Garmin VIRB Elite Camera/GPS
Discussion in 'Equipment' started by Emmbeedee, Nov 6, 2013.
  1. Emmbeedee
    Emmbeedee Procrastinators
    Mar 19, 2008
    11,480
    Near Ottawa, ON, Canada
    Been working for me since last November when it was released.
  2. VStromNC
    VStromNC DNS/DNF
    Jul 12, 2007
    1,224
    Charlotte, N.C.
    It failed installation on both of my laptops with same error message. I did see the requirements are to have your computer running 64 bits and minimum 8mg of ram. My laptops run 32 bit Windoze and one has 2mg ram and the other 4 mg ram. It would be cool to have a small map embedded in the corner of my video showing the actual tracks. I do get the other info such as altitude and speed.
    Jon
  3. JensEskildsen
    JensEskildsen Long timer
    Mar 24, 2009
    2,277
    Denmark
    Havent updated virb edit in a while, it always seems to f#ck it up.
  4. VStromNC
    VStromNC DNS/DNF
    Jul 12, 2007
    1,224
    Charlotte, N.C.
    Emmbeedee,
    I am going to try time lapse this weekend at the RDV Rally. What do you normally have the field of view set at? Do you also enable digital stabilizer?
    Sent from my SM-G920V using Tapatalk
  5. Emmbeedee
    Mar 19, 2008
    11,480
    I hate the fisheye effect so I always have the narrow view. I think if you use stabilisation, and you probably should, it automatically uses narrow view.
    VStromNC likes this.
  6. VStromNC
    VStromNC DNS/DNF
    Jul 12, 2007
    1,224
    Charlotte, N.C.
    Thanks. I will give it a shot. My Zumo 590 connected with Virb instantly. I am going to ram mount it to my bars and run usb power as needed.
  7. Emmbeedee
    Mar 19, 2008
    11,480
    Do you have engine guards? Might be nice to mount there instead of handlebars, if that was your plan. Or move it around for variety.
  8. Emmbeedee
    Mar 19, 2008
    11,480
    The last couple of rides this year, my Virb Remote was flaky. It wasn't responding most of the time though the led was flashing. Since I couldn't remember the last time the Cr2032 button cell was changed, and I had a bunch of new ones, I changed it.
    Made no difference.
    So I did a factory reset on the camera, powered up while pushing the down arrow, and said yes to the reset dialogue.
    After the reset, the remote paired up quickly, as did the Tempe, and the remote now worked perfectly.
    And none of the files on the sd card were affected.
    So if it's not working properly, reset it. You have nothing to lose.
  9. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,158
    SE Denver-ish
    I had this exact problem earlier this month - the remote ‘recording’ LED was flashing but the camera wasn’t recording, which I had no way of knowing with the camera helmet mounted. It failed on my ride through Valley of the Gods - both directions. :cry
    I’ll try the factory reset. :thumb
    Emmbeedee likes this.
  10. Castos
    Castos Castos
    May 8, 2017
    120
    Pretoria, South Africa
    I have been following this thread. I see that the VIRB Elite is not available anymore. What is recommended in its place - VIRB 360?
  11. Emmbeedee
    Mar 19, 2008
    11,480
    I don't know of anyone who's bought anything later than the Elite. The new Virbs just don't have the same appeal to most of us. And our Elites refuse to die.
    ER70S-2 likes this.
  12. Castos
    Castos Castos
    May 8, 2017
    120
    Thanks Emmbeedee
  13. VStromNC
    VStromNC DNS/DNF
    Jul 12, 2007
    1,224
    Charlotte, N.C.
    Emmbeedee,
    I had it mounted to my handlebar via ram mount. I got back last weekend and took a brief look and it looks like the time lapse setting didn't work that well for me. It played my entire recording in about 3 mins. I didn't really play with all the editing tools yet but I'd like to slow it down without losing audio.
  14. Emmbeedee
    Mar 19, 2008
    11,480
    I have good news and I have bad news. The good news is, it’s easy to slow the time lapse down to extend its duration.
    The bad news is: time lapse doesn’t record audio.
  15. VStromNC
    VStromNC DNS/DNF
    Jul 12, 2007
    1,224
    Charlotte, N.C.
    PM me some editing tricks. Thx.
    I will say that interface between my Zumo 590 and Virb worked flawlessly. The 590 put the control icon on a small window on the main nav screen. Perfect as I was able to simply turn video on or off or hit the snapshot icon while riding. Later during the RDV ride, I used my USB cable and powered the Virb rest of the day. No problem at all.
  16. Castos
    Castos Castos
    May 8, 2017
    120
    Good Day to all the knowledgeable people on the forum. I can get a Garmin VIRB Ultra 30 Action Camera or the Garmin VIRB X Action Camera. Which is the best camera? Waiting for your responses.
  17. Castos
    Castos Castos
    May 8, 2017
    120
    Just pulled the trigger on a Garmin VIRB XE Action camera.
    ER70S-2 likes this.
  18. JR356
    JR356 Long timer
    May 4, 2005
    6,982
    Way Northwest
  19. Castos
    Castos Castos
    May 8, 2017
    120
    Here comes the question now: I am planning to mount it on the beak below the head light do I use and adhesive attachment or should I use nuts and bolts to fix it in position?
    I am planning on attaching the device with some thin SS cable (similar to steel trace used in fishing) to prevent the camera from falling off should it ever come lose.
  20. ThomasD
    ThomasD Been here awhile
    Jul 9, 2004
    147
    Bonn, Germany
    Adhesive does the job.
