboard? This is what you should expect with that display.
  2. shu
    shu ...
    Feb 23, 2010
    1,501
    Colorado
    I've seen this on my Montana before, also. It is a bug somewhere. It can be pretty irritating, especially when you can look at the directions page and see that your route is still good with all it's turns and distances listed. I have found that happens - at least sometimes- when I make my route in City navigator and than switch the map over to OSM. It just doesn't seem to like that too much. In that case I will just stop navigation on the route, choose one map and re start my route in the map set I want and leave it there. Sometimes that doesn't fix it and I'll re set by taking out the battery. Keep in mind that you have to be moving on the route for those directions to come back up- you can't just reset and sit still and expect to see it.
    ............shu
    falcn likes this.
  3. Emmbeedee
    Mar 19, 2008
    11,343
    Removing the battery does not reset it in any way.
    Sent from my iPhone
  4. falcn
    falcn Squidless Soul
    Oct 29, 2006
    862
    Union City, CA
    I will check, but usually run CN for normal driving. I save OSM and Topos for riding.
    Automotive Turns in data field were blank - so I think either the map is wrong, or I need to update.
    Let us know when you're headed out here. Maybe we can coordinate the camping trip up on OR border with our buddy or ....
    Yinzer Moto likes this.
  5. falcn
    Oct 29, 2006
    862
    Union City, CA
    Thanks for the hints guys. I will try making sure the map is set to only CN, and probably try the Nuvi dashboard and a reset as something seems really wrong.
  6. kave
    kave Gravel rules
    Mar 26, 2004
    654
    Sweden
    Yes, I have a defect 276C which I liked very much, except the poor gps reception. I bought a Monterra when it came out but never liked it, sold it after ome year. I have had the Montana for a week now and used it for mtb riding and it works really well. It is so much better than a smartphone on the bars. It views all small roads and paths even when zoomed out so I am very happy using it to find new roads. A few bugs here and there but it seems to work fine for my purpose. Now I only need a new motorbike to use it on :)
    biker128pedal and Emmbeedee like this.
  7. Emmbeedee
    Mar 19, 2008
    11,343
    I also have a 276C, but I don't like it much. The buttons are on the wrong side, for a start. I really have no interest in the new 276Cx for the same reason. I much prefer the touchscreen on the Montana.
  8. Yossarian™
    Yossarian™ Deputy Cultural Attaché
    Jul 9, 2007
    12,193
    the 'Ha
    It depends.
    I have CNNA, CNEUR, etc. Each are different. To which version are you referring?
  9. rickcj7
    rickcj7 Been here awhile
    Jun 2, 2010
    663
    Hollidaysburg PA
    Looks like I have cn 17.2
  10. Yossarian™
    Jul 9, 2007
    12,193
    the 'Ha
    Okay, we're getting somewhere. That's likely 2017.20, and I know for sure that NA (north america) is at least at 2018.10 now, if not further along. So -- if it's the NA version that you have, you are a few releases behind.
    Do you know which mapset (region) you own?
  11. rickcj7
    Jun 2, 2010
    663
    Hollidaysburg PA
    NA the whole USA on it.
  12. rickcj7
    Jun 2, 2010
    663
    Hollidaysburg PA
    CN NA NT 2017.2
  13. Emmbeedee
    Mar 19, 2008
    11,343
  14. rickcj7
    Jun 2, 2010
    663
    Hollidaysburg PA
    That's the problem it says it has latest updates
  15. falcn
    Oct 29, 2006
    862
    Union City, CA
    Setting CN map as only map fixed the issue. Also Nuvi mode worked well
    shu, Yinzer Moto and Emmbeedee like this.
  16. Emmbeedee
    Mar 19, 2008
    11,343
    I use the Nuvi dashboard most of the time. It's very useful. Did you know clicking the Speed Data field takes you to the Trip Computer? When you're navigating, click the top text to see the Active Route details.
    Also, clicking the North arrow takes you to the alternate map display type. So if you're set for North Up map display it'll switch to Track Up map mode, and vice versa...
  17. shu
    shu ...
    Feb 23, 2010
    1,501
    Colorado
    :thumbup Good tips.
    I like the NUVI dash as well.
    .........shu
    falcn likes this.
  18. dvwalker
    dvwalker Working to ride
    Jul 5, 2009
    1,092
    Oregon
    what are folks using for their map-->advanced setup-->zoom levels?
    I like to have map-->advanced setup-->detail=Most, but when zooming out to say .5 mi the map becomes really cluttered with POIs. I haven't been able to find a good balance.
    Say you're looking ahead to the days track, nice to zoom out and get a good perspective. I know some folks run two GPSs just for this functionality.
  19. Emmbeedee
    Mar 19, 2008
    11,343
    Two gps units? Use profiles instead.
    If you're in the profile with the waypoint clutter problem, go to Setup\Profiles and create a new one, call it "Uncluttered" or something similar, and go to Map\Setup Map\Advanced\Zoom Levels\User Waypoints and set them to Off.
    Then when you want the uncluttered view, switch to it. Shortcuts make that easier.
    Sounds like a good idea so I did just that myself.
    scottydawg and CavReconSGT like this.
  20. Emmbeedee
    Mar 19, 2008
    11,343
    Here's the difference between the uncluttered and cluttered map display in my two profiles.
    [​IMG] [​IMG]
    CavReconSGT likes this.
