Garmin Montana
Discussion in 'Mapping & Navigation' started by AugustFalcon, May 18, 2011.
  1. guavadude
    guavadude Dirt Nap Enthusiast
    Aug 31, 2009
    2,732
    Grapevine, TX
    The main thing that will mess you up in a Basecamp is that you’ll need to create a DUPLICATE before you do any editing to a track. Otherwise the edits you make will affect every other instance of that track in every list. As SteveAZ mentioned, the lists only contain pointers to the data.
    For Mac users be aware that option-copy in Basecamp doesn’t create a duplicate like it does in every other app. This really messed with me and made me hate BC until I finally figured out what was happening.
  2. TwoUpTourer
    TwoUpTourer Long timer
    Jan 11, 2010
    2,115
    South Australia
    I use Basecamp for one thing only, which is to transfer GPX tracks to my Montana. As I've banged on about here often, I use the paid version of Plotaroute.com to map out my tracks, because it uses Google road and aerial maps as my base map, amongst an array of others that it has available as well, which allows me to see the hills and forests and everything else, whilst having the ability to mix both snap-to-road and freeform pathing, and then a large range of tools to edit/trim/re-plot/reduce points etc etc etc, all of it better than Basecamp.
    Tracks in Basecamp are primitive compared to Plotaroute.
    And unlike Basecamp, I don't have to select either route or track up front, because it is a choice you make at the end when exporting the GPX.
    I guess if I was only a road rider, then having uniformity of the one map source for both Basecamp and my Garmin GPS that ensures that routes will work perfectly might be worth it, but it would have to be giving up a lot.
    I ran a track to GPS series of classes recently for a Facebook dirt riders group I'm in, and I took them through track and route creation using a number of tools, firstly with Basecamp, then Google Maps and Google MyMaps, GPS Visualiser, and some android apps, and finally with Plotaroute. Didn't take much for them to arrive at some conclusions.
  3. dstutz
    dstutz Long timer
    Mar 23, 2008
    1,350
    Aberdeen, MD
    A bit extreme considering the existence of "convert route to track" and "convert track to route" functionality in Basecamp.
    CavReconSGT, wbbnm and SteveAZ like this.
  4. SteveAZ
    SteveAZ Long timer
    Sep 23, 2002
    2,722
    AZ
    +1
    As mentioned I think it's a clunky tool but it has features that are useful and it's a better way to manage my decades of logs than anything I was doing previously
    I have zero intention of doing any personal GNSS data management anywhere but on my own machines (i.e. I'm not going to use a third-party website... period) - I've got basecramp on a dedicated VM on the server at my shop so I can access it from anywhere... all my maps are on there and I never hook a device to it directly, I just shuck .img's and .gpx's between the device and the VM
    Maybe someday I'll consider a better tool to put on my server but I'm not feeling enough pain with BC to go down that road at present and it's likely hard to find some other third-party tool that will accept the garmin .img's
    Likely the most broken thing with BC is address searching (albeit that may have been addressed in a later version than I'm running) but there are plenty of other issues... just not enough to blow it off entirely
    Edit - just for giggles I downloaded the latest BC and address searching is still entirely broken
    wbbnm likes this.
  5. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,404
    MN and NM
    I have tried to learn Furkot a few times but always ran into things it wouldn't do at all or not without some tedious work-around.
    For me the features and things it did better than Basecamp weren't worth continued learning or much less switching. But I imagine it has improved quite a bit over the last couple of years since I gave it a try.
    I think the only thing that would get me to switch or even investigate an online trip planning app would be a long detailed point-by-point comparison showing how the newer app was better and with the honesty of showing areas where Basecamp was better.
  6. Ken in Regina
    Ken in Regina Long timer Supporter
    Sep 12, 2010
    2,516
    Regina, SK, Canada
    Thanks. That describes exactly my feelings about Basecamp versus Garmin's older Mapsource. I use Basecamp for the occasional thing that Mapsource won't do. Mapsource fits my brain. Basecamp doesn't.
