Garmin Montana
Discussion in 'Mapping & Navigation' started by AugustFalcon, May 18, 2011.
  1. JR356
    JR356 Long timer
    May 4, 2005
    6,193
    Way out West
    Several Youtube videos on Montana screen/digitizer replacement.
    Screen likely available on Ebay.
    JR356
  2. Aces 6
    Aces 6 Whiskey Tango Foxtrot, Over
    Mar 10, 2009
    3,709
    CONUS
    Question to you Jedi Montana users out there:
    Just uploaded City Navigator to Garmin 680T.
    I have loaded the MABDR tracks onto the Montana. How do I check if the tracks are on the device?
    Online searches say to go to "Track Manager" on device (albeit I didn't find anything for the 680T specifically).
    I don't seem to have that in my menu.
    Would like to confirm I have tracks loaded.
    Thanks in advance.
  3. Emmbeedee
    Emmbeedee Procrastinators
    Mar 19, 2008
    11,348
    Near Ottawa, ON, Canada
    I think the 680 went to an "Activity" model and the Track Manager is not as prominent as on earlier models. You may need to do this "Select an Output Format for Saved Tracks" setup as described in the manual screen shot below. You definitely want GPX type in your saved data. FIT is not as useful. Once you've done that, you may see the Track Manager.
    Grinnin likes this.
  4. tedhartshorn1
    tedhartshorn1 n00b
    Nov 13, 2013
    5
    miami
    Big Bear Run !!!
    Doing my first Big Bear Run next weekend. I’ve done a couple of LA B2V’s and used roll charts. First time out with a GPS. Garmin 680t. The site for the run has a Jerry Counts “set up“ for other devices, not the Garmin 680t. Don’t want to hold up the line. Any help is appreciated. Ted. Tedhartshorn@mac.com
  5. Aces 6
    Mar 10, 2009
    3,709
    CONUS
    Got it! Just had to slow down and get it sorted.
  6. Emmbeedee
    Mar 19, 2008
    11,348
    Countdown's setup page should be good enough to set your Montana from, as long as it's his Garmin 78 setup, not the 60/76 model.
    Check this message wrt saving your tracks in gpx format. It's just a couple of posts up this page.
    Grinnin likes this.
  7. Grinnin
    Grinnin Forever N00b
    Dec 10, 2005
    5,015
    Maine
    Some of those instructions may help @tedhartshorn1 but I would be flummoxed applying the Garmin 78 instructions on the Big Bear site to a Montana.
    Instruction 1, "Welcome Message", looks like it will work on the Montana. I never knew this was an option.
    Instruction 2, "Backlight Timeout and Style", is mixed. Backlight can stay on all the time with powered mount, but I couldn't find how to set the style to "Grid 12 Items". I have no experience with the 78 to even know what the intended result is.
    Instruction 3, "Menu Sequence" may work on the Montana with a slightly different method, but I'd just move Track Manager to the Main Menu instead.
    Instruction 4 is about removing pages you don't need. I haven't actually tried this, but is it necessary on a Montana?
    Some of the other instructions do apply and should be easy to translate to a Montana. Not all.
    These are the instructions: https://s3.amazonaws.com/ClubExpressClubFiles/849383/documents/Big_Bear_Run_2013_GPS_info_1_485531293.pdf?AWSAccessKeyId=AKIAIB6I23VLJX7E4J7Q&Expires=1529268285&response-content-disposition=inline; filename=Big_Bear_Run_2013_GPS_info_1.pdf&Signature=d90M6LIRlwXB0X+GhqoGediO7aM=
    The instructions don't say Big Bear Run anywhere on them, but that's the page you get from "GPS Setup Information" on this page: http://bigbeartrailriders.com/content.aspx?page_id=22&club_id=849383&module_id=254847
  8. knyberg
    knyberg @kristian_z28
    Apr 22, 2018
    10
    Vista, Ca
    Does anyone have the .gpx file for the Hardway from 2018 Big Bear Run or know where to get it? I was out of town but still want to ride it and practice for next year. Thank you.
  9. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    4,545
    Albuquerque NM
    A few other places to try to get the tracks.
