Garmin Zumo XT - Short Term Review - North East USA
Discussion in 'GPS 101 - Which GPS For Me' started by _jonoz_, May 23, 2020.
  1. infinityzg
    infinityzg Adventurer
    May 26, 2012
    16
    Munich, Germany
    No, you can't. You need to have the App to be able to transfer to your phone and then as you please.
    You can ONLY transfer between Zumo devices without the need for the Drive app.
    #21
    wilfred, _jonoz_ and ohgood like this.
  2. ohgood
    Sep 21, 2010
    10,248
    alabama
    dang, I was hoping Garmin finally got around to having regular Bluetooth like the rest of the world.
    oh well, maybe the next version of the montana will have wifi and Bluetooth.
    #22
    _jonoz_ likes this.
  3. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,568
    MN and NM
    Do you have to have the XT hooked up to a computer to see the maps in Basecamp? Or do you use some other software for trip planning that also know about the maps?
    #23
    _jonoz_ likes this.
  4. infinityzg
    May 26, 2012
    16
    Munich, Germany
    Since I have the XT I do not use Basecamp anymore (althought you could and would see the maps from the device). I plan my trips using different planning websites (they are all known to us) and export the route or track as GPX and then send it to Garmin via Explore.
    #24
    _jonoz_ and wbbnm like this.
  5. _jonoz_
    _jonoz_ The guy on the Grom.
    May 20, 2018
    50
    Berwick, ME
    That might be a US only thing. #national/stateparks
    #25
  6. _jonoz_
    May 20, 2018
    50
    Berwick, ME
    I don't used Basecamp even though I have it. I believe I can just tap a place I want to go and creat a route based on preference of travel. I. E. No tolls, highways, dirt
    #26
  7. _jonoz_
    May 20, 2018
    50
    Berwick, ME
    Yeah I usually just look at a map digital or Butler and go for it. That's why I ride a big adv. #990
    #27
    sati8d likes this.
  8. Subaruvich
    Subaruvich Been here awhile
    Aug 14, 2018
    462
    EU
    Is there a possibility to pair it with some Bluetooth or have wired physical buttons to mount on the handlebars to be able to control the XT (zoom in and out for example) while riding?
    #28
  9. Patch
    Patch Long timer
    May 4, 2011
    3,045
    Southwestern New England
    Like all lifetime map Zumos you can install the maps to BaseCamp using Garmin Express so you don;t need to tether the unit to the computer to use BaseCamp.
    Its been a while since I updated maps, but there is a 'details' under the update menu. You have an option of device only, computer only or device and computer IIRC.
    #29
  10. ncj01
    ncj01 Long timer Supporter
    Nov 1, 2006
    1,445
    NW Arkansas
    so i'm struggling with my new XT:
    1. can't get the APP on phone to connect to device.. sits and spins, never connects (bluetooth connects to device however, so when i play music on phone, it comes out XT speakers)
    2. loading .gpx files - total fail
    • load .gpx flies onto micro-SD card
    • put card into XT
    • device does NOT recognize any file/route on the card (import and no data found)
    #30
  11. Peculierboy
    Peculierboy Adventurer
    Sep 16, 2014
    56
    An island off the coast of Maine
    You have to put the GPX files on the main card in the Garmin, not the accessory card. 'Garmin/GPX' https://support.garmin.com/en-US/?faq=ACgfZF717vAeVfhHgPrFv6
    #31
  12. kennyh
    kennyh Been here awhile
    Feb 7, 2004
    392
    Friendsville, TN
    I think you can send to the sd card, but you won't be automatically prompted to import. After sending it, select apps then trip planner. If it works like the bmw nav V, you should see 3 bars in the upper left corner above any previously used routes. Tapping it should provide options for deleting, importing and sharing routes. Select import and the routes on the card should be visible and able to be imported.
    #32
  13. Scottyluc
    Scottyluc Been here awhile
    Feb 5, 2015
    896
    Southwestern CT
    When following a Track, can you adjust the actual Track line shown on the screen? Not the color but the width as well? I have a 595 and this is not possible without using other software.
    #33
  14. Uralspaz
    Uralspaz Bat Boy lives!
    May 10, 2017
    137
    Urainus Washington
    Ugh, maybe I'm a total luddite but I bought the XT and am wondering if it was a waste of money because I'm too stupid to ise the thing. Tried using basecamp to create a route but apparently if the route is on forest service roads or trails I have to spend another Benjamin for Topo 24K west? When I look at the XT the maps show FS roads but nothing on Basecamp but paved roads. Can you create a route from the device itself? Is there an easier option other than basecamp? I'm about ready to stomp this fu%$ing thing into dust and go back to using Gaia!
    #34
    G_in_R likes this.
  15. TheLondonder
    TheLondonder Been here awhile
    Mar 28, 2016
    656
    London
    OP, have you ever used the TomTom Rider and do you have a sense for how they compare?
    TomTom has a cloud thing that lets you add favourites and plan routes from its website, then it will sync without the need to connect to a PC. Does Garmin have anything similar?
    Have you used it in a car? Is the speaker OK for a car?
    #35
  16. TheLondonder
    Mar 28, 2016
    656
    London
    PS How about the motorcycle mounts? Does it come with RAM mounts? was it easy to install? Could you maybe post a picture?
    #36
  17. turtlespeed
    turtlespeed Been here awhile
    Feb 15, 2016
    630
    NJ
    I don't have the XT, but I have the Rider 550. I like the website (mydrive) for route panning. Sync with devices is seamless and easy.
    I do use Garmin Base Camp for its good cataloguing features. You will go crazy if you load 100 routs/tracks on tom tom website, as the website has no folder feature for proper categorization.
    I use my 550 in the car also, and the volume is very good / no issues at all.
    #37
  18. Saltboxlad
    Saltboxlad Long timer
    Jan 13, 2015
    4,027
    Wales, UK
    Im having same issue connecting app to device, Ive given up for now, love the XT though so far, looks almost factory fit on the 1290 SAS:
    #38
    beefcake morris and ncj01 like this.
  19. bozmotodual16
    bozmotodual16 GuttenTight Supporter
    May 11, 2016
    395
    Gallatin Gateway, MT
    Great review ~ also interested in how folks are mounting to bike. I have an older Garmin 550 that has a bomber mount/wiring base. Would like to have same for XT.
    #39
  20. dirtmarine
    dirtmarine Been here awhile
    Jul 21, 2014
    524
    Kansas City
    So I'm looking at the XT vs the new Montana 700i. I don't do a lot of backcountry nav anymore just main and secondary highways. The 700i will allow 3rd party tracking which I don't think the XT will. Can you save a track and then send it to 3rd parties via txt/email on the XT? The XT is 100-200 cheaper. Has anyone compared these 2 units yet, the Montana 700 is just out, it has a long battery life that would work for many day rides. I intend to use an X mount on the bike and a vehicle and charge using only the USB, not hardwired. Will the USB charge the XT while riding?Looking for opinions on choosing a new GPS.
    #40
