Garmin VIRB Elite Camera/GPS
Discussion in 'Equipment' started by Emmbeedee, Nov 6, 2013.
  1. doxbike
    doxbike Been here awhile
    Nov 8, 2007
    340
    Lagunatic Beach
    So I have one of the first Elites and recently the rubber covering the power/mode button started to deteriorate and it eventually fell apart exposing the microswitch underneath. I initially wrapped electrician's tape around the body of the unit and used the end of my sunglass' temple pieces to turn it on/off/mode change. Finally, the brain fat passed after a few weeks of this and I decided to take the red neck repair to a new level. Took some Rescue Tape and folded it until the thickness = the distance to the microswitch, trimmed it to fit and then pressed hard enough to get it to adhere to a piece of the Rescue Tape and wrapped that around the body of the Virb- works just like it did originally and still water proof.
    Eltjo and g®eg like this.
  2. Emmbeedee
    Emmbeedee Procrastinators
    Mar 19, 2008
    11,448
    Near Ottawa, ON, Canada
    You never know what you're going to find when you ride back roads... A hunt pack out for a little exercise, it seems. Very well behaved, but then I am not a fox.
    All our Virbs are still working as well as ever.
  3. Castos
    Castos Castos
    May 8, 2017
    120
    Pretoria, South Africa
    I hav
    I have mounted my Virb XE on the beak of the bike and have experienced no vibration. I have the power cord attached.
  4. doxbike
    Nov 8, 2007
    340
    Lagunatic Beach
    working cows between Porterville and Kernville. Got caught in the largest active catle drive in California. Had to rinse all the cowshit off the Virb as well as the rest of the bike.
  5. Emmbeedee
    Mar 19, 2008
    11,448
    One of the things I like most about the Virb is its mount system. I can take the camera off with one hand while riding my bicycle and record videos like this, then put it back on the mount without needing to stop.
    My old dog loves going for a trailer ride. The camera was handheld for most of this.
    Eltjo and ER70S-2 like this.
  6. simplemind
    simplemind Been here awhile Supporter
    Jun 12, 2009
    231
    Austin/Telluride
    You mean on the front fender? Have a bike photo? Tks
  7. Castos
    Castos Castos
    May 8, 2017
    120
    Hi Simplemind
    Look at posts #108,110,116 where I have posted photos. I am at present in South Sudan and if you require more photos, let me know as I will be home in November
    Cheers
    Andre
    simplemind likes this.
  8. johnpitts01
    johnpitts01 Long timer
    Nov 13, 2005
    1,367
    Philly
    Recently my Virb will not record when powered by the battery. Works fine when powered by the USB cable. With a fully charged battery the video will come on for @ 3 seconds, then the screen goes blank for a second, then the recording stops. Same reaction from the unit wether innitiating the video from the slider on the unit or from the virb remote. Have tried a hard reset and have the latest software installed. Any ideas what the issue is and how to fix?
  9. Emmbeedee
    Mar 19, 2008
    11,448
    Have you tried a different battery? They all fail, eventually.
  10. johnpitts01
    Nov 13, 2005
    1,367
    Philly
    Yeah I figure it might just be the battery. I think I still have an extra battery in my bike bag. Will check tomorrow.
    Was just curious if anyone had seen this specific behavior.
  11. Emmbeedee
    Mar 19, 2008
    11,448
    I did see that specific behaviour a couple of years ago in Nova Scotia while on holidays. It was strange because it looked like the battery was fully charged but the camera never booted up. I switched battery and the camera went back to normal.
  12. duibhceK
    duibhceK duibhce Kaelann
    Jan 22, 2011
    503
    Chapel of the Well
    It is probably indeed the battery giving up the ghost. But I've seen similar behaviour with a battery not being pressed against the terminals properly. A bit of extra padding in the battery compartment opposite from the terminals cured that.
  13. johnpitts01
    Nov 13, 2005
    1,367
    Philly
    Found and installed my spare battery. problem solved. Is the other battery now pretty much trash? Does it make any sense to have that defective battery in the unit when I am running the camera as a dashcam with power from my car? And save the "good" battery for use only when running on battery power?
  14. Emmbeedee
    Mar 19, 2008
    11,448
    You might as well recycle that battery. It might fail inside the camera while the camera is powered via usb.