    ADV GPS Tracks West forum, dualsportmaps.com, GPSXchange.com, ADV West Regional forum
  10. dstutz
    dstutz Been here awhile
    Mar 23, 2008
    255
    Aberdeen, MD
    I've been using Garmins for a while buying second hand BMW navigators (been through a II, III and IV) and just bought a new Montana 610. I loaded the OSM generic routable (new style) maps from http://garmin.openstreetmap.nl/ as well as trying some topo maps in a couple regions from here: http://www.gmaptool.eu/en/content/usa-osm-topo-routable. I used basecamp to create a route with those maps and sent it to the unit. When I load it up on the unit, the route is just a series of direct lines going to each waypoint that I used to create the route. While I was recently on a trip I tried to route to a location and it just drew a straight line to it that moved with me and gave me distance to "target". As I said I have a lot of experience with Garmin's and mapsource/basecamp so the difference is the Montana and trying to use OSM maps. Any ideas what I did wrong that both of those OSM mapsets are not routable on the unit but worked ok in Basecamp? For the trip I converted the routes to tracks and was following that but I lacked any distance/time to destination stuff that was a little less than useful.
  11. Yinzer Moto
    Yinzer Moto aka: trailer Rails
    Jun 13, 2008
    15,490
    Pittsburgh PA
    Check that all the settings on the GPS are ok. You will want it to lock on roads. There are a few other settings that may cause that. Sorry, i can't think of them right now.
  12. Timmer
    Timmer Curious Adventurer
    Oct 14, 2006
    3,119
    Burien, WA
    Is your profile set to Direct as opposed to Driving or Motorcycling? In the route box in BC it’s displayed in the upper right side of the screen.
    Grinnin likes this.
  13. MJS
    MJS Long timer
    Dec 23, 2005
    2,528
    Off the grid in San Felipe, Baja
    Not sure what you're doing but I am using a 610 in Russia with OSM and I don't have any problems with routing. Either from BC or on the fly. Do make sure the route type is not set to direct.
    Grinnin likes this.
  14. dstutz
    Mar 23, 2008
    255
    Aberdeen, MD
    In BC, it's motorcycle. The route looks fine there, it was snapping to the roads properly as I was dropping waypoints the way it always works, this is how I was able to convert to a track as a backup plan which got me through the trip fine. It's just after sending it to the Montana and loading it there that it's all straight lines. I went through some of the settings on the Montana after unboxing it but don't really recall any routing settings so unless it's set to direct out of the box I didn't change it. I'll take another look through the settings on there though. Admittedly I was doing all this the night before leaving so I didn't have a ton of time to dig into it.
    https://www8.garmin.com/manuals/web...UID-6F528B44-B42C-4BF0-8A36-27059DB8ECCD.html <---here are the routing settings
    Anyone know if the "Activity" is set to direct right out of the box? I definitely didn't change any of these the other day. I'll take a look when I get home from work today and test out. Really hoping it's something simple/stupid.
  15. Timmer
    Oct 14, 2006
    3,119
    Burien, WA
    Set the route to direct in BC, transfer it to the Montana, change the profile on the Montana to Motorcycling or Driving and recalculate.
  16. Timmer
    Oct 14, 2006
    3,119
    Burien, WA
    Or in BC prepare the route, convert it to a track, send the track to the Montana and then navigate the track.
  17. dstutz
    Mar 23, 2008
    255
    Aberdeen, MD
    LOL, wow, I'm such an idiot. Yeah, the Montana was set on direct routing out of the box. Just set it to motorcycling, loaded up one of the routes and it looks fine. Also tested going to a POI and it calculated a route. I figured it was going to be something stupid/simple. Thanks!
  18. Emoto
    Emoto Sure, why not?
    Feb 24, 2004
    21,194
    SE Mass
    Glad the fix was so trivial! :thumb
  19. ADW
    ADW 'tard bike restos
    May 29, 2009
    752
    Rochester MI
    Don't forget to set the routing preferences on the Montana, specifically the Avoidances. My buddy's new Montana was set to avoid a bunch of things and it was making some really weird routes because of it.
  20. PoleRbear
    PoleRbear Been here awhile
    Oct 12, 2016
    174
    SF Bay Area
    Does anyone have issues typing addresses? If I want to navigate to a certain address, first I get asked for a country, then city, and so on. And here’s my problem. I want to find an address in San Jose, CA so I type “San Jo” and three cities pop up but no San Jose. I go back to input more letters and complete the name but then it shows that there are no such city. What am I doing wrong? I’m new to this, tried searching this thread and Google but I can’t find any answers. I’m using CN US 2018 on SD card. Thanks
    seasider likes this.
