Garmin VIRB Elite Camera/GPS
Discussion in 'Equipment' started by Emmbeedee, Nov 6, 2013.
  1. globalstar66
    globalstar66 Been here awhile
    Sep 10, 2014
    306
    I guess when having it hardwired from a cigarette lighter usb, then you're not using the waterproof case?? Are you using the ultra cage part # 010-12389-12 to mount it?
    I was thinking of drilling a hole into the waterproof case, but there's no room to do so as the "door clamp" is right there....
    Could you maybe post a photo of the wiring into the case, if you're using the waterproof case with external power?
  2. yangins
    yangins Been here awhile
    Sep 23, 2014
    227
    Green Bay WI
    Here how I mount the camera. [​IMG]
  3. Emmbeedee
    Emmbeedee Procrastinators
    Mar 19, 2008
    11,481
    Near Ottawa, ON, Canada
    The issue is that you guys have two different models of cameras. The Elite doesn't have an external case as does the Ultra.
    So your Elite solution is of no use to the other guy.
  4. yangins
    Sep 23, 2014
    227
    Green Bay WI
    True, I am cheap and have the old ones.
  5. Emmbeedee
    Mar 19, 2008
    11,481
    The old one is the best one, imho, when you're speaking of Virb cameras. I have no time for the new model.
    But the one guy who complained about battery life was speaking of his Ultra.
    ER70S-2 and g®eg like this.
  6. yangins
    Sep 23, 2014
    227
    Green Bay WI
    New one trying to follow GoPro is not as good as the old ones.
  7. Emmbeedee
    Mar 19, 2008
    11,481
    I hope this isn't annoying anyone but I made a new video from my time lapse of the Five Islands Tides, and slowed the frame rate so you now see one frame/minute per second.
    It's three minutes long, but gives a better idea of what is going on in the tide changes.
    Hope you enjoy it.
    JensEskildsen likes this.
  8. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,158
    SE Denver-ish
    I know what's happening and why, but damn, that's a lot of moving water. :thumb
    Emmbeedee likes this.
  9. globalstar66
    Sep 10, 2014
    306
    Yip, I have the new Ultra 30. Thanks anyway. :)
  10. Emmbeedee
    Mar 19, 2008
    11,481
    Does the Ultra not have an external surface contact battery cable? The beta unit had one.
  11. globalstar66
    Sep 10, 2014
    306
    Nope, no such accessory cable unfortunately.
  12. Emmbeedee
    Mar 19, 2008
    11,481
    Too bad.
  13. globalstar66
    Sep 10, 2014
    306
    Yip.... And I contacted Garmin to ask about a waterproof case with built in charger, and was told the camera would get too hot charging inside a waterproof case.
  14. Emmbeedee
    Mar 19, 2008
    11,481
    Makes sense, but still too bad.
  15. DirtMerchant
    DirtMerchant Long timer
    Aug 2, 2004
    1,738
    Florida
    Never had an action camera and just ordered a Virb Elite Refurb today. I'll mostly be traveling on bike without a laptop, just iPhone and will have wifi. So now that I've got this thing coming, I need to get a data card ordered. I understand MicroSD Class 10 or better and no larger than 64GB is what I need. Do most of you just use one SD card or multiples?
  16. Gigitt
    Gigitt Adventurer
    Feb 9, 2014
    88
    Sydney Australia
    I use 128gb Samsung as cards and it works fine.
    Really easy to fill it when constantly recording. I swap cards and also have spare batteries.
    I also have a long USB power cable Not data cable for continuous power if needed. Especially needed if using wifi to remote control the video and or take pics.
    DirtMerchant likes this.
  17. DirtMerchant
    Aug 2, 2004
    1,738
    Florida
    Thanks for the feedback. Glad to hear 128gb will work. I am planing on using the power cord from my Powerlet outlet on the RT. I'm going to try to get by on one battery for know until I'm sure it is going to work for me.
    Any input on aftermarket batteries?
  18. Gigitt
    Gigitt Adventurer
    Feb 9, 2014
    88
    Sydney Australia
    I got the original batteries and even after 3 years they are still lasting.
    Do check your USB cable. some when plugged in will trigger the VIRB into data transfer mode. And not allow you to record while charging via a power outlet.
  19. dpike
    dpike BeeKeeper Supporter
    Nov 21, 2015
    1,896
    New Jersey
    i just switched from gopro to the virb. i like it a lot better and with the app built into garmin gps devices and a simple remote it makes it much more functional to me than a gopro cam.
  20. DirtMerchant
    Aug 2, 2004
    1,738
    Florida
    I am using a Zumo 395 which has the Virb app, hopefully Garmin will continue to support the Virb Elite.
