Garmin Montana
Discussion in 'Mapping & Navigation' started by AugustFalcon, May 18, 2011.
  1. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    5,834
    MN and NM
    I never knew that about the North arrow. But I always use North up. I will play around with this some.
    If it is really easy to switch, I might switch. I do get confused about turns when heading south.
  2. JMartin
    JMartin Tres Libras
    Feb 25, 2006
    707
    That very fine line. (Denver, CO USA)
    That feature must be map dependent. I have a north arrow when viewing a track on top of TOPO but not on top of Fishing Hotspots. Neat trick nonetheless.
    Jay
  3. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    5,834
    MN and NM
    I went on a 140 mile ride yesterday and tried using the North icon to switch back and forth between Track Up and North Up in Track Up mode. It basically worked as advertised.
    I missed the arrow a few times, but finally kind of got the hang of it.
    I still don't really like Track Up because of the map spinning. But it is definitely better than North Up when riding predominantly south.
  4. Grinnin
    Grinnin Forever N00b Supporter
    Dec 10, 2005
    7,108
    Maine
    When I was a Scout, we were taught to orient the map, i.e. turn the map so north on the map points to north on the earth which makes east point east, etc. That's also the way the GPS map should be turned when using track up. It sometimes wavers a bit, especially when stopped, but in general it's oriented. When the map is oriented you can look up from the map directly at physical features instead of having to figure out where they are.
    North up gives me a quicker feel for what direction roads go. I can look at just the road and don't have to look to the arrow for comparison.
    I almost always use track up.
    CavReconSGT and joefromsf like this.
  5. Ken in Regina
    Ken in Regina Long timer Supporter
    Sep 12, 2010
    2,032
    Regina, SK, Canada
    I prefer both but for different purposes. When I'm rolling I want to see what's ahead of me, so track up. I mostly don't care what my actual orientation is. On the Montana's dashboard screen I have direction in degrees as one of the display fields. If I really want to know what direction I'm travelling and don't know I just look at the arrow on the map or the direction field on the dashboard for more precision.
    If I'm stopped to do a bit of planning and trying to orient the actual trails to direction I'll switch to North Up because that's the way I used paper maps for decades.
    Actually I'm as likely to still pull out a paper map for anything but the most local, trivial orienteering. The Montana display is way too small for anything serious.
    ...ken...
  6. Grinnin
    Dec 10, 2005
    7,108
    Maine
    Now that we've dealt with north up vs. track up, it's time to hash out portrait vs. landscape.
    Since the roads we ride on will probably curve, landscape orientation will often show more of the road length than portrait.
    On the ride pictured, I did try portrait briefly, but the screen shows so much less of the road or trail than landscape.
    So we can all agree that portrait is superior.
    :hide
    Up next: Topo vs. road maps. :lol3
  7. Anders-
    Anders- 690R
    Aug 23, 2013
    4,163
    Швеция
    :lol3
    (Rollinghobo)
  8. TrotterD
    TrotterD Geek
    Oct 27, 2010
    23
    County Durham, UK
    TwoUpTourer and CavReconSGT like this.
  9. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    37,559
    Pittsburgh PA
    I like portrait with track up. It gives me the information I need while moving on the bike. I don’t need to know what direction north is while riding, just which way the next turn is. When stopped and trying to figure out where we are at and where to go next, I will switch to north up.
  10. Ken in Regina
    Sep 12, 2010
    2,032
    Regina, SK, Canada
    Absolutely right. :beer
    ...ken...
  11. CavReconSGT
    CavReconSGT Just the right amount of evil.
    Jul 7, 2011
    1,544
    CT/NH
    I use to use my Montana in Landscape track up. I now use the 396 the same way. Not that I don't get using it in Portrait. Just like Landscape. :D
    KR
  12. Anders-
    Anders- 690R
    Aug 23, 2013
    4,163
    Швеция
    Both modes make sense to me, sometimes one can see further in portrait mode than landscape.
    I run my gps at 45 degrees as a compromise, autorotate on - of course.
    :hide
  13. 250senuf
    250senuf Long timer
    Feb 17, 2008
    3,922
    Nelson area, Kootenai, BC, Canada
    That must be nice as it flips between those as the bars turn. ;)
    Anders- likes this.
  14. Chip Stevens
    Chip Stevens Been here awhile Supporter
    Feb 18, 2005
    399
    Yucaipa, Ca and Portal, Az
    Since you run with the Montana at 45 degrees have you established if 46 degrees to the left or right works better?
    Anders- and simon crewe like this.
  15. dstutz
    dstutz Long timer
    Mar 23, 2008
    1,270
    Aberdeen, MD
    Anders- likes this.
  16. ohgood
    Sep 21, 2010
    10,005
    alabama
    How are you using "north up" while you're using "track up" ?
    I'm confused by this post
  17. Grinnin
    Dec 10, 2005
    7,108
    Maine
    I usually use track up so the map is oriented.
    I sometimes use north up if I'm not following a track so I see more quickly what directions roads go.
    North up/track up isn't cast in stone; it's a simple press on the north arrow.
  18. TwoUpTourer
    TwoUpTourer Long timer
    Jan 11, 2010
    1,867
    South Australia
    I've just returned from a 3 day riding weekend, and for the first time seem to have a decent grip on the Montana way of doing things thanks to those 2 tips provided a few days back. The North, as discussed above, and the little return arrow. It behaved really well without what I previously interpreted as being a freeze. Your tips are much appreciated.
    Perhaps one more thing. I only use tracks as routes wouldn't work where we ride, but the map is zoomed too far out such that small complex junctions lose detail, forcing me to stop, take my gloves off, zoom in a bit, check map, gloves on, ride away, with 5 other guys waiting alongside for me to get my act together. Yes, why am I the only one in 6 of us who can prepare a track and load it onto a GPS, but that is another story I guess.
    And +1 for track up - I need to know where I'm going, left/right/straight on, so how this could be achieved with a north orientation whilst riding beats me.
    BergDonk and Grinnin like this.
  19. miken0vf
    miken0vf Been here awhile
    Apr 17, 2018
    328
    Broomfield, CO
    Maybe set your default view as 800ft or maybe less? you could also set diff profile defaults, an example might be "road use" and another "trail use", then just toggle to the one you need?
  20. Yinzer Moto
    Jun 13, 2008
    37,559
    Pittsburgh PA
    I run different zoom levels depending on the speed and how complex the turns are. I’ll run 200’ zoom on more dirtbike type stuff. Speeds under 40mph. 40-50mph usually ends up with about 800’ zoom. Faster than that is .2mi zoom. This gives me enough detail to see the junctions and the upcoming curves in the road. As I approach a curve, I can give a quick glance and get a decent idea of the radius. This allows me to hit turns a little faster than if I were just trying to read the road alone.
