Garmin Zumo XT
Discussion in 'Mapping & Navigation' started by VCheng, Feb 25, 2020.
  1. bomber60015
    bomber60015 Hold fast Supporter
    Sep 11, 2008
    80,653
    Chicago-ish
    No … the converter drops the voltage … plugged into a usb, the voltage doesn’t need to be dropped.
  2. Barry
    Barry Just Beastly
    Oct 4, 2002
    10,642
    Fredericksburg, Va.
    Nice. My intent was to put a 12v tip on the end. May as well put the USB on the end, and us the dual USB 12v cig adaptor that I have anyway.
    Every car, truck, moto I have has either 12v plugs, USB(s), or both. Can’t lose.
    bomber60015 likes this.
  3. Barry
    Barry Just Beastly
    Oct 4, 2002
    10,642
    Fredericksburg, Va.
    OK - not an electronics expert. I get black gets connected to black, red to red. Beyond that I’m pretty much out of my depth.
    Two questions… first, if I cut off the mail end of a USB cable, is it gonna’ be a black and red wire coming out so I don’t fry my new unit?
    And, if I get the tip you show that comes apart, does it tell in the instructions where to soldier the red/black wires, again, so I don’t fry my unit? I have a TON of USB cables, that may be the easiest route long as the wires are red/black when I cut the male tip off.
  4. Cuttin
    Cuttin Been here awhile
    Sep 1, 2007
    101
    ...greater central Texas...
    VertigoGSA and bomber60015 like this.
  5. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    5,440
    Bridge over Troubled Water
    Not sure what type of problem you experienced but..
    I created a route without any issue at all and ran both (route and track) simultaneously on the XT as I followed along for ~180 miles
  6. Fast1
    Aug 18, 2007
    5,440
    Agree I have the full car mount and power cord for use in my convertible sports car. Fine inside a closed environment isolated from dust/rain/water etc..
    May last a bit on a pavement only street bike on perfect weather days.
    V-Tom likes this.
  7. Shawnee Bill
    Shawnee Bill Long timer Supporter
    Feb 25, 2006
    5,750
    Oklahoma
    When you cut the cable there is a center red insulated wire and then some strands of uninsulated wire.
    Cut the end off one of your old USB cables and splice the red to red and the ground to ground, or get one of these (actually they seem to come in packs of several), link to You Tube that shows which wire goes where, except in our case there are no yellow and green wires, those are data transfer and we just need power, red and black or in our case red and uninsulated. That link will point you to more similar videos if you need more.
    Pretty easy to check that you are wired properly, just plug the EMPTY cradle into a USB charge port and check that the center pin on the cradle is positive 5 volts.
    Barry and FireDog45 like this.
  8. FireDog45
    FireDog45 Squirrels get enraged when they see me naked Supporter
    Sep 16, 2006
    2,025
    Central, Ohio
    For those considering removing the converter: do not plug in to 12v power! If you’re adding a USB connector then you’re fine. If you’re adding an SAE or other of those types make sure the port you’re plugging into is only 5v. I’m no electronics expert but I don’t think the XT would survive long connected straight to a 12v source.
    Of course I could be wrong…
    MUDHWY, bomber60015 and Barry like this.
  9. Barry
    Barry Just Beastly
    Oct 4, 2002
    10,642
    Fredericksburg, Va.
    I’ll grab one of the many USB cables I have and cut it, I can definitely do that connection correctly. Thank you.
  10. markbvt
    markbvt Long timer
    Sep 26, 2007
    4,471
    Georgia, Vermont (that's one town, not two states)
    Just keep in mind that the disadvantage of using USB is it's not weatherproof, unless you do something yourself to keep it dry. SAE or Powerlet plugs can be rained on without issue.
    --mark
  11. Barry
    Barry Just Beastly
    Oct 4, 2002
    10,642
    Fredericksburg, Va.
    SO, I think I need a new XT cable. I opened a USB Male Cable end and found 4 wires. Clearly a red and black.
