Garmin Zumo XT
Discussion in 'Mapping & Navigation' started by VCheng, Feb 25, 2020.
  1. kreativ
    kreativ OFFROADer
    Dec 14, 2011
    26
    Wroclaw, Poland
    Question about azimuth driving. Often on rallies only the angle and distance are given in the roadbook. And you have to enter it in the navigation. Is this possible in XT? in the 64 series you can do that.
  2. boulet_boulet
    boulet_boulet Long timer
    May 14, 2018
    1,244
    Maine
    Actually, it does appear that thickening tracks also thickens the 'where I've been' track. I compared my breadcrumb track on a modified theme vs. an unchanged one and it appeared larger. My issue appears to be more that an aftermarket ATV map I have installed conflicts with my where I've been track. Problem solved; new one found.
  3. TripleThreat719
    TripleThreat719 Track Addict ADV Wannabe
    Mar 21, 2009
    511
    Trafalgar, Indiana
    That's good news... well, sort of...
  4. simon crewe
    simon crewe Been here awhile
    Sep 27, 2007
    185
    Haslemere, UK
    I had a feeling it would help, as it is designed to modify the 'track' generated by you or down loaded - both are tracks.
    Glad to hear it works for you - good old adv rider!
  5. simon crewe
    Sep 27, 2007
    185
    Haslemere, UK
    I am sure the only things, that the XT will accept are coordinates in various formats, i think you are looking for something different?
  6. kreativ
    kreativ OFFROADer
    Dec 14, 2011
    26
    Wroclaw, Poland
    yes different:/ on roadbook I have only info about distance and angle and I need to find a waypoint on the map to go there. No coordinates:/
  7. kreativ
    kreativ OFFROADer
    Dec 14, 2011
    26
    Wroclaw, Poland
    HI did you try send waypoints from gpsmap 66 to XT?
  8. AliveDK
    AliveDK Long timer
    Sep 8, 2013
    1,134
    Denmark
    Thanks, quite helpful for us senior
    citizens:-)
  9. simon crewe
    Sep 27, 2007
    185
    Haslemere, UK
    Or go to post #476 and modified themes are already written & sitting in drop box for you to down load.
    AliveDK likes this.
  10. birdbearbeast
    birdbearbeast Been here awhile
    Jul 13, 2006
    101
    Dublin, Ohio
    FYI for anyon with the same issue...they (garmin) reprovisioned (or whatever they do) on their end and after a reset all good.
  11. CmdrPopNFresh
    CmdrPopNFresh Adventurer
    Apr 27, 2014
    64
    I was instructed by garmin to just return it through the place I purchased it from. I ordered it from amazon so it was a quick and painless exchange.
  12. bash3r
    bash3r 790ADVR
    Aug 8, 2009
    1,962
    Wentzville, MO
    So I've heard some say the XT is great for ADV, and others say it's missing a lot of features that the 276cx has or older GPSMAP units, like 478, 276c, etc.
    Can it replace the full featured 478 or 276c? I couldn't find the spec on how many tracks/routes/POIs you can load up... Debating on XT or 276cx , currently running an older 478c.
  13. yoohah
    yoohah Been here awhile
    Jun 5, 2012
    279
    I would also like to see comparison between 276cx and xt. I believe either one is ok for the adv riding, they are vastly versatile. But why Garmin is keeping two different product lines? They should listen users and create one good product. Obviously they know how to make a good display and fast processor. But they should add more connectivity (via wifi, bt or whatever) to sync universally files. The file system should be easily visible (not through some spesific dysfunctional app) for uploading and downloading files, maps, tracks and routes and other stuff. No cables anymore. And pushing and pulling the sd card constantly is not a clever either.
  14. Rofor
    Rofor Adventurer
    Mar 28, 2011
    37
    1130 Vienna, Austria
    Hi People,
    I post this here for a fellow biker in the german 'Tigerhome.de' forum - Does anyone here with a Zumo XT ride it with a Triumph Tiger Explorer 1200 or the new Tiger 900?
    Some guys here in Germany/Austria have noticed a massive(!!) interference between the new TFT instruments which is Triumph using since 2018 and the new Zumo XT. If the Zumo XT is mountet near the display, the GPS/Galileo reception brakes down nearly complete - this is verified for at least two Triumph Tiger 1200 2018 models and also with one Tiger 900...
    Here are the corresponding photos for this problem:
    Zumo XT in mount - ignition and display off
    Zumo in mount - ignition and display on
    When the Zumo XT is taken out of the mount and moved about 50cm (should be around 16ft.) away from the display, the signals from GPS and Galileo are back again - this is verified by at least by one other Tiger 1200 rider and also by a rider of the brand new Tiger 900...
    If you put a 'shield' between the Zumo and the display, also all works fine again - the guy, who noticed this problems first, has proven this in a video with a shovel - you can see those videos here: https://www.dropbox.com/sh/1s96hwzjmflfn28/AADGud_sVl0sSWVOpYVorusia?dl=0
    Maybe someone here can proof this also - and maybe someone with good contacts to Garmin US can inform them, which will under circumstances will be faster than here from Europe - the fellow biker, which discovered this massive problems, has already opened a ticket with Garmin and with Triumph...
    Greetings from Vienna!
    ohgood likes this.
  15. kubcat
    kubcat Long timer Supporter
    Sep 22, 2016
    1,412
    Upstate NY
    Yeah - in other communities its well known that certain very low cost amplified antennas for VHF/UHF TV signals can effectively jam GPS signals for a significant range. This is due to the very low power of the GPS satellite signal at the receiver. It sounds like the TFT display electronics or the ECU generates noise at a frequency that overlaps with the GPS signal. Not Good.
  16. michaeln
    michaeln What're YOU lookin' at? Supporter
    Jul 30, 2007
    3,985
    Avery, State of Jefferson
    I believe that is a Triumph problem, not a Garmin problem.
  17. kubcat
    Sep 22, 2016
    1,412
    Upstate NY
    Uh, yeah. Or maybe we should launch new satellites with new frequencies to allow the Tigers to work with GPS:jack
  18. Rofor
    Rofor Adventurer
    Mar 28, 2011
    37
    Yes, for sure - i'm with you! Proofed it a few minutes ago on my wifes Street Triple R 765ccm, which uses the same display....
    20200526_155103_Zündung aus.jpg Ignition off (infront of the display),
    20200526_155036_Zündung ein.jpg Ignition on
    ohgood likes this.
  19. michaeln
    Jul 30, 2007
    3,985
    I just checked on my 2020 KTM 890 Duke R. There's no effect on the satellite display page whether the engine is running or off. I have it mounted to the mirror mount:
  20. FearFas
    FearFas Adventurer
    Jul 22, 2017
    11
    HI Guys (after reading the 1319 posts before this one).
    My Wife and I bought 2 x XT´s for our bikes and 1x Garmin Topo Spain V7 (as we live in Barcelona).
    1- Once the topo spain V7 is installed in Basecamp, I had selected a small area of 20sqr Kms, and exported with Mapinstall to have it in my GPS (as did 1000´s of times with other maps on my GPSMAP 64s ) .
    2- Copied the exported file into the 64S and works without any issue.
    3- Copied the exported file into the XT and says something like "the map is corrupt" .
    To confirmed that was not a problem with the topo spain v7, did the same with one of the maps that come installed in the GPS with the same result..
    When i move the Garmin topo v7 SD card, from 1 gps to the other it wont work either. It looks like the maps are getting "married" with the first unit you use it .
    Any ideas?