    ...ken...
  7. TwoUpTourer
    Jan 11, 2010
    2,115
    South Australia
    What I was referring to is that track creation in Basecamp is freeform, a series of point-to-point lines, and does not conform to the road. As you say, you can create a route an then convert it to a track afterwards.
  8. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,404
    MN and NM
    I am under the impression that all GPS Tracks are just a series of points independent of Basecamp. Converting a route to a track does a good job of getting those points to lie on roads.
    duggram and TwoUpTourer like this.
  9. SteveAZ
    SteveAZ Long timer
    Sep 23, 2002
    2,722
    AZ
    I still use mapsource plenty... I'm not going to load BC on my local machines so I only use it while connected to internet (to my server) and for tasks that aren't quick and simple... I load mapsource on pretty much every bare iron PC with windows since it's very light by comparison and doesn't eat up resources, etc. - it handles the quick stuff well enough
  10. johnpitts01
    johnpitts01 Long timer
    Nov 13, 2005
    1,384
    Philly
    Will this thread cover the new Montana 700i series? Or should I look for a separate thread?
  11. CavReconSGT
    CavReconSGT Just the right amount of evil. Supporter
    Jul 7, 2011
    1,769
    CT/NH
  12. simon crewe
    simon crewe Been here awhile
    Sep 27, 2007
    420
    Haslemere, UK
  13. johnpitts01
    Nov 13, 2005
    1,384
    Philly
    I read all 27 pages last night! ;-0
    I gave up my Montana @ 1 year ago in favor of inReach explorer SE+ for a number of reasons. While I like the inreach one big disappointment is that an internet connection is required to send routes and waypoints to the device via the Explore website. Seems pretty stupid to me as these devices are designed for people using them in remote areas. The new Montana looks like it can communicate using either Basecamp or Explore
  14. Jeff B
    Jeff B Socially Awkward
    Feb 13, 2008
    9,902
    SW PA.
    Can it communicate using Explore?
  15. Grinnin
    Grinnin Forever N00b Supporter
    Dec 10, 2005
    8,076
    Maine, USA
  16. leighwgold
    leighwgold Ph.D. of B.S. Supporter
    Oct 18, 2008
    277
    Salisbury Heights
    I tried to get my head around Basecamp but it just seemed to be a really hard way to do something simple.
    I create a route in a website, Plotaroute, save the GPX file to my desktop, connect my Montana 610 to the computer, open Garmin folder then GPX folder and drop the file into the GPX folder, then disconnect the Montana. Simples.
  17. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    15,227
    Snowy Mountains Oz
    And just as simple or simpler in Basecamp, I don't get that is so hard for people :dunno
    dstutz, EmmEff, wbbnm and 1 other person like this.
  18. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,404
    MN and NM
    Easier since you don't have to create a GPS file. Just use send to.
  19. BergDonk
    Nov 15, 2010
    15,227
    Snowy Mountains Oz
    drag and drop one or more objects is even easier....
  20. Ken in Regina
    Sep 12, 2010
    2,516
    Regina, SK, Canada
    It depends on how your brain works. And I don't mean that as a shot at anyone. It's not right or wrong; good or bad. Just different. I have never had any difficulty doing anything over the years with Garmin's earlier Mapsource. But I really dislike Basecamp. I can figure out how to do anything I want with it. I just find it a real pain in the butt to do some of what should be the simplest things.
    And I really hate that it shoves everything into a single giant database. So I'm constantly trying to remember whether I'm working with the actual object or just a pointer to that object or ...?
    So I can genuinely understand when someone has difficulty wrapping their heads around Basecamp and also why those who get it don't get that anyone could have trouble understanding it.
    Vive la difference! Can you imagine the boring poor selection of motorcycles we would have to choose from if most people liked the same thing? :snore
    ...ken...
    leighwgold likes this.