    I opened the XT cable that mounts to the rear plate with the pins and inside the cable sheath there is only 1 white cable. I expected to find at least a black and read cable. Am I missing something???
    Pics below of both cable ends.
    Male USB CABLE that I wanted to connect to the Garmin cable. Note red and black power cables.
    This is the cable that comes from the back of the Garmin unit. Has only 1 white wire. I expected to see a red and black cable. I may just order a new cable and put a 12v cig plug on it and just rock on. Preference is for a male USB connection, but somehow I don’t see enough wires to make that connection. Am I missing something????
    Color me frustrated already…. There are 2 pins on the Garmin cable. That’s ground and power. So how is there is ONLY ONE WHITE WIRE coming out ofthe Garmin cable?????
  12. HarveyM
    HarveyM Long timer
    Sep 10, 2010
    1,018
    Ottawa, Canada
    I think it's a coax style cable. Your other 'wire' is the uncovered bare metal wires shown in your photo like this:
    White inner wire, other wire is the wire 'weave' just under the outer black insulator.
    V-Tom likes this.
  13. Barry
    Barry Just Beastly
    Oct 4, 2002
    10,642
    Fredericksburg, Va.
    Yes, so how do I add the USB cable with BLACK / RED to that single wire????
  14. Shawnee Bill
    Feb 25, 2006
    5,750
    Oklahoma
    Opps, you're correct, Garmin in it's wisdom decided to make the hot wire white instead of red. Been a while since I covered mine up, I had to go dig out the Garmin cable and check.
    Splice the red wire of your USB cable to the to the white coming out of the cradle, splice those bare wires (shield) to the black, the other two wires (they look to be white and green) are for data and are not needed to just power the XT. Just put/cut them out of the way so they don't short to power.
    Heat shrink over each splice then more heat shrink over the entire splice.
    Before you do anything plug your old cable into a live USB charge port and check with a meter, you will see positive 5 V on the red wire. One meter lead on the red wire, one on the black wire.
    Check that the white wire on the cradle connects to the middle pin on the cradle.
    And before you put the XT in the cradle plug it in and check that you have +5V on the center pin of the cradle.
    Barry likes this.
  15. GotMojo
    GotMojo Long timer
    Jan 10, 2016
    1,365
    Orange County, CA
    You need to buy a Bluetooth Cable [tm]! :-)
    If you want to bypass the cable's 5VDC regulator and power directly from a USB port, you need to wire the center conductor to the +5V wire and the outer mesh to GND. Easiest way is to get some USB-A shells as they will provide a bigger pad to solder onto.
    The garmin cable only provides power, not USB functionality.
  16. Shawnee Bill
    Feb 25, 2006
    5,750
    Oklahoma
    The cradle and the wiring coming out of it are waterproof, the only questionable connection is where you plug the USB into the USB charge port. If I'm concerned about that I use one of these and put it in a protected place, tank bag or some such. Very handy USB chargers.
    https://www.batterytender.com/battery-tender-usb-charger-adaptor_2
    Those are available from Amazon and other places.
    More and more new model bikes are coming from the factory with USB charge ports. Good reason (excuse) the buy a new bike! :clap:imaposer:1drink
    JackalHack likes this.
  17. Barry
    Barry Just Beastly
    Oct 4, 2002
    10,642
    Fredericksburg, Va.
    Job completed. Success, 5v at the correct pin, plug the cable into USB port and GPS asks if motorcycle mode is desired.
    ThX.
    Barry
    Shawnee Bill and bomber60015 like this.
  18. MUDHWY
    MUDHWY Look What You've Done
    Jun 4, 2014
    14,803
    The Edge Of Town
    You're not wrong. Using the method described strictly limits you to USB connection.
    FireDog45 likes this.
  19. Clammy69
    Clammy69 Been here awhile
    Jun 16, 2020
    154
    Canada
    This was my solution, after my other XT flew past my head at 75 mph! :baldy
    Cheers!
    :super:super:super
  20. GotMojo
    GotMojo Long timer
    Jan 10, 2016
    1,365
    Orange County, CA
    Same kind of thing here.
